Hi! I have euro s14 and i need new rear subframe bushings. Which ones i should buy? Do i cut the metal ring out or not? I also need new suspension. Is BC Racing BR good? What adjustable arms i should buy?
Check out Driftworks website tells you how to fit the bushes etc and they do bushes and adjustable Sent from my iPhone using Tapatalk
I fitted energy suspension bushings to my subframe, diff and hubs and used Kaber Performance rear adj. arms, wasn't cheap but after a good set up the car handles a million times better and doesn't bang/creak/crash etc. With most subframe bushings yes you have to remove the metal collars from the old ones but one or two brands make you leave the old ones in so don't remove them till you've decided what brand your going with.
