Old 30-12-2007, 22:02   #1 (permalink)
Jord
F*ck your EGO.
Jord's Avatar
Fire Extinguisher Nozzles
Exactly where have people pointed the nozzles from their plumbed in system?
I've sorted a location pointing into the driver's face , the one in the engine bay has to be at the location most likely to catch fire yarr?
On an SR20 thats usually around the turbo as the oil feeds split and pee hot oil all over the wrapped manifold and it all goes up in smoke. However didn't EDC used to specify that the nozzle had to point at the fuel side of the engine - i.e intake manifold/fuel filter/injectors?
Old 30-12-2007, 22:04   #2 (permalink)
Phil
7JZGTE
Phil's Avatar
In a two nozzle system, one goes over the drivers footwell, covering the drivers legs up to the knee, the 2nd goes over the inlet side of the engine (the fuel side). One in your face is'nt a good thing . These things can go off by accident, and being able to see while driving is pretty handy
Phil is online now   Reply With Quote
Old 30-12-2007, 22:05   #3 (permalink)
initial_j
has issues..
initial_j's Avatar
mines getting pointed in the most important area going..... my balls!
Old 30-12-2007, 22:13   #4 (permalink)
Jord
F*ck your EGO.
Jord's Avatar
Sorted Perrah!
I will lower my aim accordingly .
Old 31-12-2007, 08:41   #5 (permalink)
Mitch
Driftgarage
Mitch's Avatar
I'd always have one pointing towards the turbo area. If I had had mine aimed at the inlet side on my old 180, it may well have burnt to a crisp at Santa Pod
And a bit lower than the face, or you'll be getting a right money shot
Old 31-12-2007, 11:27   #6 (permalink)
Jord
F*ck your EGO.
Jord's Avatar
Your incident Mitch, plus the fact that my car has already had a small fire in exactly that position, make m want to position a nozzle there.
Does anyone know if you can buy the nozzles/t-piece and extra pipe seperately? I'd like to run a 3 nozzle system.
Old 31-12-2007, 11:46   #7 (permalink)
SteveC200
talent bypass
SteveC200's Avatar
You can deffo get the T piece seperately as they are just SMC fittings. http://www.smcetech.com/CC_host/page...CNN,Node_12455)) Pity you arent more local to me as Ive got loads of them in my van.
Old 31-12-2007, 12:54   #8 (permalink)
Jord
F*ck your EGO.
Jord's Avatar
Yeah I thought the T piece and hose would be easy to get hold of, just the nozzle?
Old 31-12-2007, 13:01   #9 (permalink)
cptsideways
Pimms O'clock
cptsideways's Avatar
I'd suggest the hot side of the engine on SR20's they always seem to go around the oil dipstick turbo area, oil also burns a bit better where fuel seems to get consumed up rapidly. Mines on the hot side of things on the Soarer, fuel supply is on the cold side so a leak as less likely to go up in the first place.
Aim the interior nozzle at your feet, its there incase you get trapped I suppose, which is most likely the worst case scenario
Old 02-01-2008, 01:41   #10 (permalink)
FlikstRR
FlikstRR's Avatar
can someone give me general advice of fitting the system? I'm gotta get some friends to help me with the pull cables and nossles etc... but just location wise?
i was thinkin passenger footwell, next to transmission tunnel, with the handle at the 'foot' end?.. but think i may have problems getting the cables to 'work'
FlikstRR is online now   Reply With Quote
Old 02-01-2008, 03:39   #11 (permalink)
Matt_S
SELLIN' UP!!!
Matt_S's Avatar
My Ext can is behind the drivers seat. Out the way there and less likely to get wacked by a stupid dumb blonde
Matt_S is offline   Reply With Quote
Old 02-01-2008, 09:32   #12 (permalink)
Jord
F*ck your EGO.
Jord's Avatar
I was told the pipe you get with the kit wouldn't reach to back there?
Old 02-01-2008, 13:13   #13 (permalink)
FlikstRR
FlikstRR's Avatar
yeah same here. which is why i was going for the passenger footwell. that tubing has to go to the engine bay via driver footwell from what i understand and i think you only get 2m of it.
EDIT: just offered up the fire extinguisher to passenger foot well and there is a 'brace' running verticaly over the transmission tunnel, is it ok to remove part of it? or is it vital part of the chassis etc?
I'm now warming to the rear footwell behind driver.. any one got pics of their install in an s14???
