Old 24-01-2007, 00:55   #1 (permalink)
suprmek1
Dori Mechanic
suprmek1's Avatar
Will it be ready in time
Ill start with a little bit of back ground into it. Being only 21 I thought I'd never afford it but I brought my 1st 200 in aug off EGAY for £340, it had been ported induction kit dump valve and ss exhaust. Wanted to put it on the road but was to rotten so after alot of welding I gave up and got another for £320, it had a bad engine so simple swap and some solid bushes got an mot happy days........
Well i quickly got bored so put on a ss manifold boost valve and stage 1 chip was great till bang few weeks later botom ends had gone
So I decided I was going to go all out head first and do it properly so got some money together and this is how im doing.
Car as i got it (face lift)
PLEASE KEEP POSTS ON TOPIC I KNOW WHAT THESE THREADS CAN GET LIKE I WANT MINE TIDY
will post pics as parts arrive
Engine:
nismo enginge mounts
new bearings and gaskets
ACL pistons
H beam conrods
blitz spark plugs
ported head
Tomei 260' 10.25 lift in/ex procams
Tomei cam pulleys
Tomei valve springs
Jun retainers
Cometic 1.9mm metal HG
ARP head stud and nut kit
Mocal oil cooler kit
koyo ali Rad
Inlet and exhaust:
Yashio factory exhaust manifold
Garrett GT3076R
s14 twin chamber turbo elbow
s14 3" down pipe
Apex 4"thick FMIC
Apex cat back exhaust
ported inlet manifold with tomei throttle body
SARD R2D2 dump valve
Fueling:
Bosch 044 fuel pump
High flow billet alloy race fuel filter
SARD fuel pressure regulator
1000cc fuel injectors
Aeroquip alloy piping and fittings
Modified fuel rail to take Aeroquip fittings
Interior/safety:
coberu revolution bucket seats
luke 6 point harnesses
fully stripped
Sound deadening removed
cut out weight
fire extinguisher
Bonnet + boot pins
Cut off switch
Multi point roll cage
Drive train:
standard box
Uprated g/box mounts
Apex one piece alloy propshaft
Braided clutch hoseNorris designs prototype twin plate clutch
5stud conversion front and rear
Nismo 2 way LSD
suspension:
Whiteline anti roll bar front
Whiteline anti roll bar rear
Apex alignment kit
Apex solid subframe bushes
Apex front strut brace
Apex coilovers
Electronics:
Apexi AVCR 200
OMEX 700 management
Brakes:
R32 GTR calipers
280mm red dot discs
braided front lines
braided rear lines
z32 BMC
z32 rear discs
z32 rear calipers
tilton brake bias valve
hydrolic hand brake
Body:
Charge speed carbon Boot
Bonnet
+50mm rear over fenders
Side skirts
Random make +30mm front fenders
Jun front bummper
.[/color]
Hope to get it ready to race at the begining of the season in march so alot of hard graft to come.
Interior being stripped out
Old 24-01-2007, 01:03   #2 (permalink)
Dori Edd
BONGED
Dori Edd's Avatar
Heavy
Unlucky with the previous 200 incarnations, looks like this should be a bit more solid though
And welcome to Driftworks
when you say 2 ltr, is it an SR20, or a beefed CA18?
Dori Edd is offline   Reply With Quote
Old 24-01-2007, 01:11   #3 (permalink)
suprmek1
Dori Mechanic
suprmek1's Avatar
its a beefed CA18DET up to a CA21DET
Ive brought myself a trailer and started taking the engine apart and removing it. Was out in the rain hidding under the bonnet so not may pics but here goes.
engine befor
Removed wings and front end
Cut out slam pannel for ease will remove blok on sat when i can get hold of the engine crane from work.
Old 24-01-2007, 01:36   #4 (permalink)
suprmek1
Dori Mechanic
suprmek1's Avatar
Prepping bonnet (aka making it lighter) I cut around the edge of the bonnet frame with my trusty mate the grinder then used a long bread knife to cut off the rubber bonding.
Discarded bit
top skin left of the bonnet
Fitting flush bonnet pins. I used the points where the support rubbers are removed them then drilled up through the bonnet.
drilled up through marked outline for catch
cut out with angle grinder and jig saw
fit drill holes for bolts and hey presto repete other side and done.
Old 24-01-2007, 16:57   #5 (permalink)
mammoth
what have you used to make it 2.1l?
looking forward to seeing it when its finished.
mammoth is offline   Reply With Quote
Old 24-01-2007, 23:56   #6 (permalink)
suprmek1
Dori Mechanic
suprmek1's Avatar
Got a 2ltr stroker kit then with the over size and custom pistons and the head work it will be up to 2.1
Got a little more done today sprayed the bonnet cut out for tow eye and removed the spoiler lots of rust to sort.
fitted toe eye
marked out and cut
tidyed up hole
Ground edges clean and tidyed up. Cleaned it up with soapy water then rubbed down with 220 grit
while being sprayed
finished refitted bonnet pins sealed on with mastic.
State of the boot, lights i fitted and my private plate is registered.
Ordered some cabide die bits for porting the head and a few othe little bits from Mr snap on.
Snap on bits i got today free cup and cap with floor mat and seat and wing covers.
Old 25-01-2007, 00:22   #7 (permalink)
suprmek1
Dori Mechanic
suprmek1's Avatar
A few bits from drift works soon to be fitted
Old 25-01-2007, 11:53   #8 (permalink)
LiGhTnInG
Doricomotion
LiGhTnInG's Avatar
Looking good.
How come your doing the work on the trailer?
Old 25-01-2007, 12:04   #9 (permalink)
Nick
potato king
Send a message via MSN to Nick
trailer is easier than jack and axle stands.
Nick is offline   Reply With Quote
Old 25-01-2007, 18:28   #10 (permalink)
mammoth
where did you get the stroker kit from?
are you getting the pistons made locally?
Old 25-01-2007, 19:51   #11 (permalink)
paul_k10_lx
Send a message via MSN to paul_k10_lx
did u get excited over ur cooler
paul_k10_lx is offline   Reply With Quote
Old 25-01-2007, 20:49   #12 (permalink)
Hammond
oh, snap!
Top, top work mate, but I fooking hate those lights!
Old 25-01-2007, 23:52   #13 (permalink)
suprmek1
Dori Mechanic
suprmek1's Avatar
its on the trailer to save space and is off to have 8 point chromemoly cage put in soon so save me loading it up then trouble is cant open the doors so in through the boot lol.
norris stroker kit JE pistons to my own spec
I cant see the pic did i put the wrong 1 up ment to be fire extinguisher catch tank etc
Old 26-01-2007, 00:13   #14 (permalink)
suprmek1
Dori Mechanic
suprmek1's Avatar
Dint get much done today as only had a few hours befor work and was sorting out builders for my garage for my new drifter ordered some more parts tho should be here shortly ill have all the parts for the 8th of feb lots of pics then.
Cut out the rust. wont go into to much detail as you seen it all done on every s13 thread ever lol.
cut out the frame work.
all cut off sunny isnt it though the boot.
Cut out for boot latch again using points from supports.
Washed the surface off used card to support bak of hole and fibre filled over it
done the same but around the bonnet pin out line will finish it all off tomo hopefully.
got the head stripped down will get some pics up soon. got to get the ports machined to match gaskets then will be porting full myself full posts on this will be done soon.
Old 26-01-2007, 00:19   #15 (permalink)
Baba
A Super Slider
Baba's Avatar
I will be keeping an eye on this one
Can I ask why you chose to build a 2ltr ca instead of going SR? Dont get me wrong I have a ca too and will be keeping it.
Old 26-01-2007, 01:03   #16 (permalink)
suprmek1
Dori Mechanic
suprmek1's Avatar
CA Is so much better NOT HAVING THE ARGUEMENT YET AGAIN but it is
The SR 2ltr isnt as good as the CA 2ltr so id end up stroking a SR to 2.2 any how, and insurance reasons they wont know its a 2ltr crank
Old 26-01-2007, 03:06   #17 (permalink)
Dragon Force
Toast Lover!!
Dragon Force's Avatar
OH, your arse must be sore after the Strap on man dug his money hungry cock in your arse.
Mate I feel sorry for your ring peice.
Nice project mate, don't buy Strap on though, your getting raped!!
And please remove the gash rear lights, please!!
Dragon Force is offline   Reply With Quote
Old 26-01-2007, 23:58   #18 (permalink)
suprmek1
Dori Mechanic
suprmek1's Avatar
I like the lights unless any one wants to donate some kouki ones they stay. Dint do to much today cut the doors down and fin the boot will do a big update on sunday.
Id rather be ass rapped by snap on than pay his rediculous prices but the tools are well worth it when you use them every day got even more today!
Old 28-01-2007, 20:56   #19 (permalink)
suprmek1
Dori Mechanic
suprmek1's Avatar
Been a long weekend but got a fair bit done:
Got the doors cut down, boot finished, preped the interior for seam welding, booked the car in for its full 8 point cage on the 17th of feb cutting it close.
so hears the pics and how i did it all.
first i stripped the doors down from spare car.
cut around edge just leaving for the door card poppers to clip in.
cut out crash bar this is what was removed.
I have to say dont do this on a road car unless its fully caged because it takes out all your side impact.
Finished off the boot masked it off.
it started to rain so i made a cover for myself and sprayed it.
finished spray
drilled hole for bolts siliconed around edge and bolted in.
Drilled a pilot hole down though the latch, drilled out to the right size, bolt in pin, had to bend into position which took a while then tightend up when all sorted out.
Cut out old latch bracket.
Old 28-01-2007, 21:52   #20 (permalink)
suprmek1
Dori Mechanic
suprmek1's Avatar
On to the interior:
tools used. and the all important hifi.
Stripped out interior.
Drilled out the spots on any un needed brackets, then chisled off.
Brushed on the nitro morse paint stripper
left to blister as per intructions. brush in more this only took 5 min such an easy way to it.
While it had to soak in for 20 min i got the white spirit out and removed the rest or the tar soaked it with a sponge, srcapped it off then scrubbed it off with the sponge. wipped over with paper towel.
Got the wire brusah on the drill cost £3 from b&q bargin cleaned off pealing paint then swept up and wiped clean with white spirit.
didnt take long and i had the whole car done just my battery ran out so ill get some more pics tomorro
