Old 29-04-2008, 20:27   #281 (permalink)
koukiboy
Send a message via MSN to koukiboy
I directly installed my sandwich plate on
Oil/water feeds
Oil/water lines
And that’s gonna look like that with my 2 HKS gauges
The End
P.S. : the thread is in two parts
koukiboy is offline   Reply With Quote
Old 29-04-2008, 20:35   #282 (permalink)
Mattyboi
InitialD erby
Mattyboi's Avatar
Loving this thread, keep up the good work
Old 29-04-2008, 21:14   #283 (permalink)
griffo20022
BMW Driver...
griffo20022's Avatar
Jeezus what an awsome project! Fantastic build on the engine!
Old 29-04-2008, 21:17   #284 (permalink)
vtec mini clubman
vtec mini clubman's Avatar
Send a message via MSN to vtec mini clubman
Frickin awsome thread
vtec mini clubman is offline   Reply With Quote
Old 29-04-2008, 22:10   #285 (permalink)
xborninthefightx
xborninthefightx's Avatar
Nice one dude, make sure you get that license before you finish the car
Old 29-04-2008, 22:24   #286 (permalink)
koukiboy
Thanks guys Concerniing the licence, I think I'll get it in September Just when I guess I'm gonna finish my S14
Old 29-04-2008, 22:35   #287 (permalink)
xborninthefightx
It would be a great present to yourself when you pass
Old 29-04-2008, 22:47   #288 (permalink)
koukiboy
Yep, my 18th birthday is in September, 8th
Old 30-04-2008, 00:08   #289 (permalink)
PeterT
arse bandit
PeterT's Avatar
great progress, and good luck on getting your license!
what kind of power do u expect from the engine onece built?
PeterT is online now   Reply With Quote
Old 30-04-2008, 11:50   #290 (permalink)
koukiboy
Thanks ^^ I think I'll begin at a safe 260 - 300 BHP (still got the T28...) and after I guess something between 380 - 420 BHP, depends of the turbo (GT2876R or GT3071R or GT3076R) and the final engine management if I change it (now I have a japanese ECU - just to start it weel with my new parts - tuned for Nismo 555's, Z32 MAF, stage 1 PONCAMS 260° and HKS GT2540 - same as Garrett GT2876R - turbo, and my friend is running exactly the same spec's ECU on his S14a with a GT3071R at 1.2b, and it pull hard!!! and always with a very good AFR and not too much ?? clic clic ??) and I also have my GReddy e-Manage Ultimate But these are only few numbers you know, we'll see when it will be done and when I'll take it on the dyno
Old 01-05-2008, 14:21   #291 (permalink)
koukiboy
My last order
Nismo horn button
Naprec chain
8 new OEM Nissan rocker arms
A little "Y" pipe for my fuel pressure regulator
And for the "JDM Touch" to have the "JDM Attitude" a Tein bottle oppener
Old 05-05-2008, 18:51   #292 (permalink)
ProjectoD
haha
I didn't know you're here to !
ProjectoD is offline   Reply With Quote
Old 09-05-2008, 12:47   #293 (permalink)
koukiboy
I'm everywhere I can be, so everywhere in the world
Old 29-06-2008, 13:00   #294 (permalink)
koukiboy
Hi
It's been a long time without any news in UK from me Sorry
First, I changed few silentblocks at school
And I received my Tein Bottle Opener
Old 29-06-2008, 13:00   #295 (permalink)
koukiboy
Then, I cut my hair
And I also worked a little on the S14...
First, I began to work on my homemade Nismo Power Brace
Then, I stopped it because I so wanted to end the rebuild od my engine
Timing chain :
- Right = OEM
- Left = Naprec
New VS old rocker arms
Try to find where is the new one
Old 29-06-2008, 13:01   #296 (permalink)
koukiboy
And I put the head on
New rocker arms on
I tried to save as I can my camshaft's journal :ghey:
GReddy camshafts on with Tomei assy lube
My poor chinese GRedy oil pan copy :censored:
OK, now, it's good...
And then, I needed to put some paste on my screw because the hole in the oil pan is dead...
Old 29-06-2008, 13:01   #297 (permalink)
koukiboy
Almost finished
It needs a little bit of cutting to clear the rocker arm stoppers
So beautiful
So I began the cutting with the help of my Dremel
Then, I thought where can I put the GReddy breather tank
And I put one of the little tubes (I don't know the word in english sorry )
And now, the engine
Old 29-06-2008, 13:02   #298 (permalink)
koukiboy
OK, I received my HKS GT3037 turbo kit from Japan and I replaced the engine into my S14
Before :
After :
What, that's not my S14 ?? Oh I thougt it during few minutes
Admit, there is a little similarity, doesn't it ??
Old 29-06-2008, 13:04   #299 (permalink)
koukiboy
Last weekend, I get down the engine from the stand engine
And now, Nismo Super Coppermix!!!
The flywheel
And I put the flywheel on
Old 29-06-2008, 13:04   #300 (permalink)
koukiboy
Nismo fork pivot on
The new silentblock
Nismo POWAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!!!!!!!!! !!!
And, some roses
