19-02-2006, 00:13
| #121 (permalink) |
| BDC ![]() Join Date: Feb 2005 Location: Germany....Now!
| Thanks to Oli and tony who have been down and give me a helping hand over the weekend, sometimes 2 minds are just better than one........especially at 02:30am....eh, oli anyway...update Removed the TRD cage, this has been sold to Lexus boy....what a pain in the ass it was, id obviously put it in far to well. Removed the 4" thick wierd rubber sound insulation crap from the rear wheel arches........i found in the end it was easier to set fire to it...and let it burn its way around ![]() Once it was all off......a layer of paint ![]() and the boot area ![]() removed the rear subframe, in preperation of fitting the Kaaz 2 way and doing some structural work on the subframe itself...... ![]() Made up the mounts and the brackets for the Tilton pedal box.....another truely arse job, ..... ![]() ![]() as a result of where the pedal box sits ive had to move the seating further back, this will have a possitive effect on the "feel" of the car, it also allowed me to mount the seat lower, theres still room to fabricate the cage around the seat....still some welding and required![]() |
19-02-2006, 12:39
| #122 (permalink) |
| -NightWalkers- | Hehehe, I've got the exact same steering wheel on order at the moment.. Coming direct from Italy in a week or so! ![]() I'm surprised to see how much stuff you've left on and around the steering column. My column is just an outer tube and the inner column now and it'll be mounted direct to a dash bar in the cage. Theres a lot of heavy duty stuff going on there...I guess you don't want anything to break lol ![]() Nice work with the wheel arches and boot floor. Doesn't it look a hell of a lot better with a coat of paint rather than the gunky mess that's there as standard. I'm liking the grey too but its just not quite bling enough for my tastes ![]() |
19-02-2006, 14:22
| #123 (permalink) |
| InitialD erby ![]() | That car is gonna be awesome when its done I love the fuel system, its looks great to! How much do you think a system like that would set you back all in? (if you don` mind me asking!) Thats gotta be one of the highest spec dori cars in the uk, top stuff ![]() |
19-02-2006, 14:36
| #124 (permalink) |
| touge runner Join Date: Oct 2005 Location: london
| Matt I saw your car at Matchams last year and it had some trick parts fitted then. You must be in search of perfection, it takes a brave sole to strip down a perfectly good car(pimpin car) with the plan of re-building it to a far higher standard The work involved and planning has been top class, hope it all comes together for you,Can't wait to see it this year.. Well done ![]() |
19-02-2006, 15:47
| #125 (permalink) | |
| -nightspirit- Join Date: Jul 2004 Location: swindon
mats workshop with overhead heating and shed loads of room and facility for old oil.... welder and big frickoff jacks...oh yeah and tanks burning stuff is cool.... looks like a flamey lizard climbing up in this one you mean when you decided to test the fire extinguisher out it worked and free plug: glad you got it all painted up too....those pedals looked a bastard! ps who got my clips? | |
19-02-2006, 19:10
| #126 (permalink) |
| Tony has your clip..tuther is broken. well the pedals were a pain. the reason i kept most of the steering column gadgetry is i wanted to keep the tilt adjust, it seemed easier to keep the remaining part of the dash bar, and build of that than manufacture all new brackets....and in the case of the pedal box and seat mounts...industrial size is deffo better ![]() dont want any of that shit breaking! |
19-02-2006, 19:36
| #127 (permalink) | |
Fuel cell...............................£378 Fuel cell top plate..................£170 fuel level sender....................£112 fuel level gauge.....................£45 Primary pumps......................£78 x2 primary filters.......................£10 (not yet fitted) x2 Check valve.........................£10 (not yet fitted) x2 main pump...........................£320 main filter............................£43 swirl pot..............................£135 -6 fuel hose.........................£170 -8 fuel hose.........................£22 Fuel pressure regulator..........£130 Fuel unions..........................£150 total..................................£1871 approx | |
21-02-2006, 12:56
| #129 (permalink) |
| ah.........at last, a package from japan Hmm, dont remember ordering anything from Rays.... ![]() OHHHHHHHhhhhhhhh, its not my complete order, but nice shizzle all the same EL Sport Aluminium differential mounts ![]() BORIS FACTORY final drive gear pinion (5.125) ![]() HKS Oil Cooler Kit ![]() im still waiting for the TRUST oil pan, TRD engine mounts and Ogura clutch and Ultralight flywheel....... |
26-02-2006, 00:12
| #130 (permalink) |
| the Fuel pressure guage turned up today...... ![]() Started the stripdown of the subframe,to bolter some of the brackets and mounts...also to strip the diff in preperation of the Kaaz 2 way and boris factory pinion gear ![]() and stripped...... ![]() stripped the old paint out of the engine bay, and gave it a new lick of paint.. ![]() |
26-02-2006, 14:49
| #135 (permalink) | |
| dorifto kingu! ![]() | Quote:
nope its HKS quality m8 :-) no drips where you fit it to the engine, not on the relocation kit, and also not on the cooler. everything is clean | |
26-02-2006, 21:31
| #136 (permalink) | |
![]() plus it makes the process of seam welding then painting a whole lot simpler ![]() The HKS cooler that i have doesnt have a filter re-location kit as part of it. There is no requirement, the filter for the Altezza is easy to get to as it is Last edited by DriftLexus : 26-02-2006 at 21:33. | |
26-02-2006, 21:35
| #137 (permalink) | |
today i made up the bracket to mount the fluid pots for the brakes and clutch, also started the modifications to the dash tried to work out where to put the Fuel Pressure Regulator....so much room ![]() | |
28-02-2006, 19:35
| #140 (permalink) |
| well today fitted the bracket, to mount the 3 oil pots (brakes and clutch) ![]() also trimmed down the dash and had a go at mounting the Tacho, fuel pressure and fuel guage ![]() ![]() also test fitted the HKS oil cooler, as i knew some modifications would be needed, im also going to be using my own welded brackets opposed to the HKS bolted brackets which are pretty minimal ![]() |
