Page 1 of 17 12311 ... LastLast
Results 1 to 20 of 321
    Southern style!
    May 2010
    2,007
    Southern Style badass JZX90MKII
    ok so ive had the car a while...
    for some reason never made a build thread on here...
    did on another forum, so im going to copy and paste the entire build/what ive been doing so bare with and ignore anything where it may not make sense..
    heres how i got it
    some of you may had seen my is200 i had.. and learnt to skid in it and then i swapped it for this!
    has a pretty heavy spec...
    1JZ freshly taken from an auto soarer with 60k on clocks, so never been abused
    new belts, gaskets,
    new engine mounts
    fresh coolant, oil and all fluids etc
    rare factory manual ecu and clocks
    HKS spark plugs
    HKS Fuel pump
    HKS Priest Titanium exhaust
    big front mount intercooler, metal pipework
    Yashio factory rad and rad cap
    twin electric fans
    engine earthing kit
    SARD Silicone piping throuout (new)
    r154 gearbox
    brand new HKS pro twin plate clutch, (£2k worth)
    HKS lightweight flywheel
    braided clutch line
    TRD 2 way LSD
    TRD 4.6:1 Final drive set (new)
    Cusco catch can
    ABS deleted, complete new lines made
    Traction control completly deleted also
    FOOTWORK
    Apexi N1 40 point asjustable coilovers
    TRD 3 arm rear set (new)
    TRD front and rear ARBS
    Yannack rear member locking collars (new)
    Tein steering arms and spacers
    MHC super angle spacers and corretion spacers (new)
    Cusco front strut bar (under bracing)
    Cusco chassic support frames
    mkiv supra brakes. braided lines
    ELECTRONIC
    GReddy boost gauge
    GReddy water temp gauge
    GReddy oil temp gauge
    GReddy oil pressure gauge
    triple gauge holder jzx90 specific
    turbo timer
    blitz speed limiter defencer
    seriously pimp carrozeria speakers, with matching wood trim from interior
    INTERIOR
    bride bucket seat drivers side
    standard passenger seat
    bride super low drivers subframe
    bride doorcards all round
    full interior and rear bench modified to fit round cage
    fire ext
    snap off hub
    dished naardi wheel
    mitto spec gearknob
    Yannak fly off handbrake button
    Cusco half roll cage
    broadway wide rear view mirror
    WHEELS + TYRES
    ROTA grid drift 18x10 et12 all round
    with good federal 595 RSRS
    25mm H+R hubcentric bolt on spacers rear
    AERO & LIGHTING
    Car Modify Wonder SHADOW complete kit (seriously rare kit, the best you can get for a jzx, cost a fortune)
    D-max carbon D1 bonnet (new)
    gandor mirrors
    Unknown aftermarket bonnet grille, meshed
    Origin front wide fenders (new)
    Origin Carbon 3D wing (new)
    240Z wide fender extentions (65mm (rears) + 35mm (fronts)) (new)
    Car Modify Wonder clear winker set (new)
    Car Modify Wonder Clear headlight set (new)
    Koito headlight conversion
    HID lights (new)
    Custom cannards and diffusers (new)
    [/SIZE]
    Changed since then:
    +Spoilerless and bootlid sticker bombed.
    +New spark plugs and coilpacks
    +Rear arches tubbed
    +Arc wonder ali air filter box (not fitted but included)
    +oil leak fixed and oil and filter change done 200 miles ago
    +new thermostat plus coolant bleed and change
    +DW magnetic sump plug
    +Brand new JVC double din head unit, full ipod connectivity etc.
    +Brand new battery with 3 year warranty.
    +Boost issue when I first got the car fixed, front turbo replaced with one supplied by garage D.
    +Aerocatches fitted to carbon bonnet.
    A couple of things need to be done to the car for it to be perfect:
    +Needs a paintjob to be fully badass.
    +Master cylinder needs to be replaced I THINK (clutch sometimes sticks)
    + Some form of fuel cut defender as it can hit fuel cut when it boosts past .9bar ( restrictor ring supplied so would be half hour fix)
    + A couple of bits of wiring to make the HIDS work properly and all the gauges ( just boost working atm but senders supplied for the others)
    It is a savage car and makes me smile everytime I drive it, and spins up federal 595's as if you were driving on ice.
    Car comes with 9 and a bit months MOT 3 and a bit months tax!!
    Temperatures always stayed the same, starts first time, awesome car!
    .Southern Style.
    Quote Originally Posted by driftescort View Post
    DUDE........We park so hard!
    Southern style!
    May 2010
    2,007
    got the HID's working all good.. and havent hit the fuel cut that was mentioned in the ad just as of yet.. but got a restrictor ring to fit sometime..
    horn all working now and it has a power steering leak... so i know this might seem a bit extreme.. but the engines coming out just so i can see/check if there is anything else that need doing.. and it stops me taking it out for a naughty drive with no insurance etc... haha!
    the engines pretty much ready to be pulled from the mounts now... i know a threads pretty useless without pictures.. but been pretty ill and not got many at the mojo and wasted a few days not doing anything..
    .Southern Style.
    Southern style!
    May 2010
    2,007
    some pictures of it on the way home...
    and some pictures of it getting stripped down (is a bit further at the mo but no recent pictures)
    hope to get it out and seal anything i need and get it all ready for some abuse!
    and ill get plenty of vids/pictures of it skidding so dont worry
    sometime i want to get a paint job on it .. although as it is it seems to suit its character like its going to eat you!
    .Southern Style.
  4. #4
    Southern style!
    May 2010
    2,007
    oh and ripped the stickers off the boot lid... now need to sand and paint it sometime..
    .Southern Style.
  5. #5
    Southern style!
    May 2010
    2,007
    rush out to work update....
    basically wanted to paint my cage... got no flicks of me painting it.. but sanded it and primed it and heres a before and after!
    after
    and re painted my boot lid and filled some holes where a spoiler was and was stickered up and was a mess..
    my paint job is streaky and shit... but its a temp measure
    in that last flick the car is filthy...
    enjoy!!!! off i go!
    .Southern Style.
  6. #6
    Southern style!
    May 2010
    2,007
    well finally got the engine out...
    geting it ready
    hooking it up
    pulllllll..... and pop.. out she comes..
    then made a big ass list of things to do while it was out... some not needing to be done but others were more important..
    then after getting a quote from toyota for the bits minus the fluids etc... for £900+ i thought id skimp down the list...
    now just waiting for a power steering pump seal set, gasket set for the entire engine,oil filter,cam belt and tensioner..
    and that was still £300+ and i still need fluids and to seal the power steering rack...
    so gonna take the rack apart next and juts buy a random copper washer kit and see what i can match up..
    then still have the problem of the clutch pedal not returning properly when i go balls out.. only doesnt return by 20mm or so but i have to return it with my foot.. any ideas? could it either be clutch master cylinder or slave... or something to do with the twin plate clutch? or just not being bled properly.. heard they can be a bugger to bleed? any ideas would be helpfull!
    now just waiting on bits for the next update!
    .Southern Style.
  7. #7
    Southern style!
    May 2010
    2,007
    right... parts are taking to long...
    so heres some pictures of splitting the engine up bit by bit.. bareing in mind ive not done this before just getting help from a mate..
    seperated the sump ready to re seal
    OHHH HELLO HKS CLUTCH
    and took the rocker covers off.... and it was full of shit and sludge.. so its all coming apart and getting cleaned
    as the head gaskets getting done
    .Southern Style.
  8. #8
    Southern style!
    May 2010
    2,007
    oh and random shot of it in japan getting loaded into a container!
    .Southern Style.
  9. #9
    Southern style!
    May 2010
    2,007
    yeah pretty much found what i need now and its on the way..
    started to strip the engine down.. inlet manifold and that was easy to rip off...
    but the turbos were interesting and still havent done it.. but not sure what this clamps called but i pulled it and it fell off
    and left a gap between the turbos.. found it had no nuts on it.... guessing she would had been loosing plenty of boost..
    heres the clamp?
    that was it for the day and waited for bits to turn up...
    today,.. cambelt and cambelt tensioner and the power steering pump seal set turned up...
    now.. bearing in mind i have pretty much bugger all knowledge of anything mechanical and im just having a go..
    i decided to take the power steering pump apart and re-seal it!
    seal set
    how shitty it was at the start... ewww (kind of took over the kitchen worktops.. haha)
    and then just started taking the pump to pieces trying to match the seals i had in the bag..
    then started to clean it all up and heres the end result
    some bits looked new
    then seeing all the cases and covers... kind of thought it was a shame not to paint it
    so masked or bits that looked like they wouldnt like paint in them..
    hung bits up
    and then primered them
    and how my kitchen looked after...
    so tomo going to paint the primered bits black... and then re build it all with the new seals and hope it works!
    .Southern Style.
  10. #10
    Southern style!
    May 2010
    2,007
    well painted all the bits that i primered yesterday...
    then re built it bit by bit
    first off was a new oil seal
    then to set up ready to push the bearing in
    bearing pushed in and new cir-clip
    and then other bits which i dont know what they are called..
    then im going to call this the pump fin housing??
    fins going in (was quite cool to see how it all worked)
    and then a washer thing which keeps tension (thought it was buggered when i first took it appart)
    more new seals
    and one fresh newly sealed pump
    fingers crossed it works as it should when it all goes back on..
    hopefully more work going on in the engine next!
    .Southern Style.
  11. #11
    Southern style!
    May 2010
    2,007
    right basically not much of an update.. still waiting on the friggen gaskets....
    but basically got the turbos off
    and heres how it looks at the moment..
    and now im not to sure on this... oil in the inlet of the turbo.. should i be worried? things to check?
    need to get the cams out and then the head off and wait for my gaskets to arrive....
    .Southern Style.
  12. #12
    Southern style!
    May 2010
    2,007
    and just took the cams out... and then thought i would get the head bolts off....
    snapped a extension bar... and rounded a head bolt off... so got the hump and went in for the night
    ill have to work something out sometime... guess ill have to weld a nut on the top
    pretty confident i could weld a nut on the top... like drill a nut to be close to head bolt size.. and then hammer it on and then weld..
    ill get some more pictures up of how it sits at the moment...
    .Southern Style.
  13. #13
    Southern style!
    May 2010
    2,007
    right might had found out why i rounded the head bolt off.... me being a dick i didnt clean the bolt out enought and i thought it was a 10mm allen key
    it was infact a torx bit... so might be able to save it when i get a chance to ..
    new head bolts turned up today and a induction pipe i needed...
    and a box from toyota
    the gasket set...
    many more than i thought would turn up... now just got to find a place for it all
    need to get on and work on it but works prooving to be a pain...
    .Southern Style.
  14. #14
    Southern style!
    May 2010
    2,007
    right...
    heres how its looked for a while with no cams etc..
    after snapping various tools and rounding bolts off i finally got the head off (woooo)
    had to drill the rounded off one out..
    the suspect in question
    pilot hole
    some drilling yo
    then we just kept going up in size to slowly get the head of the bolt off
    and then pop!
    so that was a real pain that i thought wouldnt have been solved so easy
    here you can see the up in sizes
    heres the head offf finannnnnnnaly
    now not to sure of what the condition should be to be honest...?
    any opinions would be good...
    now ive ordered some pistion rings.. and they wont be here till next week.... so next is just to get on whipping bits off...
    and got to source some black gloss engine paint for the block
    .Southern Style.
  15. #15
    Southern style!
    May 2010
    2,007
    right another update today... the misses went home so i got busy...
    started to get the oil and shit out of the engine bay, but no pictures of this as i remembered i needed the engine done!
    so i split all of the front sump off ready for a re seal and to do the piston rings
    and then spent the rest of the time trying to clean out the garage/shed so i could carry on doing
    the head work when its dark/raining...
    not much of an update but i guess more will have to come apart sometime..
    cheers for looking!
    .Southern Style.
  16. #16
    Southern style!
    May 2010
    2,007
    oh also for those who havent seen a twin plate clutch before this is what the consist of
    cover off
    then
    then
    then
    and then
    and thats not a pistake or a 'look at me i got a flash clutch' its just i like to see things on other peoples builds
    .Southern Style.
  17. #17
    Southern style!
    May 2010
    2,007
    well today wasnt very productive.. but i actually done a wee bit of work on the car all this shits going in...
    rinsed a tonne of break cleaner de-greasing all the old leaked oil... hopefully it stays in the engine and where fluids should stay this time..
    got all new washers etc for the power steering rack as it was leaking like a biatchhhh and had to work out from old photos how it went back together..
    and then as i was just chilling sitting in my engine bay on the blower... i found this
    so now got to replace this to... grrr
    hopefully more engine work tomo ..
    either head disassembly or block disassembly..
    .Southern Style.
  18. #18
    Southern style!
    May 2010
    2,007
    hockey pucks ordered... think ill need three per side.. all should be good gonna be out working on it in a bit and get some bits done.. oh and piston rings are here.. but im going to return them.,.. as the engine has onely done 60k K apparantley... and its saves me £190 which i kind of need for the moment.... so ill paint the block... get some tools to do the valve seals etc...
    ill try and get a move on!
    .Southern Style.
  19. #19
    Southern style!
    May 2010
    2,007
    right.. piston rings have gone back so thats some money back...
    and just a reminder im no mechanic.. so what you about to see might not be right etc.. but im improvising..
    took all the cap things off the tops of the valves.. and there in a order
    state of it..
    then i didnt have a valve spring compressor.. so the internet was my friend and i found a different way of doing it..
    heres the tools needed..
    then do this
    then this
    and this
    this was such a pain to do.. took forever and im sure the propper tool would had made light of this..
    anyways, then the magnet catches the collets..
    the first one was such a pain to do.. well even work out how to do it..
    got one side out
    and then cracked on and done the otherside..
    and then took the valve stem seals out... the exhaust side came off everso easy...
    but the inlet side i had to destroy ever seal to get it off... but got fresh new ones so all good..
    heres how it looks at the end of today!
    now jut got to clean it all up (to the best i can myself without getting to industrial)
    and then can start putting it back together..
    still need to do the crank seals on the block and then things can get put back together! (wooo)
    .Southern Style.
  20. #20
    Southern style!
    May 2010
    2,007
    started to clean the head..
    then i lapped the valves... never done it before and it took forever!
    one side done
    both sides done
    then cleaned all the face of the head up looked much better
    then me and my pal henry hoover made a new attachment to suck bits of crap out the hard to reach places in the head
    then put all the valve stem seals in on the inlet side and the exhaust side..
    and heres how it looks at the moment... as i cant get the valves back in... well the collets etc...
    also got the front sump back on all sealed up and the sump pan on and sealed.. all thats left is to get the head done and back on and things should be pretty straight forward from there! get some flicks up tomo hopefully
    fingers crossed..
    .Southern Style.
