My S14
Thread in 'Project Cars and Builds Threads' started by cattojdm, Sep 17, 2011.
  1. cattojdm
    cattojdm Member
    After a few years of owning Hondas, I decided it was time for my first RWD car. I bought a zenki S14 that didnt run properly a few months ago, fixed it (Was a boost leak :smash:) and fitted a few parts. This is how it stands currently.....
    Engine:
    SR20DET
    S15 WMIC
    Stainless Tubular Manifold
    Stainless Turbo Elbow W/screamer
    Japspeed Downpipe
    Japspeed De-cat
    Japspeed Cat Back
    Walbro Fuel Pump
    SARD Trigger Boost Controller @ 15psi
    Blitz Air Filter
    Horsham Developments Stage 1 ECU
    ARC Radiator Cap
    Drivetrain:
    Exedy Stage 2 Clutch
    Auto Welded Diff
    Chassis:
    HSD HR Coilovers
    18" 350z Alloys 245/40/18 on rear, 225/40/18 on front
    16" Super Advan SA3R used for drifting
    Braking:
    Apex 310mm Front Big Brake Kit
    Z32 Alloy Front Calipers
    Ferodo DS2500 Brake Pads on front
    ABS Delete
    Goodridge Braided Front Brake Hoses
    Dot 5.1 Brake Fluid
    Other:
    Spin Turn Drift Button
    Greddy Turbo Timer
    The plan is to learn how to drift, Im not very good at it at the moment lol however I only fitted the diff today......
    #1 cattojdm, Sep 17, 2011
  2. gibbo s14
    gibbo s14 the yarco
    lil tip the turbo elbow with the screamers dnt seal of how they should and leak like mad and sound like a gasket has blown swap it before the turbo goes mate ,looks like a gd base car. have fun and welcome to driftworks
    kyle
  3. smokindrifter
    smokindrifter Member
    With 245's on the back your are gona stuggle with the poxy S14 standard brakes locking up on the handbrake !!!
    I think your next job is a upgrade these.
    Good skidding bud
  4. cattojdm
    cattojdm Member
    Yeh the divider between the wastegate and turbine wheel does leak exhaust gases out of the screamer, sounds shit off boost.....but how will this cause the turbo to go?
  5. cattojdm
    cattojdm Member
    I will use my 16s with smaller tyres for skidding :) Thanks for the advice though :)
  6. Rhys_sx
    Rhys_sx -NightWalkers-
    u from south wales by any chance shore i seen this car about
  7. decobyrne106
    decobyrne106 Member
    nice car! seen a black one in the states just like this. keep stock bumper etc! keeps it oem and sleeper like! if your changine get a navan kit! would look aesome in that colour!
  8. cattojdm
    cattojdm Member
    Yeh im from Swansea, Where abouts are you from?
    Thanks man :)
  9. cattojdm
    cattojdm Member
    little update........
    Got a new grill and darkened my headlights and sidelights..........
    Also did my first drift day yesterday in Pembrey........
    I loved every minute of it, and learned alot. I would recommend it to everyone. Thanks to Gav and Hawkey for their tips :)
  10. jom
    jom Member
    looks good!
  11. cattojdm
    cattojdm Member
    Little update....
    Removed the screamer elbow and replaced with a stainless divorced turbo elbow
    Fitted drilled and grooved discs to rear with new pads, unseized sliders.....handbrake is ten times better now
    Also fitted a stainless hot pipe
    Few more pics....
  12. gibbo s14
    gibbo s14 the yarco
    the turbo will over boost to make up for the lost gases leaking from the elbow mate they go pp wen i got my s14 it had one fited and my turbo went from overboosting, liking the darkend headlights
    #12 gibbo s14, Nov 19, 2011
  13. Jamie D
    Jamie D // NO DREAMING //
    any pics of the stainless hot pipe mate?
  14. stugvtec
    stugvtec Member
    Looks like your having good fun mate
  15. HOLES
    HOLES Member
    looking good dale mate, long time no see/speak
  16. cattojdm
    cattojdm Member
    The only time the turbo would "overboost" or work harder is if it was trying to make up for a pressure loss i.e. a boost leak between the turbo and inlet ports, the turbo wouldnt have to work harder even if there was no exhaust let alone an exhaust leak.
  17. cattojdm
    cattojdm Member
    You can see it here next to the pussy :p
    Also fitted a z32 TT Sytec Fuel Filter, pictured below next to standard filter
    Here it is fitted.....
    Here is random snap with my roof rack fitted and with the wheels I use for drifting fitted :)
  18. cattojdm
    cattojdm Member
    Thanks man :) yeh long time, ill PM you now :)
  19. cattojdm
    cattojdm Member
    Update......
    Fitted a Greddy Spec V FMIC today as can be seen below...... excuse the mess.....I'll get better pics in the daytime.....
    Also relocated the battery to the boot, and fitted a battery cut off switch in the car.
    My new wheels turned up today!.....
    18x8.75 Fronts, and 18x9.75 Rears, Ill put more pics up of them when I get tyres for them.
    Oh and fitted my tow strap on the front :)
    #19 cattojdm, Nov 24, 2011
  20. cattojdm
    cattojdm Member
    Finally got my wheels fitted, got tyres for them today, 225 40 18 up front, and 255 35 18 on the rear.
