Old 09-05-2007, 14:39   #221 (permalink)
ringer
Trackday Films
ringer's Avatar
Not much longer and you'll have to change the thread to 'sorry, I'm 17'
Great stuff.
ringer is offline   Reply With Quote
Old 09-05-2007, 16:49   #222 (permalink)
koukiboy
Send a message via MSN to koukiboy
@ my 17th birthday yes
koukiboy is offline   Reply With Quote
Old 09-05-2007, 17:01   #223 (permalink)
Mad Cas
Libertine
Mad Cas's Avatar
I have wondered if the french police really were that gay since I saw 'Taxi' and 'Taxi 2'. Now I know!
I think the best option for building your engine might be to take the block crank and eagle rods to an engineering shop, they will measure the crank journals and con rod/main bearings and can then grade and order the correct bearings.
Its the kind of thing you can do at home if you have the right equipment, but often quicker/cheaper to take it there and get it sorted.
Mad Cas is offline   Reply With Quote
Old 09-05-2007, 21:58   #224 (permalink)
max_sd
max_sd's Avatar
Send a message via MSN to max_sd
ive got it he has a mysterious benefactor who love the drifting scene and has given the now 17yr old loads of money to buil this awsum car. lol
keep up with the good work and would love to see a video on you tube of that thing drifting
max_sd is offline   Reply With Quote
Old 10-05-2007, 12:07   #225 (permalink)
koukiboy
The only video I have :
Old 10-05-2007, 22:55   #226 (permalink)
max_sd
max_sd's Avatar
sounds awsum and keep the good work up.
Old 11-05-2007, 17:03   #227 (permalink)
koukiboy
Thanks
Old 16-05-2007, 19:31   #228 (permalink)
koukiboy
A little up with my new order :
Circuit Sport braided hoses
Elbow struds
OEM Water Pump
OEM Oil Pump
Old 21-05-2007, 20:42   #229 (permalink)
catalanu
catalanu's Avatar
What's new with that beast?
catalanu is offline   Reply With Quote
Old 21-05-2007, 21:03   #230 (permalink)
koukiboy
Only that lol
Hellowww le people (lire pipol) !!!
Shiny cam cover :
Old spark plugs :
My pretty engine
And the Eristic complete engine gasket set :
News next week with my new parts
Old 21-05-2007, 21:04   #231 (permalink)
koukiboy
Oups, double posted, sorry lol
Old 21-05-2007, 21:25   #232 (permalink)
Motary
Send a message via MSN to Motary
Oh snapz double post!
Nice progress!
Motary is offline   Reply With Quote
Old 24-05-2007, 17:05   #233 (permalink)
fegizii
fegizii's Avatar
Why do you need an oil pump and a water pump if the engine is running fine?
fegizii is offline   Reply With Quote
Old 24-05-2007, 17:25   #234 (permalink)
catalanu
catalanu's Avatar
Who says "it works fine"?This car will be for drift not for mall shopping man.In drifting the engine is vrey hard used(i don't know exactly the corect word) and needs very good cooling.
Old 24-05-2007, 17:37   #235 (permalink)
koukiboy
The water pump is 40 000 km old and the oil pump is from the built => 160 000 km... Have to be new for the reason explain above
Old 25-05-2007, 13:04   #236 (permalink)
fegizii
fegizii's Avatar
Yeah i'm fully aware of that, my S14 has 150,000 km on the clock. But you can't replace everything that migth brake, otherwise you need a new car... if it's not broken why fix it?
Rather get a oil temp gauge, an oil pressure gauge an a water temp gauge. If there is a failure in the cooling system the gauges will tell you.
Old 25-05-2007, 13:25   #237 (permalink)
Keefe
Yoddle FTW
Keefe's Avatar
Thats the silliest thing i've heard for a while.
Keefe is offline   Reply With Quote
Old 25-05-2007, 14:19   #238 (permalink)
fegizii
fegizii's Avatar
What part exactly? - edit: Don't want to hijack the thread so if yuo have questions Keefe PM me.
Old 25-05-2007, 14:24   #239 (permalink)
Keefe
Yoddle FTW
Keefe's Avatar
Fail. Upgrade to avoid it breaking in future and causing more money and time to repair damage that could have easily been avoided.
If your waiting until the gauges tell you the cooling system has failed then its too late. The damage has been done. Damage which again, could have been avoided had you not being a skinflint and built the car properly to start with.
Old 25-05-2007, 14:45   #240 (permalink)
TurboGrinch
TurboGrinch's Avatar
Send a message via ICQ to TurboGrinch Send a message via MSN to TurboGrinch
never touch a running system - is what i always use to say.
BUT if spend thousands of euros / pounds on engine, suspension ... why not spend some quid for new pumps. i would replace them too if i would build an engine like koukibay is doing.
nice project, i like project threads like this keep on coming pics
Martin
TurboGrinch is offline   Reply With Quote
