Old 17-03-2008, 14:46   #141 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
Originally Posted by Captain Muppet View Post
Arse. Looks like I have to drill holes in the only decent panel left on my car. Stupid Mazda stupid battery in the stupid boot. Nuts.
Also my lid is marked "BS6658 1985 Type A" which I assumed was OK, but the regs say "BS6658-85 Type A". Any official word on this BDC?
BS6658 1985 Type A and BS6658-85 Type A are the same thing, only that the year has been abbreviated on one of the labels
Old 25-03-2008, 15:25   #142 (permalink)
Pikey
Pikey's Avatar
Originally Posted by BDC
If you have a breather pipe which does not return into the inlet system on the car an oil catch tank is required.
So if you have standard breather system you dont need a catch tank
We dont need boot pins if there's nothing in the boot
Sorry, just triple checking through stuff and aswering my own questions.
However, no-one answered this question yet: The Driftworks seat subframes have a seatbelt mounting point - are we ok to use this to attach one of the lap straps?
Old 25-03-2008, 15:52   #143 (permalink)
Captain Muppet
EuroDrift's slowest loser
Captain Muppet's Avatar
Thanks, I've been worrying about this even more than getting the car there in one bit. I'd hate not to drive because of a couple of letters on a label.
Old 25-03-2008, 16:36   #144 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
ideally both mountings for the belts should be to the "same" structure so the stress is equal, its possible the stress added to the seat frame in an accident , could cause it to deform or collapse.
by having your harness anchored to the chassis not only holds you in, but holds you, and the seat and reduces the loading on the seat mountings.
the scrutineer will be looking for the harness mounting points to be sufficient
Old 25-03-2008, 16:45   #145 (permalink)
royal
S1- F.T break!
Erm....does that mean harness points on the DW seat runners are not acceptable? can we have an official answer on that as it may cause issues?
Old 25-03-2008, 16:47   #146 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
i said Ideally.
also said Sufficient
i,ll clarify with the regs
Old 25-03-2008, 16:50   #147 (permalink)
Pikey
Pikey's Avatar
I think I'll drill another hole and use the other driftworks eyebolt plate I've got spare, just to be safe. It's a bit of a squeeze using the seatframe point anyway
Old 25-03-2008, 16:57   #148 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
"....subframe would be classed as part of the seat so the subframe would need bolting down as in the regs and as a aftermarket frame would be mounted on the floor not using the original mounts then it would need spreader plates.
by the way when plates are described as 5" they do not have to be square - 6.5x4" 8x3etc is fine if that fits better its the area thats needed........."
and from the rules and regulations..
4-7. Safety harnesses must be used with a minimum of four fixing points (although we recommend a harness with five fixing points) and comply to SFI regulations or above and must be securely attached to the vehicles body or roll cage for both driver and passenger seats. The straps from the shoulders should be mounted as near to horizontal as possible – not on the floor immediately behind the seat
i would say it is far better to drill a hole, and put an eyebolt into the vehicle body, its much more safer
if the harness is mounted to the seat for RD 1, it will have to be rectified for round 2
Old 26-03-2008, 11:20   #149 (permalink)
Pikey
Pikey's Avatar
The rules say the external activation button for the battery isolator must be located on the nearside (that's the passenger/left side isnt it) of the car, but there's no guidance as to which side the fire extinguisher pull cable should be - and as I've done that first I happen to have put it on the drivers side!
I'm going to put them both in the same place (on the drivers side), unless someone says otherwise?
Old 26-03-2008, 18:27   #150 (permalink)
Kev
standard seat belt mount is on the seat, so i cant imagine there being any problem with mounting one of the harness points to that same point.
Kev is offline   Reply With Quote
Old 26-03-2008, 18:41   #151 (permalink)
howler
I would imagine they would want them both in the same place on the passenger side
howler is offline   Reply With Quote
Old 26-03-2008, 22:54   #152 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
they should both be on the passenger side of the car
Old 10-04-2008, 22:51   #153 (permalink)
cefiro_drifta
mad pointing munkey
cefiro_drifta's Avatar
just one question ... iirc u have to do at least 5 round out of the 6 for your points to be counted but if u only do 3-4 will your scores be put on on the score board so people can see but they wont be counted towards the actuall placing ??
just wondering really as i want to do the rounds i can which is only 3 due to family commitments and other things but wouldnt mind see points on the table if i should get any
thanks
cefiro_drifta is online now   Reply With Quote
Old 23-04-2008, 16:28   #154 (permalink)
General Banter
General Banter's Avatar
A quick one for you. I have the OEM metal bonnet, does that still need to be secured by bonnet pins and do they have to be flush-fit? For AM class.
General Banter is offline   Reply With Quote
Old 23-04-2008, 16:35   #155 (permalink)
cefiro_drifta
mad pointing munkey
thanks
in case u missed it
Old 23-04-2008, 16:44   #156 (permalink)
Jimthejunior
Represent
Jimthejunior's Avatar
Ceffy, im sure its only if you do all 6 rounds your best 5 will be counted. So if you score points in all three rounds you will be placed accordingly on the table.
I don't see why if you didn't do all 6 rounds your points wouldn't count. Never saw that mentioned.
Old 23-04-2008, 16:45   #157 (permalink)
cefiro_drifta
mad pointing munkey
sounds more reasonable than making u do at least 5 rounds just to place anywhere .... thanks jim
Old 23-04-2008, 16:50   #158 (permalink)
Captain Muppet
I think it needs to have pins - if there is a fire/issue the marshalls can get the bonnet up to sort it out without having to fumble around in the cabin by the shattered legs of the remains of the slowly roasting driver.
I've scared myself a little there.
The pins don't have to be flush, mine aren't and I have four of the buggers holding my bonnet down.
Old 23-04-2008, 17:42   #159 (permalink)
Lex
DWYB.CO.UK
Lex's Avatar
Sweep told me that bonnet pins were not a must to AM class - best buzz him to confirm
Lex is offline   Reply With Quote
Old 05-05-2008, 20:12   #160 (permalink)
fatdave
fatdave's Avatar
Hi guys i can't find the regsulations on the BDC web site. Could someone put a link up.
Cheers
fatdave is offline   Reply With Quote
