Old 06-08-2008, 10:32   #321 (permalink)
koukiboy
Send a message via MSN to koukiboy
I went on Sunday to my garage, and I had only 2 hours for any work... So I decided to repair my Breather Tank adapter fitting
It looked like this before. There was only one little thread on it...
So I took a 6mm screw, I cut it to the original specification and then I did a 2mm hole in it (like in the original fitting) and I enlarged the entry to 3mm.
Then, I did a 5mm hole in the screw's head and I tapped it with a M6 tap.
That's it
Now, just a bit of liquid gasket and a little bit of red Loctite
Done We can't see anything, it's like the original
The SR20
The Breather Tank plugged onto the adapter
And for a great end, my dirty Silvia in my very clean garage
koukiboy is offline   Reply With Quote
Old 19-09-2008, 20:49   #322 (permalink)
koukiboy
I've got my 60mm wastegate!!!!!!!!
BTW, I also welded my home made Power Brace's reinforcements
The interior...
Pink vacuum silicone hoses
The spayer bar
To follow on next week :
- Garrett GT3076R, V-Band A/R.78 T3 Twin Scroll turbine housing, Anti-surge compressor housing, oil restrictor, V-Band downpipe flange + its clamp, T3 Divided inlet gasket and oil return gasket ;
- Pink 16mm x 2m silicone hose for my oil catch tank ;
- 2x black silicone reducers : 4" => 3" and 2.5" => 2" 90° ;
- CXRacing 2" aluminium radiator ;
- 3" top mount elbow.
That's all for now
Old 19-09-2008, 21:12   #323 (permalink)
cr4zy drift3r
cr4zy drift3r's Avatar
Nice project, im a little younger than you but soon ill be buying an s13 or a s14,
nice project looking forward for more updates.
cr4zy drift3r is offline   Reply With Quote
Old 22-09-2008, 19:01   #324 (permalink)
koukiboy
Thanks
I did a little bit of work this weekend
First, I wanted to see how a wastegate is working
Then, I catch my poor manifold... The inside... With a big hole and a long crack...
Second crack...
And here, the inside almost like new I still have some work to do on it, but the hole and the crack don't exist forever
Like new, isn't it ??
On the SR
The machine
It touches... But I wanted it to touch
I did the same position that inside
The angle of the steering column
It would be like that, in theory
But I decided to do it otherwise
Old 22-09-2008, 19:02   #325 (permalink)
koukiboy
So I cut the 50mm flange, I took a 2.25" SS IC piping, I adapted it to the manifold and I welded it on It's not that beautiful, but there will be some heat wrap on it
Manifold + WG
But when I wanted to bolt at 100% the manifold to the head, the V-Band flange is touching the frame... So I have a little bit more work to do on it
The last one on the SR So HOT!!! Now I'm just waiting for my Garrett GT3076R (Twin T3 Scroll A/R.78) that would be sent tomorrow by UPS, so I guess I'll have it for Friday to bolt it It would be awesome
Old 22-09-2008, 19:20   #326 (permalink)
Johnson
Johnson's Avatar
dude that top mount rocks..like the top mount !!! is it custom or bought somwhere?
Johnson is offline   Reply With Quote
Old 22-09-2008, 19:33   #327 (permalink)
koukiboy
I bought the manifold from Damo on this forum (thanks again if you read me )
Old 25-09-2008, 18:03   #328 (permalink)
koukiboy
The 3" elbow :
Equiped with 2 O2 bungs, and works on LHD cars
I love it
My beautiful CXRacing 2" full aluminium core radiator :
And now, pure SEX !!!!!!
Specs :
Compressor:
- Wheel: 76.2mm w/ 56 trim
- Housing A/R: .60 a/r
- Housing Style: 4" anti-surge inlet w/ 2" outlet
Turbine / Exhaust:
- Wheel: 60mm w/ 84 trim
- Housing A/R: A/R.78
- Turbine Housing Style: T3 Twin Scroll divided w/ 3" v-band
Center Section:
- Dual Stainless Steel Ball Bearings
- Oil & Water Cooled
I just have to rotate the turbine housing
Old 25-09-2008, 19:06   #329 (permalink)
Corey_XR4I
XR4I 24V FTW
Corey_XR4I's Avatar
ive loved this build from the start dude, keep at it man....
be nice to see it actually drifting tho but i know what its like to start something
Old 25-09-2008, 20:41   #330 (permalink)
Chris_200SX
-NightWalkers-
Chris_200SX's Avatar
looking good, but may be a silly question but how is the elbow going to fit onto the back of the turbo? looks like you havent got the correct elbo fitting for the turbo.
Chris_200SX is offline   Reply With Quote
Old 25-09-2008, 21:31   #331 (permalink)
koukiboy
I'm gonna weld a 3" V-Band flange onto the elbow I didn't have any flange choice when I bought it
Old 25-09-2008, 21:37   #332 (permalink)
Chris_200SX
-NightWalkers-
ahhh see thought it was a silly question , keep up the good work buddy
Old 26-09-2008, 00:51   #333 (permalink)
MKdrifter
MKdrifter's Avatar
WOW Bonjour Koukiboy/Raphaël, comment ca va j'ais pris 2 hours pour lire depuis le debut de cette histoire magnifique, et je ne sais vraiment pas quoi dire. Tu est tres douer, pas comme moi j'aurai peur de casser quelque chose. Moi aussi j'aime le drifting et j'ai 18 ans mais toi tu as un monstre dans ton garage c'est incroyable et je parle francais mais j'habite en angleterre. Je ne crois toujours pas que tu as fait tout cela avec ta propre main c'est incroyable, maintenant j'espere que tu vas faire attention quand tu la roule A bientot.
MKdrifter is offline   Reply With Quote
Old 26-09-2008, 01:00   #334 (permalink)
MKdrifter
MKdrifter's Avatar
Et j'ai oublier de te demander conbien tu as depenser et comment tu connais a faire tous ca parce que ton connaisance de mechanics est incroyable pour quelqu'un de ton age et je n'ais plus a dire que t'est super.
Old 26-09-2008, 04:36   #335 (permalink)
DONUTDurifto
Enjoy that CXRacing radiator. I have one and my car overheats like a mother fricker.
DONUTDurifto is offline   Reply With Quote
Old 26-09-2008, 12:58   #336 (permalink)
koukiboy
Merci MKdrifter
I learned a lot of everything I know in the different forums I'm logged in And I also learned some bits at school
And yes, I did everything by myself
The CXRacing rad is very good. I have a friend who's got one, and he's very proud of it !
Old 08-11-2008, 20:31   #337 (permalink)
koukiboy
Let’s go for a little update
The little snail on my worktable...
... and under the hood now
Putting the HKS Water Temp Sensor adapter on the water neck
Drilled to 10mm and tapped to M12 x 1.25
Done
Then, I did a little mounting plate for the oil catch tank
The SR
The CXRacing radiatior was a little bit twisted, so I danced few minutes on it
The manifold was sold as a T3 and is a T4, so I need an adaptor flange from T4 to T3...
So, I bought one on ebay
T3 Side
T4 Side
Old 08-11-2008, 20:39   #338 (permalink)
koukiboy
I just came back from my holidays I did some work but not much because I had a lot of work in the garden...
Firstable, 3 nice pics of the turbo on the manifold Shit of manifold, the flange is not flat... And screws doesn't match holes... So I had to use 8mm bolts and to do my best to match the adapter with the manifold flange. But now, it rocks !!!
I still didn't finished to mount my wastegate...
My piping being modified
My piping being welded
Elbow in da place
T4 => T3 adapter in
And a global view of my SR and the S14 before I left it alone in my cold garage
Now I just need to finish my wastegate and my intake piping
Old 08-11-2008, 21:25   #339 (permalink)
Tony240Z
Tony240Z's Avatar
Send a message via ICQ to Tony240Z Send a message via AIM to Tony240Z Send a message via Skype™ to Tony240Z
Sorry if it's a silly question, but did you rebore or even hone the block before installing the forged pistons? What was the odometer reading when you pulled the motor out?
I'm not as young as you are (I'm almost 20), but I also have a project that started when I was 16. It's nowhere near like yours though, since it's an almost 40 year old Datsun, and I took a different approach than you - the first thing that I ordered was a rollcage, just to be sure that I won't kill myself if I hit something...
Hate to be a pessimist, but instead of ordering all those shiny new parts I'd take care of the body stiffness. Cusco makes nice rollcages that don't go through the dashboard. I think that any kind of safety equipment should be worth considering now.
Tony240Z is offline   Reply With Quote
Old 08-11-2008, 22:10   #340 (permalink)
koukiboy
Pistons are the original size (86mm) But I hone a bit the cylinders And it had 156 000km on the clock.
For the roll cage, there won't be one. It's totally forbidden in a street car in France
And I'm an optimist, I won't hit anyone
Ktorego Datsuna masz ??
