Ive had this a while and you may have already seen pictures of it on here.
The car was originaly running cosworth running gear and I bought it as a rolling shell from somone on here who runs mallory park drift school.
The car is in pretty good condition considering its 26 years old however some of the previous work thats been done is good and some is poor so Im rectifying the bad bits along the way.
The body is basically a full george polly rod spec:
<p>
<p>
<p>
The suspension is bassicaly all ford escort:
Mk 2 grp4 bilstein coilovers
4 linked 2.8 capri Atlas axle with LSD
2.8 capri rear drums and front discs
Escort rack
Im changing the front calipers to AP 4 pots and the rear to Cosworth calipers and non vented discs which will still fit under the 13" wheels.
I will be adding a Mk2 escort rack because its standard ratio at the moment and adjustable TCA's.
I also need to get hold of some MK2 Escort rear 2 1/4" rear coilovers.
On the shell the gearbox tunnel had been modified to take a type 9 box and was like a patch work quilt Ive now cut this all out and bought a MK2 GRP4 tunnel to go in.
The passanger side front foot well and inner sill has also had a jubious repair so this is also being cut out and replaced.
The spare wheel has also been previously removed to make way for the under floor alloy racing tank.
Were the boot floor has been filled in were the wheel well was also needs re-doing because Im not happy with it.
(I will take some pictures and load them up)
The running gear is 4AGE 16V on 45's running EDIS and megajolt ignition the box is from a AE86 (if anyone knows the model no for the box let me know)
<p>
<p>
Fitting the engine in required some sump modification because the car is running Escort suspension and front anti-roll bar which runs forward of the cross member rather than backwards making it very tight with the sump.
<p>
<p>
I have also had the dash Flocked by Marc Dixon on here whos doing Flocking for swaps looks really good.
<p>
I have 95% of what I need to get the car built just time now but I do need some ford fitting 4x112 wheels between 8 and 10x13 so hit me up if you have any.
Thats it for now updates will follow cheers.
LinkBack URL
About LinkBacks
<p>
<p>
<p>
<p>
<p>
<p>
<p>
<p>
