Old 14-08-2006, 17:12   #281 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
well in what seems to be my continued battle with keeping it cool, im gonna chop the bumper up and redo it.
moving the HKS oil cooler from between the intercooler/radiator, and moving the mocal power steering cooler
opening the "mouth" a little on the upper grill....
will start over the winter.........just toying with ideas, this bumper i made a couple of years ago.......and its starting to show a few scars
new bumper 07
Current design
Larger grill opening, and larger side vents, large enough for the oil coolers
its all to do with cooling now ..............
Old 14-08-2006, 17:54   #282 (permalink)
rad_brad
K1 king
rad_brad's Avatar
Send a message via MSN to rad_brad
even tho i love the bumper as it is at the minute, id have to go with the second one
rad_brad is offline   Reply With Quote
Old 14-08-2006, 18:27   #283 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
the Bumper has been its "Face" for the past few years, and definatly what has definatly been a talking point.....Marmite bumper.
but its picking up damage, and always one for changing things, ill make some repairs and while im at it change the look......always evolving
Old 14-08-2006, 18:55   #284 (permalink)
rad_brad
K1 king
rad_brad's Avatar
well giving it a chunkier front bumper would certainly change the sharp kind of look that the current bumper gives it
Old 14-08-2006, 18:57   #285 (permalink)
drax
GFX / Web Dude
drax's Avatar
Send a message via MSN to drax Send a message via Yahoo to drax
Maybe raise the bonnet towards the rear to let the heat pass up through it also?
drax is offline   Reply With Quote
Old 14-08-2006, 18:58   #286 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
i have plans afoot to allow air out of the engine bay......all part of the winter re-build
tis actually bullshit raising the bonnet, as it doesnt help heat escape as the base of the windscreen is a High pressure area
Old 14-08-2006, 19:03   #287 (permalink)
rad_brad
K1 king
rad_brad's Avatar
didn't you have bonnet vent on there? or are/were they just for show?
Old 14-08-2006, 19:16   #288 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
the vent is very effective yep, and thats staying on
Old 14-08-2006, 19:25   #289 (permalink)
rad_brad
K1 king
rad_brad's Avatar
im glad 2 hear it
coz see it in sum pics and not in other, but i like it very much
Old 14-08-2006, 21:01   #290 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
also need to do some digging around as over thr winter aswell as some major work i want to change all the rear end to fully adjustable
one of these will work im sure.....
and as far as the lower arm is concerned......this is a proven modification ive found, but im sure i can get something better rustled up......(note inner end of lower arm..)
but this time the winter re-build will be finished...lol
Old 15-08-2006, 10:54   #291 (permalink)
oli
-nightspirit-
oli's Avatar
similar to the dangerstyle mods the nobhunters jay/paz and kenneth has done
oli is offline   Reply With Quote
Old 15-08-2006, 11:13   #292 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
im actually looking at doing something silmiler to the above mod, but by adding a bearing at each end
just looking at how i can modify the upper wishbone to work with a spherical bearing
Old 15-08-2006, 11:59   #293 (permalink)
oli
-nightspirit-
oli's Avatar
was looking at some battle version stuff and some of them iir are adjustable while still on the car...looking at the lock nuts they wouldn't be adjustable while on the car would they?
Old 15-08-2006, 12:16   #294 (permalink)
sideways.taff
-NightWalkers-
sideways.taff's Avatar
Well it can't be anyway can it surely as theres a shock mount right in the middle. Usually the ones that are adjustable whilst in place have on right hand thread rose joint and one left hand thread.
Old 15-08-2006, 12:33   #295 (permalink)
oli
-nightspirit-
oli's Avatar
thats what i was thinking, adjustable ends
Old 15-08-2006, 13:14   #296 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
yes they would be adjustable, the outer locknuts are easily accessable the inner ones are accessable through the top of the U form that the lower arm is formed from
the threaded part of the bearing, would sit in a tight tolerance tube, loosen of the locknut, and wind in/out on the other nut to gain or lessen the lenth, then tighten up the opposit locknut
you would be locking the threaded part to the boss/tube that the threads run through
the inner bearing is screwed and locked in a threaded boss, the inner bearing doesnt need to be adjusted as if it was, its adjustment would effect the geometry of the shock absorber
Old 15-08-2006, 13:58   #297 (permalink)
Lex
DWYB.CO.UK
Lex's Avatar
adjustable shmustable
have you noticed better throttle response and cooler running temps since you applied your GT Battle stickers
Lex is offline   Reply With Quote
Old 15-08-2006, 14:02   #298 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
definatly......hmm maybe theres something in this sticker melarky, frick mechanicals, decals are the way to go
i need adjustable shmustable though .....all my tyres a dead on the inside, but brand new on the outside......
and falkens are poop....delaminating after 2 mins
Old 15-08-2006, 17:52   #299 (permalink)
rad_brad
K1 king
rad_brad's Avatar
just gotta turn the tyres the other way round then, last twice as long then. so bout 4 minutes
Old 25-08-2006, 19:50   #300 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
well not had chance to do much lately, other than actually use the car....
so now things are quieting down , thought id pull my finger out and get some bits done.
today i removed all the fuel system that was almost installed completely in the Blue car and have relocated it in the White car.
Jesus, making up the goodridge unions is a pain in the ass, but, ......it gets quicker each time
so i got most of it in today..
need to make up the ally box for the fuel cell, and then route the lines for the fuel to the engine, and the return from the FPR, the car currently runs a HKS FPR but that will be changed to a Aeromotive one
