03-01-2007, 21:57
| #21 (permalink) |
| hope to drift soon | i got it off this guy on ebay http://search.ebay.co.uk/_W0QQsassZleadshamQQhtZ-1 item number was 230065902566 thanks damo |
11-01-2007, 19:47
| #23 (permalink) |
| hope to drift soon | yeah was it any good? i have mine here now and its looking very good! just though i would say...... i now have my cams yey ![]() Here is my little spec list of my car this is everything i have and im not spending any more on it for a bit now dets to pay. it will be on the road in about 2-3weeks so watch this space!!!!!! Engine Mods:- wiseco forged pistons 1mm over size (1853cc from 1809cc) Pauter con Rods custom inletmanifold 60mm throttle body custom throttle cable Custom Tubular Manifold Greddy TD06-20g Turbo Turbosmart 48mm External Wastegate Custom S/S Exhaust System 3" all the way 1.9mm metal head gasket tomei poncams 256 in and ext tomei valve springs tomei adjustable cam pulles Bosch fuel pump 534cc sard injectors adjustable fuel presure regulator and gauge cooling:- apex big alloy rad and a random fan gtr intercooler with custom s/s pipe work Transmission:- rebuilt rb20/ca18 combo gearbox OS Giken Super single clutch kit s14 lsd diff apex type 2 short shift Interior Mods:- stripped out Corbeau boss seats passanger side Cobra Suzuka seat driver side Cobra pro harness (4point and 3inch all round) Blitz i.d racing 60mm oil temp gauge Blitz i.d racing 60mm water temp gauge Blitz i.d racing 60mm oil presure gauge Chassis Mods:- norrisdesigns/apex shell Nismo rear sub frame bushes kyb's AGX shocks with apex -40mm springs Whiteline anti roll bars front and rear front/rear strut braces Stainless steering bush from driftworks Brake Mods:- 315mm bmw m3 front discs with 200sx s14 4pot calipers 300zx z32 rear brake setup Goodridge Braided Hoses all round 5.1 dot brake fluid electronics:- E0-1 boost controller VEMS standalone ecu, with l/c, knock, egt, anti lag, maf and wideband lambda all from VEMS V3.3 Standalone Engine Management System (thanks phatbob) Exteria:- Jun side skirts jun rear 3/4 panels vader c3 front bumper 150cm wide carbon spoiler home made canards custom bonnet vent Personalised plate k 550 hp (for sale) alloys wheels for day to day and show 17" black Work RYVER. 17"x8" ET35 for front and 17"x9" ET38 for the rear for track day and drifting a slection of 4 x gold, 4 x white, 4 x silver 17 x 7.5 allround (thats alot of 17" lol) oil's Silkolene Pro S 10w50 Race Oil for engine Redline MT90 Gearbox Oil gearbox Last edited by damo_s13 : 11-03-2007 at 22:31. |
06-02-2007, 17:23
| #29 (permalink) |
| dorifto kingu! ![]() Join Date: Jul 2004 Location: NW Kent
| I've got a feeling it was from a Mustang or something similarly big-engined? Might be lying though. I usually am... Nice work Damo. I'm keen to see what figures you end up with, especially with the VEMS, TD06 plus that plenum. Seems like a really nice spec |
09-02-2007, 22:46
| #33 (permalink) |
| hope to drift soon | had a few hours on the s13 again to day just getting the little jobs out of the way before the engine gose in if my dad ever finishs messing with my bottom end :whip: so i have long stud in one side but not the other on the rear and 2 of them were different pitch so change the studs and fitter my H&R spacers 25mm of lovelyness please not the 300zx rear brakes pulling new studs through ![]() ![]() new H&R spacers on ![]() |
22-02-2007, 19:39
| #35 (permalink) |
| hope to drift soon | small update with afew pictures but lots to come ![]() engine, gearbox is now in and also is my 4point harness etc... all in im hoping to finish the vems wiring tomorrow but time will tellmy new water pipe work setup as using a custom inletmanifold ![]() note the new shiny adaptor for the new bosch knock sensor ![]() damo |
24-02-2007, 00:41
| #36 (permalink) |
| hope to drift soon | well its getting there now ![]() engine in but not manifold or turbo yet as i need clean hands for that lol (heat wraping lol) ![]() had to get this in ![]() ![]() I then started to put the vems wiring together and in injectors and water temp ![]() cas added ![]() Tps added ![]() looking a little neater ![]() ran the wiring into the passangers side ![]() start to add the map ![]() map sensor added but need to sort a proper mount for this yet ![]() right so that leaves me knock sensor, mat, and the coils to do tomorrow. i could have got more done but then it click that the adaptor i made for the knock sensor was me trying to fit the mat sensor in the knock senors place oops lol so i needed to make something elss. should not be long now before its running. then it a nice drive down to see jez at Horsham Developments for mapping as i dont trust my skill/knowalge when the boost start going up |
25-02-2007, 17:05
| #37 (permalink) |
| hope to drift soon | cool thanks bud. Did a little more work. did not get to much done tho as i spent 2hours sorting the bits out i needed to fit my new blitz i.d race gauges ![]() ![]() Right back to the wiring. after afew calls to phatbob sorting out a few wiring questions i had about the cas and coil on plug setup. i got the knock sensor wired, fitted and all the coil on plug wiring sorted almost. no pics tho sorry. so then onto mat sensor. i had to do some work to the throttle body to fit this but was all good and now its fitted ![]() ![]() ![]() how it looked when i left last night getting there but i need to do a clean up lol![]() thants it for now. iv'e got a few things to sort out wiring wise now got to dig the manual out for. fuel pump relay info, pos legs for coils and injectors then think thats about it all in oh plus the egt wiring but thats only 2wires damo |
27-02-2007, 11:38
| #38 (permalink) |
| hope to drift soon | well i cant beleive how long this is taking me to wirer up im almost done now tho im getting close. before i start i would just like to give phatbob a big thanks as i have had him on the fone alot ![]() right i have just the last few wires to crimp at the ecu end all the others are in ![]() onto the pictures. i only took afew as was trying to getting on with the job coil on plugs wiring started ![]() earth wiring from the vems ![]() ![]() wiring in the passanger foot well ![]() ![]() And now how the engine is now with all the wiring in ![]() ![]() damo |
