Supercharged M45 MX5
Thread in 'Project Cars and Builds Threads' started by jacksheps, Nov 9, 2013.
  1. jacksheps
    jacksheps Member
    Car started standard with 65k on the clock, FSH, every mot, new hood, clean car!
    Slapped some cheap coilovers on and some new Rotas, front spliter & twin exit exhaust. And a full service for good measure (Y)
    [​IMG][​IMG]
    Soon got bored of gaying around and got myself up santapod with the stock LSD
    soon after this my years insurance was up & had to get myself a van for work and tools due to going self employed so a lot of my money went into this so car was put in a garage on the back burner :/
    This is where I demented to get some upgrades on the go!
    4 point cage
    welded diff
    seats
    hydro
    new wheel with a stupid 200mm sun strip!
    solid engine mounts
    solid diff mounts
    rx8 injectors
    boost gauge
    LCD gauge that shows me oil temp, oil pressure, AFR & outside temp
    rack spacers & so on
    soon replaced these lines with some hel flexi lines :)
    Then I couldn't resist and decided on the supercharger route, m45 charger is from the cooper s works with Teflon blades :D
    All stand alone megasquirt ecu with front mount intercooler, 17% reduction pully, rx8 450cc injectors. Should be around the 215bhp 200lb torque, plenty in a mx5 if u ask me!
    Have been booted out the garage to back on driveway now :/ sold softop and got myself a hardtop on
    All comments welcome!
  2. jacksheps
    jacksheps Member
    9j et0 rkr's
  3. blazingburger
    blazingburger Member
    bad man idea. looks so much easier to go down the supercharged route. how easy has it been to get parts, etc for it?
  4. jacksheps
    jacksheps Member
    It's been ok, not cheap by any means! Chap in Stroud does the fitting kit, bracket, inlet, outlet, tensioner for £500, charger cost me £300, ecu £500 so with all other bits it's gunna be around the 2k mark :/ but from others I've been in its worth it!
  5. jacksheps
    jacksheps Member
    Couple more of the install
  6. Ruishy1
    Ruishy1 Active Member
    if you want more power and don't mind modding shit, the m45 snout will bolt onto the m62 charger body.
    It would require a bit of work to work but would mean you make ALOT more power :)
  7. Stavros
    Stavros Active Member
    Good call on supercharger, it's miles better for drifting than turbo, better than even a turbo with a hell of a lot more power in fact in my experience.
  8. jacksheps
    jacksheps Member
    The m45 does the job for now, I can't justify spending 2k on the charger alone! That's what the 62 goes for :(
  9. jacksheps
    jacksheps Member
    Yea been in a few cars and there no feeling like a charged one, you know when you got the power unlike a turbo car off boost it's kinda unexpected :/
    I will keep this thread up to date when more happens
  10. Ruishy1
    2k !
    don't know where you have been looking but you can get them for sub 300 quid all day long on ebay !
  11. jacksheps
    jacksheps Member
    Done abit if cutting around in the loom yesterday to get rid of the crap I don't need, also got my IAT sensor drilled and in place. Next update with all inter pipes connected up :)
  12. jacksheps
    jacksheps Member
    Also got the new radiator system filled up with new fluid so I don't get any frozen water in the block over these cold nights!
  13. jacksheps
    jacksheps Member
    Got some earths and lives sorted regarding my gauges and a quick test with ignition shows I've got a couple of wires the wrong way ha! Quick swap and it was back to normal but you get the jist of what's going on :)
  14. Dirk Jan
    Dirk Jan Member
    Quite hot out in the UK i see. Good work!
  15. Leno
    Leno Member
    Interested in the details of the guy that makes the fitting kit.. Im really tempted to do this to mine!
  16. jacksheps
    jacksheps Member
    It's not quite as simple as bolt on I'm afraid :/ google it bud and get on mx5nuts for all the info your gunna need
  17. Leno
    Leno Member
    Ah Bugger okay, little ray of hope there that I didn't have to search round for all the bits!
  18. Big Monts
    Big Monts Member
    This is a great idea :D are you doing it on stock internals?
    BM
  19. jacksheps
    jacksheps Member
    Ye stock internals bud, the 1.8 is good up to 300bhp with forced induction.
  20. eurospec
    eurospec Member
    Reminds me of mine! I had a Jackson Racing setup on my 1.6, so was bolt on, took about half a days work to get the car up and running, used a powercard to sort the ignition and fuelling, went pretty good, about 170/180bhp I reckon.
