24-01-2006, 10:54
| #101 (permalink) |
| BDC ![]() Join Date: Feb 2005 Location: Germany....Now!
| well a couple more bits have arrived over the past week.... new back box 4"outlet 3" inlet ![]() Aeromotive fuel pressure regulator ![]() turbo heat shield ( a bit of bling )![]() First bits of the fuel system.......Much more to go ![]() Aeromotive Fuel pump ![]() And the Cobra Mustang 4.6 litre throttle body......i knew it was gonna be big, i wanted big for Flow, but this thing is gonna be a struggle to fit ![]() twin 60mm butterfly plates.....they shouldnt cause any restriction ![]() ![]() ![]() These pics of the Throttle body are almost to scale, give or take a few mm..... |
27-01-2006, 23:49
| #107 (permalink) |
| A big Thanks to Mitch for allowing me the use of his arch roller today.... i dragged the car upt Bicestershire, and decided brutal was the only way..... it actual turned out supprisingly well considering the lips are really thick, and with it being a 4 door...problems sometimes arise at the front of the arch...... A little bit of this... ![]() and a little bit of that.. ![]() Before... ![]() after.... ![]() and a few general shots.......Cheers Mitch ![]() ![]() ![]() |
11-02-2006, 20:43
| #111 (permalink) |
| thought i would make a start on piecing together the fuel system components. must thank James/Phil for the Excellent assistance in getting good prices on the Unions Ive now fully assembled the Fuel cell, fitted the return line union, and the fuel level sender. ![]() I then made up an Aluminium mounting plate, that i have mounted the Primary pumps, the main pump and filter, plus the swirl pot, this will allow me to remove the whole lot for servicing. ![]() and did some minor jobs, like fitting the cell retaining straps...below is an overall shot of the boot area. ![]() just waiting for a few more unions and bits and bobs, and fuel hose then i can start making up the fuel hoses, but then that will pretty much be the system done, less the running of the lines forward, and the return line back from the engine, Tommorow the windscreen and the rear glass is coming out in preperation, for the removal of the TRD cage, and the fitting of the new weld in cage |
12-02-2006, 13:31
| #117 (permalink) |
| Bamalam | Well frick me! The money and work thats gone into this is crazy! I know i spent a shit load on my'86 but not quite to this extent! ![]() How on earth can you afford it especially with a family too! (must have a good job)I cant wait to see this thing all up and running, its gonna be a bad bitch! lol As i see your from Wiltshire, does this mean it will be seeing any Castle Combe action?? ![]() Keep up the good work dude, and always keep us updated, its a refreshing change to all of the s body scum! haha |
12-02-2006, 15:45
| #119 (permalink) | |
| -nightspirit- Join Date: Jul 2004 Location: swindon
12-02-2006, 17:17
| #120 (permalink) | |
cheers, peeps, Ian i ended up getting the unions from DW prices are very competative ![]() well glass is out.........and its pissing it down....fan-bloody-tastic ![]() | |
