Old 01-01-2008, 23:11   #61 (permalink)
Baba
A Super Slider
Baba's Avatar
Well I would say for any Pro drivers, you might as well meet EDC regs because there is a chance you will move up sooner or later.
Thats what I am doing. My car will be EDC spec by March.
Old 02-01-2008, 08:36   #62 (permalink)
e30 of Death
EDC - pish. PAY A MILLION POUNDS TO HANDBRAKE ROUND ONE CORNER 10 TIMES. No thanks.
Old 02-01-2008, 13:41   #63 (permalink)
Matt_S
SELLIN' UP!!!
Matt_S's Avatar
Oh come on Mike, be fair.....
ITS EUROS!!!!!!!!!!! Hahahahahaha
Matt_S is offline   Reply With Quote
Old 05-01-2008, 17:21   #64 (permalink)
Alex B
Alex B's Avatar
Send a message via MSN to Alex B
Originally Posted by scrutineer View Post
the subframe would be classed as part of the seat so the subframe would need bolting down as in the regs and as a aftermarket frame would be mounted on the floor not using the original mounts then it would need spreader plates.
by the way when plates are described as 5" they do not have to be square - 6.5x4" 8x3etc is fine if that fits better its the area thats needed
marc
Is there a minimum or recommended thickness for the spreader plates?
Thanks
Alex B
Alex B is offline   Reply With Quote
Old 07-01-2008, 10:28   #65 (permalink)
Captain Muppet
EuroDrift's slowest loser
Captain Muppet's Avatar
Thanks
Alex B
Min of 3mm in the rules.
Old 07-01-2008, 17:59   #66 (permalink)
Alex B
Alex B's Avatar
I couldn't find anything in the rules, I pm'd Marc, he said minimum of 2mm, but 3mm recommended, which is great as I have a load of 3mm plate
Alex B
Old 07-01-2008, 23:56   #67 (permalink)
scrutineer
scrutineer's Avatar
as before, remember i'm not the BDC scrutineer so cannot make decisions for them the final decision in any matters wouldbe the BDC scrutineer not mine.
If anyone PM's me could they let me know which championship they are entering
Old 08-01-2008, 00:14   #68 (permalink)
Alex B
Alex B's Avatar
Sorry, thought you 'sort of' doing both, just seen your post on the previous page.
I'd guess BDC will not be stricter than EDC though? I'd rather build/modify my car to top level, especially for safety regs.
Alex B
Old 08-01-2008, 00:17   #69 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
BDC will be as strict, if you follow the rules and regs, which are pretty much identical to the EDC ones, you wont go wrong
Old 08-01-2008, 00:19   #70 (permalink)
scrutineer
scrutineer's Avatar
Alex B
not a problem - i have been helping out on line while they get sorted so in many ways i have been doing both but as i said anything that requires a decision is not up to me
Old 09-01-2008, 02:16   #71 (permalink)
jrc
Watch Out 2009
jrc's Avatar
batt cut off switch
stupid question but do the batt cut off switches for bdc pro need to be FIA approved also?
jrc is offline   Reply With Quote
Old 09-01-2008, 02:34   #72 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
yes, think of FIA as a benchmark for an acceptable level. or standard in equipment, BDC and EDC have aligned there regulations very closely.
why buy twice.....what happens if you end up in EDC
the difference in price between an FIA approved switch and a non FIA switch is a couple of quid
Old 09-01-2008, 17:47   #73 (permalink)
Jord
GRD Drift Club
Jord's Avatar
I currently have a oil catch tank from the crankcase breather, it has no sight/level indicator on it though - do I need to change it for one with a level sight?
Old 09-01-2008, 18:04   #74 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
odd one this really, as before, in other racing ive done, the catch can only had to be easy to check,
as in it had to have an easily accesable balcock type valve that could be flicked open to prove the can had no fluid contents within.....
this is the device i now have fitted to the lex as a coolant catch can.
an easy alternative to the catch can is to fed the breathers back into the intake. its how i did it on mine, just fed the cam cover breathers back into one of the turbo air inlets.....however i dont have any oil being blown about so i suppose its an easy option for me
Old 09-01-2008, 18:40   #75 (permalink)
Jord
GRD Drift Club
Jord's Avatar
Originally Posted by BDC Regs
3-21. Catch tanks for oil and water must be installed and securely fastened with its contents easily visible on inspection.
From this I'd read that you HAVE to have one. Easily visible I guess could mean disconnecting one pipe to check its empty.
Old 09-01-2008, 20:45   #76 (permalink)
e30 of Death
Hope we don't have to have one if we retain the standard recirculating oil breather system, as long as there's no way for oil to start dripping on the track/exhaust etc I can't see that being a problem surely?
Old 09-01-2008, 20:47   #77 (permalink)
SteveC200
talent bypass
SteveC200's Avatar
As I understand it, you are correctamundo.
Old 09-01-2008, 22:06   #78 (permalink)
howler
Ah I was wondering about this as my engine has the re-circulating stuff so that will save me some pennies
howler is offline   Reply With Quote
Old 09-01-2008, 23:39   #79 (permalink)
Gavwan
Gavwan's Avatar
Doh! bought one now
Ah well, sure it can't hurt
Gavwan is offline   Reply With Quote
Old 10-01-2008, 12:13   #80 (permalink)
Jord
GRD Drift Club
Jord's Avatar
Just preparing my shopping list for Autosport on Sunday....
Helmet, obviously has to meet the standards set out, as does race suit.
Gloves - is there a standard these have to meet? FIA? Or do they just need to be fireproof?
Boots - again, do they have to be FIA, fireproof, or just racing boots?
