Old 12-11-2006, 16:29   #21 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
Originally Posted by raethorn
pickey mate was this car sat in a lay by up by crickley hill about 5 o'clock maybe a month or so ago avsoloutly smoking its tits off
he was up there dogging, flys undone and allsorts, lol
Old 12-11-2006, 16:39   #22 (permalink)
Shyne
Shyne's Avatar
Friction smoke them????
Suggest: Lubricant of some sort to avoid burns!
Shyne is offline   Reply With Quote
Old 13-11-2006, 11:47   #23 (permalink)
coley
i remember seeing that, me and raeth went past and just seen it smoking. glad its all coming together now. mech repairs any good for drilling out bolts from the turbo were the elbow attaches?
coley is offline   Reply With Quote
Old 13-11-2006, 12:33   #24 (permalink)
Pikey
Pikey's Avatar
Mech can do all sorts of shit
I bashed the lip down so my wheels have a bit more clearance now, but tbh it needs extensive remodelling with a substantially bigger hammer
For now I think I'll have to remove the spacers so I can drive it safely and clear the oil out of it.
Old 18-11-2006, 18:20   #25 (permalink)
Pikey
Pikey's Avatar
ok this is how it looks with the rears fitted with 205/55/16s, and the front spacers removed:
I think I might fit some smaller front spacers, maybe 15mm instead of 25mm. It'll still need some bashing though, still touches at full lock as it is!
Old 21-11-2006, 10:53   #26 (permalink)
Pikey
Pikey's Avatar
Hmm maybe all the talk of dogging has put people off looking at this thread
SRB have a group-buy on Cusco roll cages on the SXOC at the moment, so I'm going to get in on that to save the bother of making one myself and the expense of getting a H-Dev one. That'll be here in January/February
Old 21-11-2006, 10:57   #27 (permalink)
playworker
12A Powered
Those new wheels look fooking awesome dude
I'm tempted by the Cusco GB as well, just need to figure out how to afford it
playworker is offline   Reply With Quote
Old 21-11-2006, 10:58   #28 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
Cusco jobs arnt D1-spec and poss not Eurodrift spec next yr, anyone know for sure?
As if they were id bloody get one too...
Old 21-11-2006, 11:05   #29 (permalink)
Pikey
Pikey's Avatar
15% deposit now, you wont need to pay the balance until February
Is that because they dont have door bars, or they're made of the wrong material? Whichever, any roll cage is better than no roll cage, and chances are I'll not be needing one anyway (to compete in Eurodrift novice class). Also, if it turns out that I need one made of a higher spec material I can use the Cusco one as a template
edit - and I'll be adding the rear diagonal and door bars myself
Old 21-11-2006, 11:12   #30 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
Haha, just read the thread and had EXACTLY the same plan.
I dont want pussy-spec doorbars anyhow, i want badass ones that makes it nigh on inpossible to get in and out the car, like on my cossie
Old 21-11-2006, 11:16   #31 (permalink)
Mattyboi
InitialD erby
Mattyboi's Avatar
The cars looking tough jeff, soo low! I need to lower mine lots more but its cold outside
Old 21-11-2006, 11:22   #32 (permalink)
Pikey
Pikey's Avatar
I'd like X-bars ideally, but they're a pain to make. Probably end up with one at the feet and one higher up. And one across the rear strut tops as well as a rear diagonal - saves me buying a strut brace
Old 21-11-2006, 11:37   #33 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
I wanted X's too, they that hard? Oh well, just loads of other random ones then
My Cossie one didnt have an X, just rear diagonal and a single but quite high (ie about halfway up the door ) straight door bar.
Old 21-11-2006, 14:00   #34 (permalink)
Pikey
Pikey's Avatar
Both the Safety21 and the Cusco ones are made from CDS (cold drawn seamless) tubing, so they'll comply with regs - just need door bars to comply with the 2006 D1 regs. I think that's right anyway
Old 26-11-2006, 17:30   #35 (permalink)
Pikey
Pikey's Avatar
Did a bit of today, and now the wheels dont rub on full lock like they used to
I need 10mm spacers at least, to cover the end of the wheelstuds as at the moment without spacers they're going rusty. I think 10mm spacers should be alright, but I think Im just going to have to admit I made a mistake buying 225/50 tyres when I should have bought something like a 45 or even a 40 profile! When budget allows I might have them swapped, but it's a bit gutting knowing you spent £150 on the wrong size tyres
I was gonna spray the bonnet matt black today too, but I was working on it at a friend's house and their neighbour is THE BIGGEST GAYLORD in the whole entire world, and threatened to call the police etc if I sprayed the car in case I got overspray on his shitheap N reg Mazda estate
I managed to fix my boost gauge aswell. It hadnt been working properly ever since the turbo blew, and now I know why - the pipe was FULL of oil, lol, so I cleared it out and now it's working fine again
Old 05-12-2006, 12:15   #36 (permalink)
Pikey
Pikey's Avatar
Er, right, so, my engine has blown up
Managed all of 25 miles since fitting the new T25 Although I think the turbo is fine so I'm not blaming that at all. I think it must have been trying to drive it home from Curborough with a broken turbo that killed it
Anyway, all stop on this until I find a new engine. Hopefully will be back on the road soon - it'll only be one evening to remove the old engine and slot in a new one if I go for a straight swap. It's just the timing that's UNBELIEVABLE - I sold the Mercedes on Thursday, taxed the SX on Friday, blew it up on Saturday
Old 05-12-2006, 12:17   #37 (permalink)
playworker
12A Powered
Gutted man! What was it - bottom end gone?
Old 05-12-2006, 12:18   #38 (permalink)
Dori Edd
BONGED
Dori Edd's Avatar
Lol!! Unlucky dude.
Don't do a straight swap though, put something stupid in that'll take ages to do and ultimately be pointless but incredibly cool nonetheless.
Like a Kent or an A series.
Dori Edd is offline   Reply With Quote
Old 05-12-2006, 12:26   #39 (permalink)
Pikey
Pikey's Avatar
Yeh - clanking like a mofo it was
Then it cut out and wouldnt start again
Old 05-12-2006, 12:32   #40 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
Originally Posted by Dori Edd
Lol!! Unlucky dude.
Yeah man, 1700 X-flow on a single 38DGAS, awesome
