01-12-2007, 01:59
| #182 (permalink) | ||
| spl dori master | Quote:
01-12-2007, 12:57
| #183 (permalink) |
| spl dori master Join Date: Nov 2004 Location: Northweazy
| iv checked the thor kit out now - have you purchased the hydraulic release bearing yet? - did you get it from them or find someone else? it looks like a TILTON item . . . and the adapter plate to fit it? if you want i can send you some pics of a RX7 relaese fork its pretty much a free standing unit which will need some sort of adapter to fit it but not as complicated as the Tilton style just a bar of metal realy will also need a slave cylinder mount (bit of bent steel) and hole in the bellhousing (grinder)! but these parts are allmost free (brother cas will be interested at least) |
14-12-2007, 23:08
| #191 (permalink) |
| A few of my bits came through today Dellow belhousing - a bit rough but cheap and came quick with fork and relase bearing ![]() Dellow flywheel much heavier than MR2 item and still needs ring gear fitted my car is a lot heavier though - however still a general waste of good money ![]() |
