Results 1 to 10 of 10
    May 2005
    Cork, Ireland.
    4,640
    Question for people with solid bushed diff and subframe, noise question.
    Right basically I have now fitted a S14 subframe to the back of my R32, I have used solid offset subframe risers to do this. The diff is also solidly mounted.
    I am getting quite a bit of noise from what sounds like the diff, but I have had a few different diffs in it and it always seems the same.
    Thing is previously I had the R32 rear subframe in it which was solidly mounted (but without the subframe risers) and I remember it being fine?
    So my question is has anyone else experienced this on the road? Is it normal to hear alot of noise from the diff or do I need to be looking for something else that might be making the noise?
    Check out my R32 adventure
    R32 LIFE
    http://www.facebook.com/R32Life
    Jan 2010
    Waterlooville
    232
    My solid mounted s14 is noisy due to the it being amplified through the car. Hope this helps.
    A £10er in the tank aint worth a wank!!!
    .MTM.
    Jun 2005
    round a bend
    6,691
    solid mounted everything=mega diff noise.
  4. #4
    May 2005
    Cork, Ireland.
    4,640
    Quote Originally Posted by gaz_moose View Post
    Really? That will probably be it then.
    Just weird that I never noticed it with the Solidly mounted R32 subframe before?
    R32 LIFE
  5. #5
    .MTM.
    Jun 2005
    round a bend
    6,691
    maybe your older diffs were a bit less tired than your new one.
  6. #6
    May 2005
    Cork, Ireland.
    4,640
    My new diff is supposed to be rebuilt! haha
    R32 LIFE
  7. #7
    May 2012
    850
    Same for me too!
    Isn't this the first time you have had it on the road with no interior?
  8. #8
    Jan 2011
    Aberdeen
    946
    Solid everything is awesome! the diff noise once warm is savage on the motorway without my back seats but not to bad with them in.
    every time I hear it I think - dam, that's fucking gangster and puts a massive grin on my face
  9. #9
    May 2005
    Cork, Ireland.
    4,640
    Quote Originally Posted by kevinLee View Post
    Same for me too!
    The only difference to the way it was before is I have no carpet. But I don't think that would make much difference.......
    Quote Originally Posted by Jites View Post
    I might try and wedge my back seat back in then, cage kinda gets in the way. I don't feel too gangster with an annoying whirring noise behind be the whole journey.
    R32 LIFE
  10. #10
    MJG is offline
    Oct 2004
    Derby
    14,978
    If you've removed the carpet then yes it'll change the noise. The carpet won't stop much noise by way of insulation, but it stops the floorpan vibrating and transferring the noises.
    Yes, solid mounts make everything sound broken and loud. When you can hear diff backlash, feel the gears physically binding together in the box, and feel the engine's growl through the accelerator pedal you know you're doing something right.
    Jites - Exactly how I feel haha, "shit dawg, I'm a G right now with all these whinings and tings".
    When in doubt - clutch kick.
