Page 1 of 5 123 ... LastLast
Results 1 to 20 of 81
    Jul 2009
    Herts
    961
    M50B25 Turbo E30 rocket build
    After breaking my track S14a, I wanted to build an awesome street weapon.
    I had originally planned on dropping a turbo m50 into my daily 323i E36, but always wanted an E30. So when a good one came up for the right price I snapped it up.
    Gunni as GSTuning is sourcing the parts for me and also making the manifold. The future spec of the engine will be:
    MLS headgasket
    Bosch 60lb injectors
    Split pulse twin scroll manifold
    Borg warner S256 twin scroll turbo
    60mm wastegate
    Sachs pressure plate with 6-puk clutch
    VEMS
    I had previously sourced this 1991 E36 325i auto (non-vano M50 ftw!) for cheap so I could rob it of its engine:
    Car had been stored in barn for ages and had all sort growing under the bonnet, but was only 91,000 miles and full BMW service history so was a steal for what I paid for it.
    M50B25:
    Nice and clean under the cam cover:
    The paint has completely flaked off the cam cover as it is magnesium, so got to stripping the paint and sanding it:
    Etch primered it and painted it with some 2 pack black:
    Sourced this 316i E30 for a fairly decent price, needs some work done to it as has rust in usual places (jacking pads!).
    Sourced an E36 325i gearbox:
    Ended up with 2 E28 diffs as one of them was meant to be a 2.93, but the guy I got it off had got it wrong, so have ended up with 2 3.10 diffs:
    The comedy 316i engine:
    Got to removing it:
    Will be selling bits off the 316i engine, PM me if you need parts:
    Next threw in an E46 clubsport rack with DanThe spacers on the top:
    Took apart an E34 steering UJ and combined it with the E30 UJ:
    All bolted up with DanThe's splined steering shaft:
    I have a E34 sump waiting to go onto my engine, so will sort that and am also waiting on poly engine mounts from rev-shift. Had to really go with poly as the downpipe is going to be running to close to the steering column and don't want it to foul on it!
    So engine will be in within the next few days. Just waiting on Gunni at GSTuning to come down so he can mock up an E36 bottom mount turbo manifold so see if it fits, if not will probably go with a top mount. I would prefer a top mount anyway, but will see when Gunni comes down to check fitment.
    Jul 2010
    Hillingdon, Middlesex
    1,595
    Cant wait for this to hit the road as i said on Saturday. Will be a beast with your skills
    BMW 325i Turbo
    Jul 2009
    Herts
    961
    Quote Originally Posted by R32 GTR View Post
    We will defo have to hit up a drift day with our M50 turbos when we're done!
  4. From the Driftworks Shop
  5. #4
    Apr 2012
    Hertfordshire
    50
    Nice one!
  6. #5
    Sep 2011
    London
    52
    Cant wait to see this finished... Always love turbo bmw's. Good luck
  7. #6
    Jul 2009
    Herts
    961
    Stuck the 5 series M50 front sump on:
    Revshift 24v conversion poly mounts:
    Needed these because I don't want the engine to move too much and foul on anything as I know clearances are going to be tight. Cabin noise should be fine still as its a smooth 6-cylinder and not a 4 pot bag of shite.
    Getrag gearbox:
    Mounts installed. The central stud goes into the slotted holes in the subframe closest to the chassis rails. Since the stud on the other end is eccentric, the mount can be rotated to centre the engine perfectly.
    Nearly there:
    And shes in:
    I am using stock E36 gearbox rubbers (same as E30) for the moment until I get hold of some E21 ones. I rotated the engine mounts until the crank was perfectly centred between the chassis rails and each end of the mount was sitting flush with their mounting surfaces. Gearbox and engine mounts were then tightened fully and measurements checked again it its sitting perfect. The mounts left are right aren't aligned symmetrically with each other, but this is fine since the engine sits spot on.
    Plenty of space for a turbo! And loads of room for downpipe.
    Car is being trailered up to Gunni at GSTuning tonight and he will build the top mount manifold.
  8. #7
    Miseryguts
    May 2005
    Isle of bollocks
    22,943
    Awesome! I've always wanted a big power E30! This is going to be the bollocks.
  9. #8
    Mar 2005
    2,129
    Looking good see u tonight.
    S14 Silvia
  10. #9
    Feb 2012
    Barnsley
    468
    looks like a good build mate, I have a e30 325i how hard is it to get other engines to fit i.e... 3.5
  11. #10
    Aug 2007
    83
    subscribed ;-)
    e36 m50 turbo 434bhp 404 lb ft
  12. #11
    Mad pointing Munky
    Oct 2005
    24,768
    subscribing as i love e30's and m50's
    DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
  13. #12
    LM.
    LM. is offline
    UNAUTHORISED ADVERTISING
    May 2010
    Manchester, UK.
    309
    Will be watching this one closely, looks set to be fucking awesome.
    What sort of power figures are you aiming for?
  14. #13
    Jul 2009
    Herts
    961
    Quote Originally Posted by 123tom123tom View Post
    Sorry got no idea mate.
    Quote Originally Posted by LM. View Post
    500+ bhp and similar torques. Will never put the power down anyway lol
  15. #14
    Jul 2009
    Herts
    961
    Car is still at GSTuning, so thought would go about rebuilding and freshening up the brakes. The brakes will probably be fine, but thought I would rebuild them as they are really old, and also they look really grubby!
    I sourced some vented E30 325i front calipers and complete E30 325i rear trailing arms. I will be using these with yellowstuff pads for the time being, if I need bigger brakes will invest in some in the future.
    The rears weren't too bad:
    Fronts were a different story. Looked like someone had attempted to paint them yellow at some point in their lives (wire brushed the one on the right):
    So I stripped the calipers, wire brushed them as much as I could:
    Mixed up some Deox-C and left it for a day:
    Bits came out well:
    They then got another wire brush, degrease and good cleaning before I started painting them:
    Baked them in an oven for around an hour, then got to tapping the holes again and cleaning off any paint on any of the contact surfaces:
    Started to rebuild everything. Rebuild the calipers, greased and assembled everything.
    All done!
  16. #15
    Mar 2005
    2,129
    Nice did u get the seals and everything from BMW?
    S14 Silvia
  17. #16
    Jul 2009
    Herts
    961
    Nah got them from biggred.co.uk
  18. #17
    Apr 2012
    239
    Quality project
  19. #18
    Sep 2010
    Edinburgh
    40
    Top build be interesting to see what Gunni can ring from the M50 on stock internals, you changing to single mass flywheel to go with the uprated clutch.
  20. #19
    Jul 2009
    Herts
    961
    Yep going for an M20 flywheel with a Sachs 618 pressure plate and pure performance sweden 6-puk friction disk.
  21. #20
    Sep 2011
    15
    good luck with the build
