Old 12-12-2006, 22:10   #41 (permalink)
Motary
Send a message via MSN to Motary
Amazing, you're 16 and tune a S14 and not doing it cheap either, darn I have a lada and I'm a year older (actually got it when i was 16).
Good luck with it
I'd have a cheaper car for doing it first time, no worries when wrecking it, but I couldn't afford S14 at the moment anyway
Motary is offline   Reply With Quote
Old 12-12-2006, 22:13   #42 (permalink)
astraboy
Yer, fookin' Volvoooo!
Send a message via MSN to astraboy
where did you get the tissue box cover from?
astraboy.
astraboy is offline   Reply With Quote
Old 13-12-2006, 13:56   #43 (permalink)
Shyne
Shyne's Avatar
Starting early. good work fella.
Not liking the Neon vybe though, thats just me!!!
Best of luck with it and keep the updates rolling
Shyne is offline   Reply With Quote
Old 13-12-2006, 17:35   #44 (permalink)
riddler
riddler's Avatar
Send a message via MSN to riddler
lookin good
EDIT: i really need to earn more money
riddler is offline   Reply With Quote
Old 13-12-2006, 18:36   #45 (permalink)
LiGhTnInG
Doricomotion
LiGhTnInG's Avatar
Why?
Why?
Why?
...and why do you have a pink neon?
Welcome to DW by the way. Bonjourno.
Old 13-12-2006, 18:48   #46 (permalink)
koukiboy
Send a message via MSN to koukiboy
1st Why ? = to start my engine...
2nd Why ? = to cover my box...
3rd Why ? = because I like this colour...
4th Why ? = because I won it at the 2006 Paris Tuning Show
Thank you all for your congratulations
koukiboy is offline   Reply With Quote
Old 14-12-2006, 13:17   #47 (permalink)
koukiboy
I hesitate between :
1) Top Mount turbo kit (XS-Power) + FMIC and after (maybe in 1 or 2 years) V-Mount ;
2) Garrett GT2876R (AR C => 0.70 ; AR T => 0.64) in top mount + FMIC and after (maybe in 1 or 2 years) V-Mount ;
3) Garrett GT2871R (AR C => 0.60 ; AR T => 0.64) in top mount + FMIC and after (maybe in 1 or 2 years) V-Mount ;
4) Garrett GT2871R (AR C => 0.60 ; AR T => 0.64) in low mount + FMIC ;
Please help me...
Old 14-12-2006, 13:51   #48 (permalink)
Shyne
Shyne's Avatar
Ahhh-haaaa turbo tech, lovely territory, you'll find the 2876 to have a harsh surge line, if you get copies of the Compressor maps you can plot the boost points at a given pressure to see approx where you can expect boost at that pressure. The first rpm range you calculate which breaks through the surge line will be the approx RPM that you see the given pressure at.
The only variant then will be turbine hsngs, as most turbo manfs don't publicise there turbine maps.
Old 14-12-2006, 15:25   #49 (permalink)
VIP.DRFT
VIP.DRFT's Avatar
The 2876 will have more lag than a 2871 but will pull harder to the redline, so it depends on what you want. With just a FMIC expect 330-350hp i guess from the 2871, not sure about the 2876, but apparently the 2871 spools extremely fast. As well the 0.64 can reach 400hp, with the right cams, upgrade intake manifold etc. Stick with low mount as well, so you don't have to worry about oil/water lines and all that stuff. Unless you're prepared to pay out for all that stuff, both turbos bolt right on the the stock SR manifold. For now, stick with the FMIC as it is more of a bolt on (not exactly but bear with me), instead of the v-mount which requires alot of cutting, extra brackets etc, and unless you can do it yourself you'll pay too much. If you're worried about airflow put some fans on the the radiator, i found a thread somewhere on how to make a cheap fan setup, (using universal fans or something) i can't find it right now,
i'll look for it after school (i'm only 15, 16 in february, getting my car in march hopefully a R32 skyline GTS-t 4dr!! We can import them for $5000CAN here, gotta love canada, other than footy isn't very popular here)
good luck with it all, hope that helped
(feel free to correct me if any of that is wrong, anything i know is just from forums, friends cars or magazines that is until i get my car =)
VIP.DRFT is offline   Reply With Quote
Old 14-12-2006, 17:38   #50 (permalink)
koukiboy
Good luck with your R32 skyline GTS-t 4dr
My project is a drift/track project. I need a turbo who spools fast and who's big (up to 400-450hp). The 2871 spools very fast with a FMIC. So I think I'll try the Garrett GT2876R (AR C => 0.70 ; AR T => 0.64) in top mount + a V-Mount IC (who, I think, should spool very fast too with it)
Tell me if I'm wrong
Thanks
Old 14-12-2006, 18:39   #51 (permalink)
mase1000
mase1000's Avatar
i know i should have staied at home with my olds
good on ya mate
mase1000 is offline   Reply With Quote
Old 14-12-2006, 21:28   #52 (permalink)
koukiboy
Here is, I think, my future IC for the V-Mount :
And here is the Garrett GT2876R :
Old 14-12-2006, 22:02   #53 (permalink)
Dex
kut!
Dex's Avatar
Send a message via MSN to Dex
try to get an fmic that taff has, ideal end tanks
Old 14-12-2006, 22:57   #54 (permalink)
DollyKean
CHUNKY MONKEY
DollyKean's Avatar
Send a message via ICQ to DollyKean Send a message via MSN to DollyKean Send a message via Skype™ to DollyKean
Hey just read all the things done!! Good job
But I'm french too and I don't have understand why you're using this "thing" for the starter button and what's the nismo stuf?
DollyKean is offline   Reply With Quote
Old 15-12-2006, 00:23   #55 (permalink)
VIP.DRFT
VIP.DRFT's Avatar
Thanks! Should be a fun car to go to and from school with + learn to drift.
If you're looking for 400-450hp, just get the 0.84A/R GT2871R, i believe it can make this power and will still spool very fast. The GT2876R will provide your 400-450 at lower boost thus have a large scope for more power later (boost is addictive )
v-mount or FMIC doesn't matter, won't spool it faster, though a v-mount is obviously more efficient.
try to find something like this
the guy got it custom made by Forge Motorsport.
sideways.taff is the guy doing the crazy SR20 GTS Skyline with v-mount, he can probly help you out,
where in paris are you? (jw cause i've been there, lovely city)
Old 16-12-2006, 12:56   #56 (permalink)
koukiboy
Thanks guys! I'm not far from Gare du Nord, Montmartre.
Old 16-12-2006, 13:15   #57 (permalink)
DollyKean
CHUNKY MONKEY
DollyKean's Avatar
a 93 boy!!!
Old 16-12-2006, 13:16   #58 (permalink)
sr20-power
sr20-power's Avatar
forge do that intercooler if i remember right
i thought you wast alowed to modifiy cars in france
sr20-power is offline   Reply With Quote
Old 16-12-2006, 13:23   #59 (permalink)
DollyKean
CHUNKY MONKEY
DollyKean's Avatar
You're right, We are not allowed to modify our cars but unlike other countries like yours, We don't have to declare the mods.
So we could swap like , passing the mot and having a normal insurance.
The only problem with have it's the police when they are clever and if we are involved in a accident....
But with a sleeper, no prob
Old 16-12-2006, 15:26   #60 (permalink)
VIP.DRFT
VIP.DRFT's Avatar
wow, thats the station where i came in from england i think.... well first you go to Calais from england, then to paris if i remember right, and i stayed right near Monmartre.
with not being allowed to modify cars, are all modified cars completely sleepers? Whats the rule/law for that?
anyways, hope all goes well with your car, anymore updates in the works?
