10-11-2007, 01:57
| #261 (permalink) |
| gripper | Mad props. I'm always amazed at someone who can do their own work to their car. I really don't know anything about the insides, but I'm slowly learning! =D Good news is, you don't need to know how it works to drive it insanely, I smellahhaha. Last edited by double_helix : 10-11-2007 at 01:57. Reason: misspelt word |
11-01-2008, 20:50
| #268 (permalink) |
| touge runner | Today I went to Nissan for my parts, but the OEM circlips were already here ... It's nothing, it wil help me wherever else Nissan f***cked me!!! They sell main bearings as a pair, but con rod bearings as ONE PIECE!!!!!!!! So I had to order 4 more And they are the same as Nismo ones, but only con rod bearings, main Nismo and Nissan bearings are not the same!!!![]() |
15-01-2008, 21:22
| #269 (permalink) |
| touge runner | A little begining of the rebuild : OEM Main Bearings OUT ![]() ![]() And new ones ![]() ![]() ![]() ![]() A little shiny paint ![]() ![]() Mains ![]() The crankshaft in ![]() ![]() ![]() I just have to do a "plastiguage" (I don't know how it means in english lol) to be sure of bearing grades Next : GReddy stage 2 264° cams, HKS GT2835 turbo, braided lines for it, SS manifold and few other bits |
15-02-2008, 22:27
| #271 (permalink) |
| touge runner | Got a little head work done (polishing was done only on the exhaust side) : ![]() ![]() ![]() ![]() Almost finished, just to clean it up a little : ![]() ![]() ![]() ![]() ![]() Tomei (pink ) cam sprocket (only for the exhaust camshaft, I'll keep the NVCS on the intake ![]() And some other stuff : Braided turbo lines : ![]() Z32 Bosch Fuel Filter (GIANT )![]() GReddy radiator cap (the good one this time) and a recirculation fitting for my HKS SSQV : ![]() And the Energy Master Bushing Kit (poly bushes for all the suspension arms) : ![]() ![]() Now, I juste have to find some time to work on it ![]() |
28-03-2008, 19:02
| #272 (permalink) |
| touge runner | Some news... not very good to read… Thanks to the last owner... ![]() ![]() So, I found these great things in my engine block!!! : - 2 shims (1 in a head’s corner and 1 in the oil pan…) ; - 1 guide in the OIL PUMP… dead… ; ![]() Oil strainer also dead … ![]() So, like always, I’m so so lucky... But I’m glad I'm rebuilding her, if I drove her few km more… The engine would be definitely dead… Now, the rebuild!!! 1st piston ![]() 2nd piston ![]() ![]() Both last ![]() Screwed at torque, play was checked etc etc… ![]() Rear oil seal ![]() Hummmmm, so beautiful when it’s new and forged! ![]() Non-ended head ![]() Because with my first valve remover, that wasn’t very easy… ![]() ![]() Now with the facelifted second generation valve remover… It’s a way easier ![]() ![]() So, that’s all for the moment. Now : I have to order last bits (like the oil strainer, some more poly bushes, turbo, manifold etc), rebuild everything and start that fu***g b**ch ![]() ![]() |
30-03-2008, 20:44
| #274 (permalink) |
| touge runner | Thanks a lot Sea Squirrel This week end (on Saturday), I went to visit a school for my studies... So I didn't had any time to work on the engine... But but but, I assembled it just to see how is it look like when it's "finished" ![]() ![]() ![]() ![]() ![]() ![]() I think it begins to look like a real engine ![]() ![]() |
01-04-2008, 01:47
| #278 (permalink) |
| tail slider Join Date: Feb 2008
| my eyes r busted....this mustve took me a hour to read every single post and im speechless....the amount of money u have poured into this car and ur not even using it yet...this is going to be a complete weapon....![]() lucky lucky boy ![]() ![]() |
29-04-2008, 20:27
| #280 (permalink) |
| touge runner | Some news!!! Innovate LC-1 Wideband ![]() ![]() ![]() - OEM Nissan strainer ; - Gauge holder ; - EMPI inner tie rod dust boot ; ![]() - Energy steering rack bushings. ![]() HKB 350mm steering wheel (will be certainly respraid) ![]() I did some painting... ![]() ... in a good colour :wack : And the "A" significate : I just started to do my driver license!!!!!!!!! ![]() Once done ![]() ![]() It’s so cute :wack : My damper pulley ![]() ![]() Also in my garden ![]() ![]() Intake valves with Brian Crower valve springs ans titanium retainers ![]() ![]() My head on my home made head support ![]() ![]() Rocker arms and lifters in ![]() ![]() A little bit of cutting ![]() Instalation of the steering rack bushings ![]() Another little package from USA ![]() From the left to the right - GReddy Breather Tank ; - NRG Hub and Quick Release ; - 2 HKS 60mm mecanical gauges (Pressure and Temperature) ; And under that we have - breather tank adapter ; - GReddy sandwich plate ; - and an OEM Nissan oil return hose for the turbo ![]() ![]() |
