Results 1 to 9 of 9
    Nov 2011
    5
    Georgy bmw
    Hello guys!
    I have bmw e36 for drifting,{I have idea build this for track only,but now its not possibly..
    And I build my car for daily drifting )
    engine:M50b25 with stroker kit from m52b28
    I want to fitt turbo on this engine..
    This is test, i want 0.5 bar.
    because on the 3rd gear I miss power..for stability drifting )
    who know?what need to tune for normal working engine?
    CR 10.5:1
    need bigger gasket?
    or i can boost this?
    If i like turbo drifting,winter 2014/2015 i build from 0 new engine,turbo engine with normal parts..but in this time a need to try how it is )
    some pics of my car.
    Sorry for bad english.
    Feb 2013
    22
    No need for thicker gasket if you wont to run 0.5 bar. 280 Hp is safe on standard engine.
    Nov 2011
    5
    but i need to do 350-380 Hp .. maybe 0.7 bar..
    guys who i know @ m54b30 boost 0.7 bar,and all is okay...
    N/A power approximately is a 220-240 Hp.
    @ stock m50b25 can do 300 Hp with 0.5 bar..
    or for 350 hp need changes? oil pump need to change? or stock 2.5 pump work normal?
  4. #4
    Jan 2014
    Aberdeen
    40
    very nice!!
  5. #5
    Feb 2013
    22
    Quote Originally Posted by woxel View Post
    For those kind of power it would be wise to get a thicker gasket and ARP studs because you will have to run a full bar to achieve that power level. Most likely ARPs aren't needed just new new head bolts could do the trick. Oiling isn't an issue on M50s. To run that kind of power reliably you have to pay attention on things around the engine. Good intercooling, smooth exhaust manifold, proper ECU map, solid fuel pump and injectors. Stock clutch will give up, so will the gearbox and the diff bolt will crack all the time. All those things happend to us running a supercharged M50 with only 250 HP/400 Nm.
  6. #6
    Nov 2011
    5
    Thanks DW & DPD ! )
  7. #7
    May 2005
    Isle of bollocks
    26,147
    Quote Originally Posted by TheMR2V6 View Post
    Totally depends on the turbo.
    No way will you need as much as 1bar with the right turbo setup to hit 350bhp on an engine that already is pushing over 200 n/a
    knmk;mk;m
  8. #8
    Nov 2011
    5
    Wilwood, Summit Racing
    Cylinder for my new handbrake
  9. #9
    Nov 2011
    5
    DRiftworks+Wilwood
    Cestom plate from non-rusted metal.
    200 Euro + 6h of work & i got this result.
