Old 24-04-2008, 10:58   #381 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
Originally Posted by SteveDunn View Post
Yeah, cows without disguises on are frowned on 'round these parts.
But horses dressed in natty reflective jogging suits are acceptable it seems.
Old 24-04-2008, 12:42   #382 (permalink)
Paul-S13
Paul-S13's Avatar
Bob,
Is it looking like Steve needs to get a trigger wheel for the VEMS setup now?
Paul-S13 is offline   Reply With Quote
Old 24-04-2008, 13:59   #383 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
Originally Posted by Paul-S13 View Post
Bob,
As discussed previously the standard trigger needs to be modified.
What have you seen that has lead you to the trigger wheel conclusion?
Rob
Old 24-04-2008, 14:46   #384 (permalink)
Will_DW
Will_DW's Avatar
Looking good Steve, Look forward to see it in action
Old 24-04-2008, 15:24   #385 (permalink)
Paul-S13
Paul-S13's Avatar
Rob
I think it was a sleepy read of the misfire probs of the DW S15, pay no attention mate, my brain is fried!
Old 25-04-2008, 13:45   #386 (permalink)
Mad Cas
Libertine
Mad Cas's Avatar
Why the long face?
Edit: Its the official team D:mon horse! look at its eyes! and reflective graphics!
Mad Cas is offline   Reply With Quote
Old 25-04-2008, 14:37   #387 (permalink)
SteveDunn
I can't see...
SteveDunn's Avatar
Send a message via MSN to SteveDunn
That's my ride for this years competitions...
SteveDunn is offline   Reply With Quote
Old 25-04-2008, 16:05   #388 (permalink)
Nelo
Resident Alco
Nelo's Avatar
Send a message via MSN to Nelo
Originally Posted by Mad Cas View Post
Why the long face?
Think I spot a set of Tein Super Street horseshoes as well underneath that baby?
Nelo is offline   Reply With Quote
Old 25-04-2008, 16:08   #389 (permalink)
SteveDunn
I can't see...
SteveDunn's Avatar
Set of D2's actually, hence why it's stood at a pissed angle and looks like its had its teeth rattled out...
Old 13-05-2008, 13:08   #390 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
Turns out you were right, perhaps those voices in your sleep could benefit mankind.
The 12 tooth crank trigger is a write-off from our point of view, with the S15 we had the joy of self-advancing timing which we can only put down to the trigger being subject to interference (or some strange inductance or capacitance in the system effecting a time/phase shift as RPM and therefore frequency and voltage increase). Why this didnt effect James' car and the other 1JZs I don't know, but thankfully a simple answer is available, the 36-1 trigger from these people:
Trigger-Wheels
Old 13-05-2008, 17:33   #391 (permalink)
SteveDunn
I can't see...
SteveDunn's Avatar
My wiring bitch Phil is currently sorting me out with a trigger wheel He's also found some sparkie shiney things to use too. I think he's been in contact with you about this stuff. It's all greek to me I'm afraid
Brm brm race car go fast.
Old 13-05-2008, 17:35   #392 (permalink)
SteveDunn
I can't see...
SteveDunn's Avatar
Oh, someone buy my PS13 so that I can finish this fricking whore of a car!!!
Old 13-05-2008, 17:35   #393 (permalink)
Phil LS
Bob i can get a 60-2 sorted easily enough. Will that be ok? Might be able to get a 36-1 machined into the standard front pulley, although obviously not as good, just unable to get a 36-1 sorted yet....
Phil LS is offline   Reply With Quote
Old 13-05-2008, 17:37   #394 (permalink)
Phil LS
ooh just clicked ur link. they look good.... will have to get steve to buy one of them then.
steve buy one of them next....(joke, need to take ur spare engine somewhere to get a bracket made up btw) then decidewhat diameter wheel to go with)
can we use teh standard sensor (i havnt looked if it's hall effect or reluctor yet)
Old 13-05-2008, 18:20   #395 (permalink)
PhatBob
Mr Sir
PhatBob's Avatar
60-2 triggers are often troublesome, those 36-1 setups are tried and tested - and you cant beat that.
We think that part of the problem with the standard sensor is that they're such high impedence that they effectively make the entire crank sensor an aerial.
Personally I'd go for the V8 coil pack kit as it has plugs and and sensors:
Trigger-Wheels
And then your choice of trigger wheel:
Trigger-Wheels
The talk to Mr Steveo about the magic that he did with this:
Old 14-05-2008, 19:06   #396 (permalink)
Paul-S13
Paul-S13's Avatar
Cool if Phil is sorting that then, still struggling with brake and clutch master cylinders at the mo.
Old 15-05-2008, 11:44   #397 (permalink)
Paul-S13
Paul-S13's Avatar
Errr?
Old 19-05-2008, 10:55   #398 (permalink)
SteveDunn
I can't see...
SteveDunn's Avatar
Paul and Chris (Moby-Dick) came down this past weekend to get some brainstorming done.
I have a little (big) list in my unit of stuff that needs to be done to get the car working and MOT'able, as I'm going to the Nurburgring at the end of July and I HAVE to take this car.
Problem being is that I've pretty much run out of money. I have £10 left to my name right now and 1.5 weeks until payday, where I'll pay off my overdraft and that's about it. Sadly this means that my project has slipped into "budget" mode for the time being.
My number one concern was the fact that we'd decided to go the pedal box route, as it was easiest option with the space issues we have (ie, can't fit brake booster and clutch master cylinder in the bay as the engine is in the way). The one that I wanted (after trying another) is £600. I don't have £600. Whilst mulling over this, I went to Tesco to get us some munchies. I came back to find Paul had done this...
He's cut the bulkhead and raised the clutch master cylinder up a bit. We have to extend the pedal in the car to make it normal position again, but that's no biggy. The brake booster also now fits, thanks to some chopping of the cam cover. This has saved me a shitload of money, and means I can use the standard pedals, which are nice to use if im honest.
So, out came the engine and box again for more fine adjustments...
On these went.
And some balls in Moby-Dick's face.
Tonight the car goes to have its manifolds fabricated. It comes back in a week, then instantly gets shipped off to Phil LS to be wired up finally and forevreererly. Hoorah.
Fingers crossed it will be alive in less than a month.
Old 19-05-2008, 20:58   #399 (permalink)
Jason
Onevia Vert
Jason's Avatar
Send a message via MSN to Jason
i really hope so!! im getting tired of pushing it in and out of the unit x x x
Jason is offline   Reply With Quote
Old 19-05-2008, 21:13   #400 (permalink)
Beezy
I AM MCLOVIN
Beezy's Avatar
Go steve!!!!
About time you need this car done and out!!!
You getting the manifolds done at the place in Hothfield?
