Old 24-10-2005, 22:36   #41 (permalink)
BenR
Send a message via MSN to BenR
wouldnt be bothered by FPR's, just size the injectors properly and all is fine.
BenR is offline   Reply With Quote
Old 24-10-2005, 23:25   #42 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
problem with the car at the mo, theres no fuel return, i will be running a fuel cell...swirl/surge tank, ive worked out the requirements that end of it, i.e pumps etc etc
these are the things though i need to get sorted before the car comes over your way
Old 24-10-2005, 23:41   #43 (permalink)
BenR
any FPR is fine, so long as we know the change with vacuum/boost.
Old 25-10-2005, 22:37   #44 (permalink)
Tom_R
Newbie question: Does a wastegate blow off excess boost pressure?
Tom_R is offline   Reply With Quote
Old 25-10-2005, 22:41   #45 (permalink)
ant
R32 GTR-S
ant's Avatar
Send a message via ICQ to ant
no it vents the exhaust gas before it gets to the turbo so the turbo makes a certain amount of boost
ant is offline   Reply With Quote
Old 01-11-2005, 21:42   #46 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
the aeromotive one im looking at (FPR) has a 1:1 raising rate
regarding low pressure and high pressure pumps, i need to work out rough requirements.
originally i was going with a low pressure facet red top " works" pump (35 gallon per hour-159 litres per hour @ 6.5-7.2 psi -0.44bar) this was going to feed a 1.5 litre swirl pot then a sytec high pressure pump (34.31 gallons per hour-156 litres per hour @43 psi - 3 bar) would feed the fuel rail
however.......
i read the facet pump is only good to feed for 200hp, im aiming for 400-450
so my Q to the experts is......are the figures above upto running a 2.2 4 cylinder or should i look at something with a little more flow.
i am looking at aeromotive stuff and they have some serious high flow high pressure pumps.....but nothing to feed a swirl pot.
could 2 Facets be used to flow the required amount?, and then use 1 high flow high pressure pump to feed the rail, if so what sort of flow @ what pressure am i needing to find
Old 01-11-2005, 22:05   #47 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
A Walbro 255 pump would provide enough fuel at the right pressure for (IIRC) 500bhp.
After that its a job for the Bosch motorsport pump.
Rob
Old 01-11-2005, 23:11   #48 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
i was looking at the walbro stuff, but at the mo its the numbers im looking at, if......if i can get all my componenets from Aeromotive i can get a decent saving
the walbros are in tank units, i have a fuel cell so the pumps need to be external, as a fuel swirl pot is also used, the swirl pot needs supplying by low pressure pump, and then the feed to the rail needs to be done with high pressure
Old 01-11-2005, 23:29   #49 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
Now you're bringing in new specifications!
I used gravity feed for the swirl pot install on my off roader, I guess two Facet pumps in parallel would provide the required flow, but those Facet pumps were really only ever for weber carbed things and belong back in the 20th Century. What do aeromotive suggest for your fuel option?
Rob
Old 01-11-2005, 23:33   #50 (permalink)
BenR
a low pressure high volume pump to the swirl pot, then the normal high pressure pump to the rail, and a return to pot and tank.
all you need
Old 02-11-2005, 09:10   #51 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
You're not going to be needing 400bhp worth of flow at all times, a large swirl pot will act as an accumulator and with the flow from the low pressure pump and return line it will have enough fuel for the requirement peaks.
Old 02-11-2005, 17:36   #52 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
all you need
thats the question, which low pressure high volume pump, i cant seem to find any
regarding High pressure pumps other than the sytec one i listed above the Aeromotive one im looking at is good for 700hp and flows fuel at max over 450lbs an hour at 45psi and thats not there highest output pump
the aeromotive systems that you can purchase complete dont facilitate the use of a swirl pot, id like to have one due to the fact i will only be using a small 20 litre max fuel cell,
in reality i suppose if i have an idea of fuel flow requirements at what psi then i can go hunt for the correct parts, thats why u guys are the engine builders ...as im hoping you will have ball park figures that i can use
Old 02-11-2005, 21:22   #53 (permalink)
BenR
plenty of facet pumps around.
As for injecotr sizing, a complete engine spec is needed and bhp area to judge the best injectors to use.
Old 02-11-2005, 22:15   #54 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
so it comes back to the facet, pump i originally said or 2 in parallel as Rob said
what do you need to know on spec.....or Hp aims that i havnt already said, only thing that hasnt been decided is whats happeneing with the head, because i dont know what is being thought, i was going to remove it 2 weeks ago and get it down to Rob so he could look at the cams. but he told me not to..
as i have said the engine will be running
2.2 low compression pistons and crank
eagle rods
HKS GT2835, internal wastegate
circa 400hp
...nothing has been decided on the headgasket, becuase rob needs to look if he can work with the vvti...for his VEMS......however, before the car comes to rob or yourself ben there are things that need doing, and one of those is the fuel system.
this is why i am asking for those that know these things to be a little more open in the info, so it can be completed correctly.
not wanting to sound ungratefull but the topic so far regarding the fuel system has gone round in circles
i thought by bringing the topic out into the open as i was asked, that the infomation would help others, make the decission about how far to go with builds, and either encourage or show the work involved
the hope is to actually do the rebuild with some form or forethough and planning, and not let the car be idle for months, or keep dragging it around the country
the car is starting to be stripped this weekend, then its being shot blasted.....then hopefully the new cage will be fitted before the new paint is applied.
then the block needs to go in and the fuel system plumbed in.............along with all the basic loom, dash brakes etc etc
so ben, if there is specific info you need to give me the best possible idea of what im going to look for and buy next please ask away, as i thought thats why i was asked to start this topic.
i hope the post doesnt sound to bad...its not ment to.
cheers
mat
Old 02-11-2005, 22:25   #55 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
regarding injectors ive been told that 700cc injectors, will cut the mustard just fine with that turbo and engine capacity, for the HP hoped for, and that the std fuel rail is upto the job in hand, although i am looking for bigger capacity fuel rails, strangley enough Aeromotive do a blank rail, that just needs machining to requirements
im getting the aeromotive FPR and Filters
Old 02-11-2005, 22:30   #56 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
so it comes back to the facet, pump i originally said or 2 in series as Rob said
Parallel
Closed loop fuel system
Might be an idea to shot blast after the cage is fitted, have you a rough date for when you'll be bringing it up, like I said the cage fabricator, Ben and I are all a few miles apart so it might be an idea to bring all the bits that need bringing and heading to the public house to discuss an action plan.
Rob
Old 02-11-2005, 22:33   #57 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
Mat, what bore size is the engine you're putting in?
Rob
Old 02-11-2005, 22:46   #58 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
rob the shot blasting has to happen before the cage goes in, as the cage in at the mo will be moved to another car in York...and at the same time i can rough plate any un-needed openeing before the cage is welded in.....this also gives the cage fabricator clean toyota metal to work with .
then it can be brought down to you once im happy that the stuff required to be done is done.......i mean i have no issues with re-collecting the car after the cage is fitted to get more done my end before returning it to you or Ben to get the next stage done.......
the std 3s-ge.................................. bore and stroke is 86 x 86mm @1998cc
with 2,2 low compression.................. bore and stroke is 87 x 93mm @ 2211cc (compression 8:8:1) with std thickness headgasket, normal uptrated ones are .5 thick
Old 02-11-2005, 22:50   #59 (permalink)
BenR
i was gonna say 600cc injectors, still leaving scope for safety margins.
However, this totally depends on how good your engine builder is and how it is mapped to keep bsfc as low as possible.
Old 03-11-2005, 22:03   #60 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
i was on the understanding Ben....you was doing the engine
