Results 1 to 9 of 9
    Apr 2011
    Nottingham, England
    63
    E36 subframe tearing points
    Hi there
    Just wondered if any bmw experets or mechanics have any photo's or information on where the E36 tearing points are likely to be. I have heard about a lot of pre-95 models tearing the subframe mounts .
    Also just wanted to know if my 1997 R reg 328i has had the problem rectified when it was manufactured, or would i have to reinforce them myself
    Any info would be a real help guys.
    Simon
    May 2008
    Beaconsfield, Bucks
    1,443
    I'm no expert but have had these sorted on my car. They tend to tear where the subframe mounts are as you said. The problem has not been rectified, i've heard of it happening on e46s. You can buy M3 reinforcement plates that are welded, the guy that did mine said he'd never heard of a repaired one breaking.
    Also the trailing arm mounts can crack/tear/whatever on the chassis, you can get support plates for these too (also weld in). Your best bet is speak to a garage that has done a lot of these repairs
    MJG is offline
    Oct 2004
    Derby
    14,959
    If you removed the subframe and looked at where it bolted to the car you'd see the areas that tear. I cut little windows into my inner floorpan to expose the "top" of these areas in the rear bench and boot floor area and repaired my two torn ones and strengthened them along with the un-torn ones.
    If you can cut and weld, then just go for it and weld up what looks weak and shit. If not, then just rag the car until it rips the subframe off then get it welded up.
    When in doubt - clutch kick.
  4. #4
    #FullAttack
    Jul 2009
    Surrey UK
    4,449
    This job has got CUNT written all over it... My friend and I got the plate kit for his e36 when 3 of 4 mounts were torn.
    Subframe out > lots of prep > lots of welding > primer + paint > refit subframe...
    SPONSORSHIP NEEDED
    Instagram: FullAttack
  5. #5
    MJG is offline
    Oct 2004
    Derby
    14,959
    Mine was - sit in boot or back seat, cut H section into floor, fold out the flaps to reveal broken bits, jack subframe into right position, re-weld, then reinforce with more sheet metal and bird shit. Job done, solid as a rock
  6. #6
    Oct 2008
    Nantwich or Doncaster
    1,869
    Just go but the M3 reinforcement plates from BMW for pretty cheap and weld them on to the body with the subframe out.
    Brad =)
  7. #7
    Jul 2009
    23
    Quote Originally Posted by MJG View Post
    That's my take on it.
    325's would do it a lot, 328's wouldn't, although I do know someone who managed it.
    He was the kind of guy that could scratch a diamond if you let him hold it.
    Most likely you'll be fine, so you can probably just forget about it until the very rare chance it does rip, and then fix if needed.
  8. #8
    Apr 2011
    Nottingham, England
    63
    Cheers for the information guys realy helps me . I can now get under the damn thing and have a good look at it all. iam just trying to get it as stiff as possible. Not good when your working on a budget
    Just wanted to be sure for peice of mind when skidding at 40+ mph
    Cheers again guys
    Simon
  9. #9
    Jun 2008
    251
    I've done two of these, one e36 and one e46 and it's never fun... You can cut the rear out from inside but I deemed this too fiddly and I saw it as an excuse to poly my rear subframe. I am the friend dale refers to and we fucking hated this job... Also, don't do it on a deadline otherwise you end up skidding round Essex arena with 6 litres of energy drink in you having been awake for 30 hours... And driving back to Brighton at 30mph because you can't see the road where your eyes are so blurry. Good fun though...
