Hi. With drifting I don't have too much to do and I've never login to your forum before. Accidentally I met with Paul from Japspeed, we talked about three hours about my projects and when he see some pictures of our 200sx S13 body with Audi engine, he ask me to post topic here. So I do this Body is S13 200sx. Suspension and steering: S14 hubs Tein SS, Reg. Camber plates front and rear, polyurethane bushings Breaks: Front - D2 8pot calipers on Mercedes ML disc (350mm) rear - 300mm disc and calipers from 300zx Bodykit: RPM bodyshop (polish product) And most interesting, engine and driveline: - Total absolutly stock Audi 4.2 V8 40v Turbo (from '01 A8) - helix double-disc cluth with flywheel - Oil pan is built from the basics for project needs - Oiling system - relocated filter, external thermostate, and oil cooler from Mocal - water cooling - radiator from Audi 80 comeptition, 2 Spal fans - Intake - custome made intake manidold with 80mm throttle body, 76mm intercooler, HKS blow-off, ITG airfilter - exhaust - custom made manifolds to twin scroll, chines T76 replica, 2 external 60mm HKS wastegates, 3" exhaust - fueling system - swirl pot, 2x 044 Bosch fuel pump, 10mm tubes lines, 8x 850cc Siemens deka injectors, Sytec fuel regulator - gearbox - stock getrag 6speed from S4 B6, custom made shaft - rear diff - audi coupe, with mounted torsen from audi V8, driveshafts from VW T5 and joints form land rover freelander And pics: Front breaks: Intake manifold: And others: And dyno - setup on 0,8bar of boost, at final stage we have 0,95bar and something about 640hp and 800Nm. And engine is still stock
Goddamnit I knew those 4.2 V8s would be awesome with a turbo! Someone, a VAG 'tuner/expert' told me when I mentioned it to them that they're weak and don't take to turboing well at all. At the time I thought it sounded like he'd never tried and was just guessing to explain away why they never had. Guess I was right. Awesome stuff.
I have said all along. Audi a8 4.2 lumps are so cheap great power, light, easily charged or turboed. Loving this to the max!
the car run's smooth...... delivers the power preety nicely the bodykit is stated wrongly - it's RPM bodyshop - still Polish brand
Some vids: Start with old turbo 3,7 and 590hp and 800NM: Nissan 200sx S13, audi V8, Holset HX50@14cm2 - YouTube And start from gauges on finał stage (2nd gear start on street federeal rsr 285/35) https://www.facebook.com/video/embed?video_id=579237278771595 https://www.facebook.com/video/embed?video_id=579231708772152
Can you provide a bit more info about the gearbox set up with the rear diff/torsion? I was under the impression it was a bit difficult to make the Audi V8s RWD, but this clearly works quite well! Power output is spectacular good work, what ECU are you running, factory or what? Thanks
gearbox is a quattro version, with welded center diff and unmounted front diff. You must use audi rear diff, because output shaft from gearbox rotate counter-clockwise. Ecu is EMU - realy good polish product (ecumaster.com)
https://fbcdn-photos-g-a.akamaihd.n...0x720/534303_446594625369195_2115390499_n.jpg This is our torque monster stock v8
