Old 18-06-2008, 22:18   #301 (permalink)
sideways.taff
-NightWalkers-
sideways.taff's Avatar
Right, the radiator has gone in and is mounted on tabs at the bottom, I still need to make tabs at the top but its so tight in there they aren't really needed lol but better to be safe than sorry.
With the rad in I thought it best to mount the valance, so I cut the two centre mounts off and offered it up.. christ its tighter than I thought, there's 2mm clearance at the sides and about 20mm in the middle.. more punch and flare required! With all the grilles and lights back in it looks totally standard!
I dont have pics because I left the camera in the house and it was raining too hard for me to be bothered getting wet just for the sake of a couple of pics!
I've also converted the hubs to studs rather than bolts.. Makes life a whole lot easier. Time will tell whether they are man enough for the job!
sideways.taff is online now   Reply With Quote
Old 18-06-2008, 22:21   #302 (permalink)
Hammond
oh, snap!
Taff, word on the sheep vine is that you've done an R234567GTS-R front end swap!?
Old 18-06-2008, 22:21   #303 (permalink)
e30 of Death
Sounds good dude just make sure there is a bit of crash protection there for tyres/cones as the valance's don't do much in terms of protection. You'll especially wanna make sure there is a bar at the bottom front edge of the rad, without one there my rad would've been toast on it's first outing at Teesside.
Old 18-06-2008, 22:25   #304 (permalink)
sideways.taff
-NightWalkers-
Yeh, don't worry I have plans for some protection bars, just need to squeeze them in there somewhere.
Old 19-06-2008, 04:55   #305 (permalink)
sammysideways
sounds cool. good work fella
prob a dumb question on my part how/what you use to convert to studs? really wanna do this on e36
Old 19-06-2008, 08:00   #306 (permalink)
Lee
Skint
Lee's Avatar
Send a message via MSN to Lee
Professional Motorsport Parts, Spares & Rally Equipment from Rally Design
on there sam,
Lee is offline   Reply With Quote
Old 19-06-2008, 10:05   #307 (permalink)
sideways.taff
-NightWalkers-
As the man Lee said, I got them from Rally Design yesterday. They just screw into the original hubs and the small machined section without thread tightens up against the hub allowing you to get the nut back off. Pretty cool really and makes changing wheels quickly a hell of a lot easier than faffing around trying to match up bolt holes.
Old 19-06-2008, 10:29   #308 (permalink)
cefiro_drifta
mad pointing munkey
cefiro_drifta's Avatar
if i were u taff i would maybe, if u can, stick a weld or two on the back of those studs to stop them coming out. I had the same on my 4 & 5 stud convertor hubs and even with lock tight and julians strong hand tightening them on to the hub after about 5 wheel changes the studs came out when undoin the nuts ...
Old 19-06-2008, 10:52   #309 (permalink)
sideways.taff
-NightWalkers-
Good plan spearchucker.
Old 19-06-2008, 12:04   #310 (permalink)
ringer
Trackday Films
ringer's Avatar
hehe, I know I'm gonna have to show some restraint with this one lol!
Whatever.....
ringer is offline   Reply With Quote
Old 19-06-2008, 12:18   #311 (permalink)
sideways.taff
-NightWalkers-
I'm showing lots of restraint.. I would have gone bonkers with a mental cage, and a newer engine with lots more powers... hahaha so shush.
Old 19-06-2008, 12:20   #312 (permalink)
e30 of Death
Bigger engine Bryn Do it.... Do it.... Do it....
Old 19-06-2008, 12:28   #313 (permalink)
sideways.taff
-NightWalkers-
hahaha.. you going to fund this bigger engine then Mike?! No? Didn't think so.. be happy with a mapped M30 then!
Old 19-06-2008, 12:40   #314 (permalink)
e30 of Death
Ok Ok, well mine is a monster anyway and yours will be better so it's a win-win-win-win situation
Old 26-06-2008, 20:56   #315 (permalink)
sideways.taff
-NightWalkers-
Some pics for Karan to show how I've modded things and made brackets to fit the rad:
Split the bumper away from the heavy crap behind it:
Started making mounts for the now lightweight bumper..
And got busy with the hole saw. Holes behind the number plate for track/practice days.
Old 26-06-2008, 21:19   #316 (permalink)
Silverfang
No longer K1
I see you got some blanking plates in the end, did that ad on E30Zone do the trick?
Old 26-06-2008, 22:10   #317 (permalink)
Karan
nice job bryn!
i started doing mine today i have a MIG coming tmro in the post so once ive worked out how to MIG stuff ill get it together finally
decided on an s14 apex 56mm rad, not as good quality as the koyo on my s14 but should be ok.
heres a few so far, ive done it so that the top bar will be removable and have the top rad mounting tabs on it too....
i managed to keep the lower horizontal section and it needs to be notched out about an inch for the lower rad hose which will go under the notched horizontal section.
http://img266.imageshack.us/img266/9076/dsc02329ff9.jpg
http://img389.imageshack.us/img389/1301/dsc02335ws3.jpg
http://img389.imageshack.us/img389/1616/dsc02337li8.jpg
Karan is offline   Reply With Quote
Old 26-06-2008, 22:29   #318 (permalink)
e30 of Death
Pah, dash to the standard front end stuff, make it all outta box! Saved me loads of room around the front end, fits my massive e28 radiator no problems, and gives a handy front jacking point!
No proper pics I've just realised, but I have this one showing my engine bay (airbox removed to clean it up)...
Old 26-06-2008, 22:35   #319 (permalink)
Dex
kut!
Dex's Avatar
Send a message via MSN to Dex
wow thats your rad? looks small dude!
Old 26-06-2008, 22:56   #320 (permalink)
e30 of Death
Mine? Nah dawg, it's full length of the front of the car, proper massive just not very thick (ooer). It's lasted me fine every drift day so far so it's obviously big enough
