Old 03-07-2008, 08:20   #341 (permalink)
Jord
F*ck your EGO.
Jord's Avatar
Did I miss the bit where you bought coilovers?
Old 03-07-2008, 10:11   #342 (permalink)
sideways.taff
-NightWalkers-
sideways.taff's Avatar
Yeh probably (Taff*tune E30 Touring) but the post wasn't exactly the most informative. I sort of made them myself using a coilover tube from Rallydesign that are usually used on Ford Escort coilover conversions, then got some spring platforms for them and used an old spring that was in one of my storage boxes but the fronts are too long though, so need to get around to measuring them and ordering shorter ones. Then I just screwed in some Bilstein shocks and got some camber top plates. I need to sell the camber top plates really and get some less chunky ones.
Old 03-07-2008, 16:30   #343 (permalink)
Paster
Hi mate, just read from page one, how plans change eh...That already looks sooooo good, Rear arch/wheels are spot on, top marks, also got half way thru your R324 thread a while back, what a monster!!! You have some serious skills fair play
Paster is offline   Reply With Quote
Old 03-07-2008, 16:47   #344 (permalink)
sideways.taff
-NightWalkers-
Nope, just a severe case of automotive induced O.C.D. or Brainaids as Bon likes to call it.
Old 03-07-2008, 16:54   #345 (permalink)
retrodan
smashes aero
retrodan's Avatar
why oh why ddddddddddd lyla
Old 03-07-2008, 21:19   #346 (permalink)
Paster
Brainaids or not, all seems so well prep'd will be nice when its done
Old 03-07-2008, 21:29   #347 (permalink)
sideways.taff
-NightWalkers-
Finally got round to getting the steering column UJ's off and stripped them down, degreased them and cut the rubber off and solid mounted the two parts together.
Revamped brake servo went back on too
More lock to come once my dads been to his mates place to make me some spacers, he's going to make some rack mount spacers too. This lock isn't completely full lock as it kept bouncing back a bit when I let go of the wheel so its not a true representation of where it actually is at the moment.
Painted up the impaling spike mounts too, those frickers are gonna be deadly!!
On an aside I've cobbled together a Nissan suspension bush extractor out of a length of threaded bar, a 22mm socket, a left over section of rollcage tube from the R324 and two old Alfa bush inserts! Works a treat and pulls the whole lot out in one go without needing to burn anything or cut any sleeves! Result.. should mean that replacing the knackered bushes on the GTR should be easy tomorrow night so I can get it booked in for an MOT next week in time to make the trip to EDC@Pod!
Old 03-07-2008, 22:27   #348 (permalink)
gaz_moose
buy my car
how many times have you bashed your shin on those spikes?
i thought about telling mike about escort struts but could not be arsed.
Old 03-07-2008, 22:35   #349 (permalink)
sideways.taff
-NightWalkers-
I've kept away from the spikes so far lol. I've only had them on the car for a few hours in total so I've not left myself open to self-impalement.
Yeh the Escort struts are 2" so as near as damn it to the 51mm BMW struts, a bit of wet and dry on them and some lube and they slid on a treat. Leaves plenty of room for adjustment and spring length changes.
Old 03-07-2008, 22:56   #350 (permalink)
e30 of Death
My problem is not adjustability etc, it's just that my upper spring seat hits the top of the strut housing so I'd need to cut the housing down and/or get some posh top mounts.
Old 03-07-2008, 23:15   #351 (permalink)
sideways.taff
-NightWalkers-
Yeh, thats the problem I've currently got along with the fact that the springs are too long. You can see that the lower spring platforms are right at the bottom and that there's about an inch and a half of travel left in the shock, so if I can lose about 3/4rs of an inch off that travel and leave some in there with a shorter spring where the lower platforms are sat half way up the adjustment then I'll be running lower. Combine that with some machine work to the top spring seat and some new slimline topmounts and I should be able to drop it a good 30mm further again. It wont be uber low by MJG/Dex standards but to be honest, I don't want it uber low as I think that is gay!
Old 04-07-2008, 07:00   #352 (permalink)
e30 of Death
Gay in the fact your car handles like crap, yes, but gay in the fact it LOOKS BADASS!? lol.
Old 04-07-2008, 11:16   #353 (permalink)
topi
Shh Cha Muhf
topi's Avatar
Gay like you wont be able to nail it through the valleeeys. Good work Brine, make it proper.
Old 16-07-2008, 20:30   #354 (permalink)
sideways.taff
-NightWalkers-
Gay BMW snakes
pappa taff*tune simple snakes
bonnet holder-onner mounts
bonnet closeinated, fitment!
Waggly tongue.
Old 16-07-2008, 20:42   #355 (permalink)
Jord
F*ck your EGO.
Jord's Avatar
I swear I'm gonna dump my Silvia outside your house one day with the keys left inside, safe in the knowledge that you just won't be able to leave it alone.
Old 16-07-2008, 20:47   #356 (permalink)
sideways.taff
-NightWalkers-
You'd better leave a blank cheque in there somewhere as magic doesn't happen without spondulics
Old 16-07-2008, 20:47   #357 (permalink)
Jimthejunior
Represent
Jimthejunior's Avatar
Very pretty boyo. Whens it gonna be running under its own steam?
P.s You at Bdc this weekend? If yes do i get my present?
Old 16-07-2008, 20:48   #358 (permalink)
sideways.taff
-NightWalkers-
Yeh, I'll be down there Jimlad. I'll put it next to my bag and with an ECU I need to drop off with someone too!
Old 16-07-2008, 21:10   #359 (permalink)
Jord
F*ck your EGO.
Jord's Avatar
I THINK I'VE ALREADY PAID OVER THE ODDS WITH YOU MOTHERBISH
Old 16-07-2008, 21:12   #360 (permalink)
sideways.taff
-NightWalkers-
mwwahhh ha ha ha.. rapage!
