Old 17-12-2007, 11:14   #41 (permalink)
scrutineer
Originally Posted by LUFFY View Post
does th passenger harness have to be FIA approved?
Marc, will my monaco seat be ok, has an FIA approved badge on it but says till 1995, will this be ok for AM
double check as the date on the seat is often the manufacture date note the use by
Marc
Old 17-12-2007, 14:57   #42 (permalink)
SteveC200
is Stupid
SteveC200's Avatar
Originally Posted by scrutineer View Post
the subframe would be classed as part of the seat so the subframe would need bolting down as in the regs and as a aftermarket frame would be mounted on the floor not using the original mounts then it would need spreader plates.
by the way when plates are described as 5" they do not have to be square - 6.5x4" 8x3etc is fine if that fits better its the area thats needed
marc
Damn, my 'save Marcs fingers from wearing out' post didnt work.
So basically... if using standard subframe mounting points then no need for spreader plates but if the subframe is bolted to anywhere else on the floor then spreader plates are required.
Old 17-12-2007, 15:32   #43 (permalink)
scrutineer
if using the standard mountings you need to make sure that they are strong enough to take the strain but otherwise yes.
your concern for the wellbeing of my fingers is quite touching
Old 22-12-2007, 17:48   #44 (permalink)
royal
S1- F.T break!
Are road legal semi-slicks allowed for BDC, eg 888s etc? I'd like to use them on the front. I know its says 'no cut slicks' but I'm not sure of the terminology and what these actually are.
Old 22-12-2007, 21:02   #45 (permalink)
Most wanted
a048's and r888's etc are moulded tyres, not cut slicks. They are e-marked and legal for road use.
Old 23-12-2007, 00:29   #46 (permalink)
Two_Sheds
chaplad
Forgive me if its already been covered/I am being thick, does the rule about having to disable boot locks and add boot pins/springs apply to those of us with batteries in the boot (i.e. all BMWs), or is it only people with fuel/nos systems (i.e. highly flammable stuff) that it applies to?
Two_Sheds is offline   Reply With Quote
Old 23-12-2007, 10:41   #47 (permalink)
BDC
BDC's Avatar
We will be amending the rule re boot locks.
As Mr Carter stated earlier, the EDC said the boot need only be accessible if it contains anything that could be hazzardous. The BDC will opereate the same rule.
Many thanks
The BDC team.
BDC is offline   Reply With Quote
Old 28-12-2007, 17:07   #48 (permalink)
Jord
PS13 Silvia
Jord's Avatar
3-21. Catch tanks for oil and water must be installed and securely fastened with its contents easily visible on inspection.
I currently have an oil catch tank however it has no sight/level on it - will this need to be changed?
Also, where would an water catch tank come from? Is the stock radiator expansion bottle sufficient?
Old 29-12-2007, 00:14   #49 (permalink)
FlikstRR
FlikstRR's Avatar
can i quadruple check yet again.. as i want to be crystal with this:
My harness has no visable FIA markings (its a border 4 point). It does however meet the same specs as the DW TRS ones.. (3" straps, computer controlled stitching, aero buckle and reinforced joins).
do i REALLY need to spend another £120? i thought Border was a good make. And i have alot of outgoing cash atm.
FlikstRR is offline   Reply With Quote
Old 29-12-2007, 08:51   #50 (permalink)
Most wanted
JDM's fricked people up y'all with their lack of FIA gayness.
Old 30-12-2007, 21:56   #51 (permalink)
Jord
PS13 Silvia
Jord's Avatar
Boiiiing! Scrutineer?
Old 31-12-2007, 12:43   #52 (permalink)
cefiro_drifta
mad pointing munkey
cefiro_drifta's Avatar
i to need to know about the catch tank as my engines pretty much standard and i still have the factory catch tank on ... would that be ok ?
Old 31-12-2007, 17:10   #53 (permalink)
scrutineer
yes -
Old 31-12-2007, 17:10   #54 (permalink)
scrutineer
that would have to be answered by whoever is scrooting at the events - effectively a harness needs to have a FIA label to be approved but if you can convinve the scroot that that one conforms .......
Old 31-12-2007, 17:11   #55 (permalink)
scrutineer
who?
Old 01-01-2008, 14:12   #56 (permalink)
cefiro_drifta
mad pointing munkey
Old 01-01-2008, 17:45   #57 (permalink)
Most wanted
Just about to buy a 6 point 3" sabelt harness, FIA approval ran out end of 2007. This would be fine as long as it shows no signs of damage, correct? I've asked a couple of times but understand it getting snowed under by other questions. Cheers.
Old 01-01-2008, 17:51   #58 (permalink)
Baba
BORN SIDEWAYS
Baba's Avatar
Just a suggestion but maybe you guys could try PM'ing Mr Scrutineer. He may not have noticed the new posts on this thread.
Old 01-01-2008, 18:10   #59 (permalink)
Matt_S
SELLIN' UP!!!
Matt_S's Avatar
Mike, my catch can consists of a 'fruit shoots' (or similar) bottle with the breather pipe wedged int he top and some holes peppered around the top. Its translucent enough to see any oil in it. ANd it passed EDC scrutineering
Matt_S is offline   Reply With Quote
Old 01-01-2008, 19:18   #60 (permalink)
scrutineer
just to clarify the situation
as the scrutineer for EDC - i agreed with mark (sweeps) that i'd keep an eye in here and answer some regs questions where i can but i'm not actually connected with BDC and so cannot answer borderline questions as this will be the decision for the BDC scroot not me - especialy in the AM cars as we do not have an equivilent set of regs.
and no , at this stage i do not know who will be
I hope you understand the situation - basically i cannot make decisions for BDC
Marc
