| | #41 (permalink) |
| kind of related question, am i right in saying that harness's cant be mounted to the rear seat belt holes? so when were putting cages in we need to have a bar to mount harness's..correct? come to think of it, its not really related!doh |
| | #42 (permalink) |
| Mood=Amazing ![]() Join Date: Aug 2004 Location: West Midlands
| I'll be putting you a harness rail in, but if you wish to mount the belts to the floor you can do so but it needs to have a flange welded to the floor, i would say the standard bolt holes would only just be up to it. Clarkey. |
| | #43 (permalink) | |
| In need of practice ![]() Join Date: Oct 2004 Location: Glasgow
i run with the standard mounting holes for the last 2 seasons with no issues Last edited by kieran_e1 : 18-02-2008 at 16:34. | |
| | #49 (permalink) |
| InitialD erby ![]() | Padding isn`t silly, it stops you smashing your head open on the metal bars right next to your head. It is affordable motorsport, you try doing any other form of motorsport for the costs it takes to do BDC. People should stop winging about the cost of safety gear cause you can`t be made alive for £50 after your dead, or worse still retarded. But if your not putting cage padding in maybe you`ve already hit your head on it ![]() |
| | #52 (permalink) |
| Team Green! ![]() Join Date: Aug 2006 Location: Aylesbury
| Two meters is all im getting, regs say 30cm from drivers head right? well thats all im putting in, 2 meters is fine ![]() EDIT: no its half that so 15cm from drivers head. Last edited by Polo : 18-02-2008 at 17:20. |
| | #54 (permalink) |
| InitialD erby ![]() | If its not FIA, its not good enough. Even if its the same spec its not tested so you can`t say either way. Would you rather risk it or know your safe? Exactly paul. Remember to do the passenger side if you wanna take passengers out at any point in the event weekend if your alloud. |
| | #55 (permalink) | |
Not got two FIA seats or harness so that aint happening ![]() Last edited by Polo : 18-02-2008 at 17:26. | |
| | #58 (permalink) |
| Represent Join Date: Apr 2007
| I don't see why they wouldn't let you enter, as they don't no the state of your car when you enter over phone/internet. But im pretty damn sure you won't be allowed out on track as your car won't be upto spec. Simple math realy |
« Previous Thread
Next Thread »
. On a tight budget here
Linear Mode
