UPDATES
May 2013 -
Latest Pics:
The British Drift Championship
Sponsors & Support:
Project D
Bodyart Paintworks
Auto Extreme UK Ltd
6Boost UK
MGT Racing Ltd
Safety Devices
Demon Tweeks Motorsport
Nengun Japan
Driftworks
+ friends & anyone else who has helped- thanks
Current Spec:
Engine:
580BHP / 481WHP @ 1.2 Bar (Mapped by MGT Racing Ltd)
1JZ-GTE Non VVTi
Holset HX35 Single Turbo / 12cm Ex Housing
Turbosmart Comp 40mm External Wastegate (routed back to downpipe)
6Boost Ceramic Coated Twin Scroll Top Mount Manifold
Solid Fabrications Custom 3' Downpipe
Solid Fabrications Custom 3" Straight Through Exhaust System (straight piped rear)
HKS FCon Gold V Pro Type A
HKS 650cc Injectors
Walbro 400LPH Internal Fuel Pump
Sytec FSE Fuel Pressure Regulator
HKS Cams 256 IN, 256 EX
HKS Fine Tune Timing Belt
HKS Metal Suction Pipe
HKS Air Filter
Greddy Oil Cooler With Relocated Oil Filter / Braided Lines
Greddy Top Rad Pipe
Blitz Intercooler Kit / Shortened Pipework / T Bolt Clamps
Blitz Rad Cap
Custom Tripple Brass Core Radiator
Sard Engine Torque Damper
Millers 10w60 Engine Oil
Millers Gearbox Oil / Diff Oil
Air Conditioning Delete (Conti 6PK1888 Shorter Belt)
Custom P/S Pump Support Bracket
Hydraulic Fan Delete
Pace Oversized Electric 16" Fan
2JZ Waterpump.
CDF Racing 2JZ Lightweight Waterpump Pulley
CDF Racing 2JZ Lightweight Alternator Pulley
CDF Racing 2JZ Lightweight Power Steering Pulley
Nozzs 1JZ Clear Timing Belt Cover
Chassis / Drivetrain:
R154 Manual Conversion with Remote Shifter
Custom Aluminium Solid Cradle Bushes
Northshore Toyota NZ TRD Quick Shift Kit
Weld Heavy Duty Brass Shift Linkage Collar
Weld Heavy Duty Clutch Pedal Pivot
ORC Twin Plate Metal Clutch / Lightweight Flywheel
Comp Brake Hydro Handbrake with Wilwood Master Cylinder & Hel Braided Brake Lines
Aftermarket Front Pads / New OEM Rear Pads
HSD Coilovers 15F/8R
Cusco 2 Way LSD
Nickson Motorsport FIA Weld In 6 Point Roll Cage with Double Door Bars, Roof Diagonal, Rear X & Harness Bar
Cusco Front and Rear Strut Braces
Ultra Racing Front Antiroll Bar with Poly Bushes & New OEM Links
Cusco Rear Adjustable Antiroll Bar with Poly Bushes & New OEM Links
Ultra Racing 8 Point Front Lower Arm Bar
Ultra Racing Chassis Bars
Cusco Solid Subframe Bushes
Ikeya Formula Rose Jointed Front Upper Arms / Camber Arms
Ninja Power Steering Rack Spacers
Hey Man 800HP Forged Steering Knuckles
Uras Strengthened Tie Rods
Super Now Rose Jointed Tie Rod Ends
IS200 Tension Rods with Super Pro Offset Polyurethane Bushes
Super Pro Lower Arm Polyurethane Bushes
Completely Rebuilt Front Suspension Assembly Inc Hubs (New Bolts / Bearings / Uprated Bushes / Cleaned / Painted)
Exterior:
Vertex T&E Front Aero Lip
Vertex T&E Side Steps
Vertex T&E Rear Apron
D-Max Front Vented Over Fenders
Lightened Bonnet / Bonnet Louvres
Ganador Door Mirrors
Clear Front Corner Winkers
Bi-Xenon Super White HID H4 4300K Hi/Lo
Super White H3C 4300K Side Bulbs
Super White LED 4300K Marker Lights
Front Wheels: Work Equips 18 x 9.5 ET-1 (3" Lips with Gold Rim Bolts) - Polished
Rear Wheels: Work Emotion CR Kai 18 x 9.5 ET20 - Powder Coated Anthracite
Front Tires: Yokohama Advan Sport V103 235/40/18
Rear Tires: Treads of Malvern 225/40/18 & Achillies ATS 255/35/18
Demon Tweeks Aluminium Tire Valves
AI TECH Copper Coated Racing Nuts
Schroth Tow Hooks
Aerocatch Plus Flush Bonnet Catches
Lifeline 2.5L MSA Plumbed in Fire Extinguishers
Lifeline 2.0L Handheld Fire Extinguisher
FIA Battery Cut Off's / Panel Switches
Interior:
HKS Turbo Timer
Defi Link Controller
Defi Gauges (Oil Pressure, Oil Temp, Water Temp & Boost)
Greddy Profec2 Boost Controller
JZX100 Dash Clocks
KEY!S Racing Deepdish 330mm Buckskin Steering Wheel
KEY!S Racing Buckskin Shift Knob
Okuyama Carbing Aluminium Pedals
Okuyama Carbing Aluminium Driver Foot Rest
Okuyama Carbing Aluminium Driver Floor Plate
Okuyama Carbing Aluminium Passenger Plate
Cobra Pro Suzuka S Kevlar Driver Bucket Seat / Recaro Side Mount Subframe (8.3KG)
Recaro Pole Position Passenger Bucket Seat / Recaro Side Mount Subframe (7.0KG)
Takata 5 Point Harness with crotch strap
Safety Devices FIA Roll Cage / Doorbar / Roof Padding
Fully Stripped Interior inc ALL trim, OEM heater matrix, excess wiring, part dash & all sound deadening
Interior / Cage all painted in Toyota white
Demon Tweeks Lightweight Motorsport Heater with custom ducting
Fully Flocked Dashboard
How it started - November 2012:
Hello!
On my quest to get into Motorsports after slaving away as a car dealer for god knows how many years I've taken the plunge and purchased a rare Toyota JZX90 Cresta! I've always wanted to get into Motorsports and have been praised for my skills or lack of fear for years but I've never actually drifted, so it's time to take action, drift world here I come!
The JZX90's are quite rare, think of a 4 door Soarer running the same 1JZ. Mine is an earlier NON VVT-i so has lot's of potential! Converted from auto to manual in Japan using a R154 gearbox and remote shifter. They do a Cresta, Chaser, and Mark II in 90 form, same goes for the later 100 and 110. Mine is the luxury version with great cult status in Japan, popular with naughty people, ideal!
Here is what she looked like in Japan:
Since then she has undergone a few owners in Scotland so is a little "weathered", just needs a really good tidy & some love.
I went all the way to Scotland to get her and drove back on a 7 hour hike, mission but glad I made the trip.
Budget sardine airways for the win:
Finally back on home soil at Project D in preparation for Pod on the 17th of Nov:
Mainly tidying, all new fluids, used but unwarped disks as current ones are buggered, fit lock spacers Dale gave me etc just get it driving nice then start playing. Will be living at Project D while I get her ready enlisting the help of anyone who cares
Outside J's Body Art Paintwork in Guildford:
Oh and also bought a vertical Hydro from Comp Brake , a willwood master cylinder to go with it and some Hel braided brake lines which are of a good quality. Will be going single turbo next year but going to enjoy what it has on offer now as the year closes and get a few practice days in.
Using Mitto's old car as inspiration:
Hopefully one day my middle name will be Sato
Anyway just an intro into what I will be up too. I'll update as I go on as best as I can with spec and pictures.
That's it for now.
Cheers!
Toby Aspinall
LinkBack URL
About LinkBacks
- thanks
Had lots of Jap cars in the past as well though 600BHP R32 GTR, R32 with a 1JZ, Evo 8 FQ400, 2 S2000's, KP61 4AGE etcetc you get the picture I'll stop gloating now
Never actually skidded though apart from the odd chav action in a car park, sure we've all been there. And I'm not rich I just spend all my money on cars lol...
Good pictures though your great at what you do.
