Yo guys, picked up my first skid car 318is M44. Clutch started slipping after a session, just wondering if its worth while upgrading it as I plan to use it quite a bit and only being a 1.9 its gonna require a bit of clutch kicking to instigate or will the standard clutch be man enough? Not on a massive budget so don't wanna fork out for a fancy clutch if the standard ones gonna cope fine. Cheers guys.
Just buy a Sachs one that will be perfect. You need to clutch kick a lot while in a corner as they bog down a bit sometimes in second, speed and flick is good on entry. Hydro helps when u lack the power tho.
If you ever did want to upgrade... I believe the 3.0 M3 clutch fits your M44! I can get more info on if you like?
This is what you want to see.... Its off another forum... as I am a forum slag LOL the link below is the actual thread! 1998 e36 1.9 Z3 - M44 supercharging thread
