Updated!!! Sr20det blacktop non vvt forged pistons cosworth headgasket tomie inlet cam hks exhaust cam rocker stoppers hks valve springs alloy winged sump ported cosworth valves cosworth conrods was running 360hp apex front coilovers and bc rear driftworks tension rods superpro rear links and anti rollbar bushings superpro front antiroll bar bushings 50mm over fenders uras front vertex sides origin streamline rear chargespeed carbon bootlid nismo z tune bonnet vent Front mount intercooler deep dish wheel boost guage 3 inch cat back exhaust Stainless manifold s14 turbo s15 brakes 18 inch works 9s front 10s rear front 25 mm spacer rear 50mm Engine damper uprated clutch cusco 2 way diff Full respray in red last year and underside sealed. {} plans are to get the arches filled with new wheels fit my omps i have sort the cooling as shroud of the car due to front mount need to relocate battery to the boot tidy the engine bay and more guages got an oil pressure and boost option guages and a new hks mushroom filter, filter fitted {} nct {}
Ok a bit of an update. my passenger headlight full beam had no voltage so gonna run a wire across from driver side knock in coilover driver side. Done removed the drift bits sticker! Done driver door packed up so hardship to get door open the clip that holds the handle in was loose, fixed. Done wipers acting up stopping at middle of the window? changed motor and still same issue linkage was off but still have problem with it. need a few interior bits and getting a new washer bottle and fuse cover and that from petko if he has them also new clear side lights.Done got all these parts and fitted. also will be fitting a turbo timer boost and oil pressure guage plus rsm it already has a fcd i already had these laying around. the speedos not working so rsms for that. decided on the wheels i want too work vs will swap the advans for them if i can. pass the nct and fit my omps.
Update time! went for nct failed on emissions tires wiring a brake hose etc loose bumper so done a few bits fixed bumper and hose got two new yokahama advan sports on the front then for the back my friend who does the tyres has an rx7 but took these off the back ventus s1 evo stupid wide!! 285/35/ r18! also new pads front and back! may book another test! got a lambda sensor of aidan reilly
silver rsm fitted with stand also hks ssv bov fitted. also sent off the tax book again as it had the original white on the book got it back today as red, had to go to nissan to get the car checked, chassis plate to the book taxed for three months few issues to sort such as the fan cowling going for electric fans id say as cowling wont fit noise in steering starting to think its the brake calipers as its constant noise until i brake. battery isint great shes needed a few jumpstarts, still have to retest it. need to spray wheels too and get guages in aswell as fix speedo
Ok update time my zenki has been through the nct 3 times and failing on emissions, sky high each time, the last time she had a lambda sensor a new cat and diptaine. will try ecu and check all gaskets for leaks etc. then car started getting sluggish as i drove it ended up not starting and still wont start. no spark so checked all coilpack etc cas unit so coil igniter im presuming so waiting on that part from lady 89 i might have monday. random drive with the toyotas! she is living on these! today i did this which cheered me up real happy with it tomorrow ill be cutting the inside of the overfenders to bring my wheels out more spraying the advan lips spraying my calipers and compounding headlights need to collect my bride low max and a set of 25mill spacers for the back find an alloy rad with twin fans also rear diffuser connect the coil igniter when it arrives.
update cars driving ok. got these for a bargain in dublin image wheels was only two so i stuck two tyres on them. will be getting them tidied up and back to mint for the rear. need to alter pitch as its too narrow and offset as there out a mile! [/IMG]
works vskfs on the back now. the lad i got them off has another for the front and a lead on another so will be on soon. need 50mill spacers.
Yeah i know theyre hard to find but i always loved the works and had to put them on, i found 50 mill spacers and im collecting sunday so theyll be on then. will have pics once theyre on. Need lower skirts too!
its not too far away. got a lend of enkeis rpf01s he has 4 for the front off a friend. love them already. love having rare and desirable rums. need extended wheel nuts and threw on some spacers. getting tracked in the morning. think its the back end is off.
