Old 08-07-2008, 08:51   #21 (permalink)
Chris_200SX
-NightWalkers-
Chris_200SX's Avatar
Originally Posted by tech View Post
Bit of a pain for us possible 2009 AM's thinking we could do it super cheap, but it's Safety first and the reputation of a growing Motor sport to think about
Yep its best to get a full cage now, as if you get good enough to be in pro-am then you wont have any problems cage wise
Chris_200SX is offline   Reply With Quote
Old 08-07-2008, 09:29   #22 (permalink)
Sweeps
Sweeps's Avatar
Wink
Originally Posted by shane View Post
Would THESE be up to standard?
Can't see there being much point to be honest, they don't come with brackets to make them in to a full cage. Therefore if you ever wanted a full cage you'd be left with a half cage thats only good for show.
Better investing in a full cage and put the front half in to storage if your not a pro-am driver, or if you fit the full cage (which will stiffen your shell and make it skid better) you could always remove the door bars between events if they're a pain, its only 8 bolts after all...
Fabricage FTW yo!
Sweeps is offline   Reply With Quote
Old 08-07-2008, 12:27   #23 (permalink)
tech
Garage-Tech
tech's Avatar
Thats my plan if I go for it
anybody wanna sponser a rookie
tech is offline   Reply With Quote
Old 08-07-2008, 12:54   #24 (permalink)
jamie k
-NightWalkers-
jamie k's Avatar
Or 2?
jamie k is offline   Reply With Quote
Old 13-07-2008, 13:42   #25 (permalink)
goose
goose's Avatar
or three...
where can i get a cage for an E36 M3 coupe? cheap cheap...
Old 13-07-2008, 18:06   #26 (permalink)
cossiecrew
cossiecrew's Avatar
good call imo best get saving lol
cossiecrew is offline   Reply With Quote
Old 13-07-2008, 19:50   #27 (permalink)
cookiemonster
WOW fabricage are gunna be busy lots of work coming ur way i understand the decission after seeing pazes 86 glad ur ok btw fella, but it just seems like everytime i think my car is getting near the goal posts get moved lol o well work a bit harded save a bit more keep up the good work BDC !!
cookiemonster is offline   Reply With Quote
Old 15-07-2008, 17:55   #28 (permalink)
se4n
se4n's Avatar
Fabricage FTW yo!
Will the rear apex cage still be up to standard in amateur class though?
se4n is offline   Reply With Quote
Old 15-07-2008, 21:42   #29 (permalink)
Maximus Driftus
Maximus Driftus's Avatar
Sweeps - question for you: what about chrome-molibden cage? they are much stronger than steel so can they be thinner? 41x2main hoop?
Maximus Driftus is offline   Reply With Quote
Old 15-07-2008, 21:50   #30 (permalink)
Sweeps
Sweeps's Avatar
Sean Yes - Max no, unless the grade of metal is stated within the rules and regulations then the answer to your question is no.
There is no way of checking if the cage would be made of what a driver said, a certificate could be produced by anyone to state otherwise.
Cages must be made of the correct wall thickness as stated withing the rules.
Cheers
Old 15-07-2008, 22:27   #31 (permalink)
Maximus Driftus
bummer... gotta problem with cage then... 50 is bit to thick - needs a lot of mods... well - it has be done I guess
