| | #1 (permalink) |
| dorifto kingu! ![]() | BDC/EDC reg roll cage padding??! sounds mad but im having a bit of a nightmare finding padding for the cage. I found one place but want to triple check before forking out. It says in the BDC rules .pdf that you need padding in the front etc... So i was gonna pop off to the local B&Q, being the tight arse i am, for some of the pipe lagging stuff.... but im informed it melts rather well ![]() can someone post me a link to a few uk outlets that stock some?? Im hoping it wont cost the earth too lol but why skimp on saftey i guess! cheers guys |
| | #8 (permalink) | |
| dorifto kingu! ![]() | Quote:
thats why i put 'no point skimping on saftey'.. but thanks for tip matt. but cant find DW link | |
| | #10 (permalink) |
| -NightWalkers- ![]() Join Date: Aug 2005 Location: S.Wales
| ill be interested in getting some of this. My views were the same as phil. ![]() EDIT : would this be suitable? Professional Motorsport Parts, Spares & Rally Equipment from Rally Design Last edited by Chris_200SX : 12-02-2008 at 08:23. |
| | #11 (permalink) |
| phil and others, just found this on the BDC regs "Please note: The above drawings are for indication purposes only and are not to scale and must be not be construed as the correct angles. Each vehicle that requires cage modifications should speak with the Technical Officer of EDC/BDC in advance of any modifications. Parts of roll cage within 150mm of occupant’s helmets must be fitted with fire resistant padding." does this mean FIA??? |
| | #17 (permalink) |
| Process Protector Roll Bar Padding | Roll Bar Padding | Demon Tweeks Motorsport, Motorcycle, Modifying, Parts and Accessories oops my bad with vat and delivery it goes to just over a tenner |
| | #20 (permalink) |
| SELLIN' UP!!! ![]() Join Date: Jul 2004 Location: NE Essex
| Demon Tweeks Motorsport, Motorcycle, Modifying, Parts and Accessories ![]() "The ultimate in roll bar padding, having a 15/8"ID offset hole and 1" thick high density padding giving you the best protection possible. Flame retardant. Length: 36"/914mm." Thats what Ive got. Its offset just like mine ![]() |
« Previous Thread
Next Thread »
yay)
Linear Mode
