| | Thread Tools | Display Modes |
28-08-2008, 15:07
| #181 (permalink) |
| dorifto kingu! | thanks mate as it stands now, it ows me about £23K give or take. but that includes buying the car and the import taxes, wich came to about £5K. luckily i've been able to do nearly all the spannering myself, and that's saved me a boatload of monies, and i owe bjørn (SWR) a MAAAAAAAAAHOOOOOOOOOOOOSSSSSSSIIIIIIIIIIVEEEEE!!!! thanks for all the work and late nights he's put in. his work is top notch and extremly impressive, and his knowlege knows no boundries just found the spec list: spec: engine: SR20DET JE pistons EAGLE rods stock crank brian crower stage 3 cams adjustable camsprockets stock valves and springs SWR ported head block and head decked internal water and oil channels ported top-mount turbo manifold Turbonetics t04e 60 trim air-to-water intercooler 3" hard pipes 3" throttlebody HKS style plenum 38mm wg stock injectors (primary) billet fuelrail FOMOCO green injectors (secondary) fuel pressure regulater DW oilfilter reloc oilfilter kit and external cooler DW servo oil cooler DW upgraded oilsump aluminium radiator FZR 1000 radiator for water-to-air IC DTA engine managment system walbro 255 fuelpump oil catchtank 3" straight through exhaust from turbo, de-cat biltema 25L/M waterpump K&N 800hp airfilter running on E85 suspension: apex coilovers with adjustable top mounts tein tie rods tein tie end rods whiteline front and rear anti-roll bar DW 4 arm kit DW poly bushes all round DW front and rear strutbrace transmission: F1 paddle clutch lighter flywheel bara 600% uprated lsd interior: snap off suede steeringwheel sabelt racer duo xl bucket seats sabelt seatframes sabelt 4 point belts autometer 5" speedo 260km/h " 5" tacho " oil temp " oil pressure " water temp " tank gauge " wideband AFR " volt meter " fuel pressure hks boost meter 6 point rollcage DW hydro wand sound deadening removed golf mk1 heater custom panels custom wire loom sparco main power cut-off retrimmed doorcards made to fit rollcage exterior: W9 replica bodykit carbon bonnet carbon rear wing 17x8/8.5" zito hubs federal 595 tires panasport c7 splitrims 16" for practice full respray inside and out. Last edited by smokey : 28-08-2008 at 15:28. |
16-09-2008, 22:07
| #186 (permalink) |
| doughnutter Join Date: Jul 2008 Location: Tln, Estonia
| dont' you tnink that monifold is to short?! or the turbo runs good ont hat..i was thinking about buying the same one..cose i very whant top mount..?! what A/R you turbo got and from what RPM does it stat * blowing*.. BTW: nice ride m8 ![]() ![]() ![]() |
16-09-2008, 22:37
| #187 (permalink) | ||
| gripper Join Date: Oct 2007 Location: Norway
Driving it it has 7 psi at 3000 rpm,at 40% throttle... Still mapping,and not hooked up enough fuel to it to run more boost yet. At 7 psi now it runs just like the previous build did at 13.. that was 214 whp. | ||
17-09-2008, 11:36
| #188 (permalink) |
| so what aproc amount of HP you plan to take from that engine with that spec..i think aprox 350 or 400?!..or not?..i just wonder about the turbo as i dont have worked with TURBONETICS only GARRET..do you know what Garet have the same turbo spec..i think gt28 or 28r or Turbonetics is even better? |
17-09-2008, 12:15
| #189 (permalink) | |
17-09-2008, 20:50
| #191 (permalink) | |
It might heat up after 4-5 minutes of drifting,some say... So what? After 5 min the run is well over anyway. | |
