Page 2 of 10 FirstFirst 1234 ... LastLast
Results 21 to 40 of 196
  1. #21
    kam
    kam is online now
    all about Clare
    Apr 2006
    6,526
    Track width.
    Just thought I'd throw that in there...
    Quote Originally Posted by nootty View Post
    Yes I am dyslexic, yes I can't spell for shit ,
    Do I care no! This is not a spelling bee. Do I give a fuck if you bet me at scramble contest , errrrr no
  2. #22
    Dec 2008
    3,731
    Quote Originally Posted by Mr Bizzle View Post
    You're all saying the same thing.
    This ffs. Painful read.
    PS13.4a Daily Drifter
  3. #23
    Feb 2006
    Somerset
    7,799
    Quote Originally Posted by FireStorm999 View Post
    Innit!
    Mitto without trying to be clever or over thinking it can you answer the op question?
    Ie will a 9j et10 wheel have the same scrub radius as a 9j et30 wheel with a 20mm spacer?
  4. #24
    May 2010
    Cumbria, UK
    914
    just some with more words and diagrams than necessary, lol
  5. #25
    Dec 2006
    933
    Quote Originally Posted by Mike@TDSW View Post
    Innit!
    if its same wheel without different concave style/design then will be same scrub radius
    JANKES ///M
    http://www.driftworks.com/forum/image.php?type=sigpic&userid=5490&dateline=1317064  372
  6. #26
    -NIGHTSPIRT FAMILY-
    Jul 2004
    - ALBION -
    11,113
    FFS. I give up.
    - RUNNING FOREVER - WE ARE ILLUSIONISTS - NETSUJYO SHOTEN -
  7. #27
    In Safe Hands
    Jun 2005
    Woodstock, Oxfordshire
    8,143
    Innit!
    As a loose rule no, because the hub offset isn't the same. Most wheel manufacturers alter the wheel's structure to change offset - not just pack the back face of the wheel with more material (what you do when you fit a spacer)
    Way too old for signatures
  8. #28
    Feb 2006
    Somerset
    7,799
    Ha come on bizzle, your first reply was yes then you've edited it.
    It's obviously not as simple as it seems.
    Your answer doesn't really explain why it doesn't equate to the same thing.
    Fwiw whilst most wheels structures alter according to offset some do just pack out the mating face of the wheel.
    Im fairly certain Rotas are one of them, for example a grid drift from et30 to et12. I've seen it on borbets, mims etc. Ie the wheel design /concavity / everything else remains constant but the back spacing alters.
  9. #29
    FRANTIC
    Apr 2005
    FAREHAM (Almost-Portsmouth-ish)
    9,541
    on the same width wheel they do, the structure (spoke design) is normally only different on different width wheels.
  10. #30
    May 2012
    826
    For this question thread the answer is yes!
    It's the same fitment! Et10 is the same as et30 with 20mm spacer. It's obvious. Just a couple people on here trying to be clever and make it complex imo
  11. #31
    Classic Ford drifter
    May 2008
    Glasgow
    763
    Totally agree. In the example in the OP it's exactly the same.
    Why do people try and overcomplicate matters?!
  12. #32
    S13+S15=S28?
    Sep 2005
    Redditch/Solihull
    4,753
    Yeah... this was made to be way more complicated than my initial post was questioning.
    I understand how offset works, obviously. I understand suspension geo also, obviously. I just have gaps in my knowledge when it comes to scrub radius - I knew the logic, but just wanted to double check. If I could increase the track width to achieve my desired result (basically to be able to fit wider wheels for wider tyres, and have clearance room on the rear face from the coilover body) then I would do that, but I'm not simply looking for spacing on my car, I need clearance.
  13. #33
    -NIGHTSPIRT FAMILY-
    Jul 2004
    - ALBION -
    11,113
    Quote Originally Posted by kevinLee View Post
    Of course it's the same fitment you plonker, nobody said otherwise... however it does not change the wheels offset, just moves the centreline of the wheel further away from the hub, altering scrub radius, akerman and various other steering and bump related things.
    Basically, don't use spacers when you don't absolutley have to, because it's a shit idea
  14. #34
    -NIGHTSPIRT FAMILY-
    Jul 2004
    - ALBION -
    11,113
    Quote Originally Posted by Ade B View Post
    because it is actually complicated. cheaper brands tend to use one mould and machine the offset to suit. More expensive brands use different moulds. Then of course you have 3pce wheels.
  15. #35
    Come at me bro
    Jun 2009
    Bracknell
    1,092
    You have the spacer on the wrong side chumley.
  16. #36
    CIH
    CIH is offline
    May 2010
    515
    Um, I'm confused. Scrub Radius is established by Camber and SAI. Offsets or spacers would reposition in the SR within the tyre contact patch but wouldn't actually make it larger or smaller. Atleast, that's how I understand it ?
  17. #37
    -NIGHTSPIRT FAMILY-
    Jul 2004
    - ALBION -
    11,113
    LOL! principal is the same.
  18. #38
    -NIGHTSPIRT FAMILY-
    Jul 2004
    - ALBION -
    11,113
    Quote Originally Posted by CIH View Post
    when the wheels are all pointing straight yes... now work out what happens on full lock.
  19. #39
    #FullAttack
    Jul 2009
    Surrey UK
    4,434
    Quote Originally Posted by mitto View Post
    So fitting low offset wheels is a shit idea too? If your saying that running a spacer would make the same fitment as a low offset wheel then your saying that low offset wheels are a shit idea, surely?
    SPONSORSHIP NEEDED
    Instagram: FullAttack
  20. #40
    kam
    kam is online now
    all about Clare
    Apr 2006
    6,526
    Spacer on the face of the wheel
    An ET10 wheel or an ET30 wheel with a 20mm spacer is exactly the same thing.
    The distance from the hub face to the centreline of the wheel will be the same for both.
    No of course it doesn't magically change the ET of the wheel, but effectively in terms of geometry its THE SAMEEEE.
    JAYSUS.
