Old 02-04-2008, 14:19   #41 (permalink)
Phil
7JZGTE
Phil's Avatar
We had another serious misfire once the engine went back in.. My heart sank, and we did a compression test. That wasn't the problem, so I jumped about like a madman reveling in the fact I didn't have to take the fcukin thing out again .
Then we had an O-ring fail on an injector, which would normally be a 5 minute job, but because of the lack of access with the engine pushed back so far it took about an hour. We still had the misfire, so took the NGK 9's out, and swapped them for some 7's to see if they had just been fouled with it running so badly. The sparkplugs are changeable, but it's not a pleasant job when the engines red hot, and it takes 30 minutes each time. Misfires still there, and we find a problem with the VEMS using a TPS based map, and it had been fcuked up by removing and re-installing the throttle cable . So we have it idling nicely now (at about 1am) and I make the mistake of thinking 'finally, something positive has happened'. Then we find that as we go up the rev range, the good old crank and cam signals start spiking everywhere and we do need a trigger wheel based signal after all..
The car is 99% complete, but there's so many loose ends that need tieing up to get the car compliant with EDC rules, that I really really needed this engine running correctly for the inspiration to finish it.. I don't mind having had 3 hours sleep a night for the past week if something positive were to happen as a result of it, but as it stands I'm about to push the thing off a bridge
Phil is offline   Reply With Quote
Old 19-04-2008, 21:04   #42 (permalink)
jammie654s13
Dorifto!
jammie654s13's Avatar
any updates phil?
jammie654s13 is offline   Reply With Quote
Old 21-04-2008, 22:28   #43 (permalink)
Phil
7JZGTE
Phil's Avatar
She's running again after taking the front end off the engine to modify the crank sprocket.. It's currently running on the map from our 1JZ powered R32, so is understandably running like pants. I'm just doing a few more jobs whilst it's on the ramps tomorrow, and I'll be booking it in for some mapping .
Old 21-04-2008, 22:30   #44 (permalink)
caged
climbing frame builder
caged's Avatar
yay!
caged is offline   Reply With Quote
Old 22-04-2008, 00:12   #45 (permalink)
Mattyboi
InitialD erby
Mattyboi's Avatar
Glad to hear man! Looked like a caged beast today when i saw it, you could see the fire in its eyes!
Old 22-04-2008, 07:50   #46 (permalink)
overdrift-Johan
overdrift-Johan's Avatar
Send a message via MSN to overdrift-Johan
sweet! congratz!
overdrift-Johan is offline   Reply With Quote
Old 23-04-2008, 16:57   #47 (permalink)
SVTuner
SVTuner's Avatar
Question
this is 1 hell of a project car!
but 1 Question is the car going to rum those do-luck wheels for drifting?
because they REALY look the N*TS
keep up the GODLY work boys
SVTuner is offline   Reply With Quote
Old 29-04-2008, 22:37   #48 (permalink)
xborninthefightx
xborninthefightx's Avatar
Hows it going, havnt heard anything in a while.
Old 30-04-2008, 22:47   #49 (permalink)
Phil
7JZGTE
Phil's Avatar
Small update:
After chasing our tails with this crank trigger problem for far to long, we made the same modifications to the OEM crank trigger that we did to get our 1JZR32 working. It of course DIDN'T work . We were getting a jumpy RPM signal, and at 4800rpm it would read 25,500rpm .
So knowing that there's really no physical difference between our two engines and two ECU's, we exactly replicated the R32's wiring for the crank trigger, pulled the sensor out, found it to have picked up a load of swarf (it's a magnet), cleaned it. Which cured the jumpy rev needle issue, but not the massive jump in signal after 4800rpm.
So, dispite being incredibly busy, and very stressed out, the imortal Phatbob set up an exact replica of our car on his testbed. He found it caused the same problem we were having.. He suggest a change in a setting that I believe tells the ECU the space between each of the teeth on the crank trigger.
Myself and James have just been back to the workshop, and within 5 minutes had it running cleanly with no flittering RPM needle, and a clean sweep right to 7000rpm.. Can I get a WOOOOOOHOOOOOO!!!!
Next stage, start from scratch on the dyno again. Another update soon .. Something positive just happened.. I might get a good nights sleep..
Yeah, they are our drift wheels
Old 30-04-2008, 22:49   #50 (permalink)
caged
caged's Avatar
yay!
Old 30-04-2008, 22:50   #51 (permalink)
Car Media
Send a message via MSN to Car Media
Woooooohoooooo!!!!
Car Media is offline   Reply With Quote
Old 30-04-2008, 22:51   #52 (permalink)
retrodan
cant skid
retrodan's Avatar
go to sleep dude, cuddle up to the good lady!!! stress does not solve issues!! ur car will be mint!!!
Old 30-04-2008, 22:51   #53 (permalink)
superclarkey
Mood=Amazing
superclarkey's Avatar
well done Phil
Old 30-04-2008, 22:51   #54 (permalink)
Dori Mat
MINTY S13
Dori Mat's Avatar
thats great news phil
Dori Mat is offline   Reply With Quote
Old 30-04-2008, 22:52   #55 (permalink)
cranky
Well done bob
cranky is offline   Reply With Quote
Old 30-04-2008, 22:57   #56 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
Its been a funny old day... Glad its running now, I've drowned the pain from my stomach ulcer with 3 pints of Stella
We've got that setup nailed now for sure - Steveo, Niall and Mr Dunn will have an easier time of it now... yeah right
Old 30-04-2008, 22:58   #57 (permalink)
Car Media
Big well done to PHATBOB
Old 30-04-2008, 23:01   #58 (permalink)
damo_s13
hope to drift soon
damo_s13's Avatar
Send a message via MSN to damo_s13
nice one well done lads
damo_s13 is offline   Reply With Quote
Old 30-04-2008, 23:14   #59 (permalink)
Melissa
Drift Widow
Melissa's Avatar
amen to that lol.
oh yeah...... S15 working WWWWWWWWWOOOOOOOOOOOHHHHOOOOOOOOOOOOO!!!!!!
Melissa is offline   Reply With Quote
Old 30-04-2008, 23:32   #60 (permalink)
Irishtwincam
Tá me sasta :D
Irishtwincam's Avatar
PhatBob FTMFW!
Irishtwincam is offline   Reply With Quote
