Old 20-10-2005, 00:20   #21 (permalink)
BenR
Send a message via MSN to BenR
Yes, but it is the camshaft BCD and lifter shim surface area i'm interested in.
Originally Posted by DriftLexus
ben, there is only one generation for the altezza,(sxe-10) the black top the red top is the dual vvti as fitted to the last generation mr2, the only other version i know is the type fitted to the caldina.
as for getting you the head, thats not a problem.....i will be stripping it soon, to start the prep for the install of the 2.2 stroker parts
the other generations are all the iron block 3s-ge, and gte as fitted to mr2 ,celica and avensis...plus other models
however the Altezza and Caldina are the only cars fitted with the alloy blocks,
the altezza also has the Yamaha developed head, with the titanium valves
BenR is offline   Reply With Quote
Old 20-10-2005, 09:27   #22 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
the control is by oil pressure and electronic, HKS do do a controler for the VVT called valcon, but id be happier to have it removed......or controled fully, its a infinatly varible cam, so not like vtec which is switched on/off
to disable it, is a simple case of fitting a head gasket that blocks the oil drilling in the block
If the VVT is disabled mechanically (head gasket) then it can't be re-enabled without pulling the head, so its worth us looking to see if we can't find a way of doing it another way so that its fully controllable at a later stage. Its worth a few hours investigation with the head, a car battery and a VEMS
Old 20-10-2005, 17:25   #23 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
so we wish to go with keeping the vvti.....i shall order a "normal" headgasket then.
i have the option of these 2 turbos, but have to decide quick which one.....
HKS GT2540R good for 370hp, and also a GT2835 good for around 400hp
both have internal wastegates, its obviously not a case well one is able to run more hp, which is prolly better for this application, the gt2835 is the more modern of the 2 , the 2540r is now discontinued by HKS
Old 20-10-2005, 17:32   #24 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
Hold off on ordering the Head Gasket 'till we've got the head at Bens and I've had a look at it.
Rob
Old 20-10-2005, 17:39   #25 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
Rob
ah ok.....
i will remove the head this weekend.......
either of you coming to the matchams practice?
Old 20-10-2005, 17:41   #26 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
ah ok.....
No I'll be going to bed this weekend after a piss horrible week at work and not getting out until the next piss horrible week starts.
Rob
Old 20-10-2005, 17:44   #27 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
Rob
excellent.....matchams is next weekend
was thinking of passing the head over, unless there is someone coming from over that way who could pass it on.
Old 20-10-2005, 17:48   #28 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
Which will be the weekend before the delivery date, so I may be working it
Surely you'd be best to bring the bits over in one go when you bring the shell for its cage fitting? Then we can impress you with our charm and banter
Rob
Old 20-10-2005, 17:59   #29 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
hmm true..gotta experiance the banter....better be a good pub near you but
i just thought it would give you time to prod and look over the vvti set up,
regarding the cage we need to see what direction these D1 regulations are gonna go!
need Ben to let me know on the 2 turbos.......
HKS GT2540R good for 370hp, or a GT2835 good for around 400hp
suppose i want to know which he thinks is better for power delivery
saying that i have 2 GT2835's on my other car and they spool up from pretty low down
Old 20-10-2005, 20:45   #30 (permalink)
BenR
pubs round here are for local people only...............lol
Old 20-10-2005, 21:30   #31 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
suppose i want to know which is better for power delivery
Ben ?
Old 20-10-2005, 23:02   #32 (permalink)
BenR
if your going 2.2 i'd go with the GT28, if you design everything properly to work as a system then you will have no problem spooling, or even making power on very little boost.
However, i'm not a fan of toda stuff, and always opt for something else better, and in most cases cheaper.
Old 21-10-2005, 12:50   #33 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
im getting the TODA pistons and crank cheap enough, $2000,(direct from japan) the Eagle Rods cost £500
Ben ive sent rob the compressor and turbine maps for the 2 possible turbos, maybe you will wanna have a quick look......i need to decide which im gonna run with in the next 24 hrs
there are 2 gt2835.
one with internal wastgate, other requires an external.....
2835
0.73AR /56 T
T3 flange
external wastgate required
will Bolt on RB20det / RB25det so that gives idea of use
2835
52T
T25 flange
internal wastegate
will bolt on SR20det / CA18det , S13 S14 S15 180sx RNN14
Old 22-10-2005, 14:25   #34 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
got the turbo......
a nice GT2835, should be here in a couple of weeks...now, what else do i need
Old 22-10-2005, 15:07   #35 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
An external wastegate for starters, have you seen the manifolds that Full-Race do for Toyotas? I dont know much about the dimentions of the ports etc so they may not fit your engine:
http://www.full-race.com/catalog/pro...roducts_id=314
Old 22-10-2005, 19:34   #36 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
erm, nope not external wastegate, the picture was the other for sale....posted by accident
there is no room for external wastegates, and i only found one manifold in japan that would fit, with external.
internal will save a bit on instalation headaches, fitting a 2835 will be bad enough as it is.
the 3s-gte manifolds do not fit the sxe-10 altezza
Old 22-10-2005, 19:51   #37 (permalink)
Joe
Toyota's best-Ae86-Jza80
Send a message via MSN to Joe
Look up Tom's Racing in Japan.They do a T280 Altezza,which is the Beams engine turbochaged.These are 280bhp stock.
There might be some info there that might help your build.
www.tomsracing.co.jp/e
Joe is offline   Reply With Quote
Old 22-10-2005, 20:02   #38 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
thanks.
i know the TOMS cars very well.......good as they are, there not quite in the same dimension...
if you can ever get one in good nick though there worth keeping in storage as there worth a few bob now
Old 24-10-2005, 19:08   #39 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
ok...im looking at injectors,....
which size would best suit the application....and can you recomend a GOOD fuel pressure regulator
Old 24-10-2005, 21:30   #40 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
RC injectors seem to be popular in the US with the Honda tuners.
They provide an injector sizing page here.
http://www.rceng.com/technical.htm
Prices are here
http://www.rceng.com/prices.htm
