Old 03-12-2007, 00:57   #601 (permalink)
Hammond
oh, snap!
Man those seats are trick! I wish I had more monies! Good luck getting the fricker sorted dude, bet you're dieing to give it a good thrashing lol.
Hammond is online now   Reply With Quote
Old 04-12-2007, 01:20   #602 (permalink)
japaneasy
japaneasy's Avatar
Send a message via MSN to japaneasy
Nope, its a nightmare, meaning im gonna miss the Drift UK practice day next weekend
Well TBH mate, rather than do it myself, i was seriously considering letting someone else do it and let them fit the hydro wand and line lock at the same time.
Im just worried about it bankrupting me, which is why i do stuff myself normally, but this is just a nightmare now
Give me a ring tomorrow i will sort some thing out for you mate.
japaneasy is offline   Reply With Quote
Old 04-12-2007, 01:23   #603 (permalink)
mittomatto
-NIGHTSPIRT FAMILY-
i got 8 rims for you too
mittomatto is offline   Reply With Quote
Old 06-12-2007, 13:11   #604 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
just got back from Germany, my tyres have arrived or the Rotas now too
now just need to change/uprate the manifold gaskets ASAP. dunno wether to have a crack myself or what, hmm.
Eh?
sounds good, no idea what the crack is with that, explain pleasebut sounds good...
Old 07-12-2007, 02:48   #605 (permalink)
BillyFIVE
no disassemble
BillyFIVE's Avatar
love the colour of the harnesses
gutted that the car is being such a ballache for ya. chin up n stuff
BillyFIVE is offline   Reply With Quote
Old 07-12-2007, 04:13   #606 (permalink)
superclarkey
BRAP! BRAP!
As mentioned when tested for the spark it was perfect, as its wasted spark 1 and 6 fire at same time, so easy test of putting number 6 on number 1 without effecting no.1s firing proves that the ignition is fine.
The injectors are firing, we tested each one, and it is clicking... and stavros you chaged the injector over, so there is no reason to which it shouldn't be firing now. As the number 6 injector was now working perfectly in number 3 location, so we know the injector now in 6 to be of good working order.. still leaves a slight question mark over the wiring...possiblty
So we have fuel and ignition, which made me wonder if the inlet gaskets have gone, they are only made of crap on the RB26 and because its per cylinder throttle bodies and having a paper gasket in front and behind the throttle body there is a good chance they may have failed, they are known to blow out at Bar of boost, is why i suggested this, and in my mind IF its not electrical this would be the only other cause i could possibly seeing causing the fault, because logically when the throttle plate is shut, its vacuum could be drawing massive air in from outside, from the gasket behind the throttle body, which as entering the system after AFM would be unmeasured and cause that cylinder to not have correct mixture, then when the throttle plate is opened it would be over whelmed by the incoming mix and start to pick up a little.
This is how i saw it, but stavros, to check if its gaskets spray some brake cleaner down the back over the area were there the gaskets are, if the idle picks up or splutters you have a leak. but remember brake cleaner can catch fire easily, so do it a squirt at a time... not covering your whole engine in extremely flammable liquid
Either way as i mentioned charging them for steel is a great upgrade to do anytime.
If you need someone to come lend a hand or just do the job for you, let me know, i have a place up here i can work on cars so if there is a few things need doing, maybe i can help you out.
Clarkey.
Old 07-12-2007, 09:33   #607 (permalink)
Alex B
Alex B's Avatar
Send a message via MSN to Alex B
We've had inlet gaskets blow a couple of times, but its always been at tickover and clears at about 2krpm?
Alex B
Alex B is offline   Reply With Quote
Old 07-12-2007, 14:30   #608 (permalink)
Pikey
Pikey's Avatar
My inlet gasket went on the CA at Teeside, car would barely idle and would misfire when revved.
HKS inlet manifold (1) and throttle body gaskets (6) cost me about £30 from I cant remember where, Sumo Power possibly. I agree you might as well do them if it's a possible cause but personally I'd be surprised if it was. I'll give you a hand if you like - I've done it before, its not a nice job.
Old 07-12-2007, 15:02   #609 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
Id appreciate any help I can get TBH mate.
Im gonna whip the cam covers off soon as I get a chance (tonight/tomorro) just to make sure the cams still have all the lobes on them
Then I guess next job is to remove the inlet. Ive sprayed WD around it, no change, and what its doing does seem odd to be it, but who knows.
I really hate RB26s and if I had it my way id remove the engine and start getting the car fitted with something I do like, but I want the car on the road, well, i want to drift, so guess that isnt an option.
Old 07-12-2007, 15:19   #610 (permalink)
N22CK_C
dam just caught up since the last time i had read sorry to hear your having bit of trouble keep at it tho you will have skidding soon
N22CK_C is offline   Reply With Quote
Old 07-12-2007, 15:29   #611 (permalink)
James
Lights out!
James's Avatar
you done a cylinder compression test Stav?
Old 07-12-2007, 16:52   #612 (permalink)
superclarkey
BRAP! BRAP!
Yeah he has, i think he told me it was 10bar across all.
Old 07-12-2007, 16:53   #613 (permalink)
Nelo
Resident Alco
Nelo's Avatar
Send a message via MSN to Nelo
Compression test was done James but a Leakdown test wasn't. Compression was Ok but generally can be ok even when there is a valve(s) not seating correctly. A Leakdown test on that cylinder should tell you if you're have any problems like this though.
Nelo is offline   Reply With Quote
Old 07-12-2007, 16:55   #614 (permalink)
superclarkey
BRAP! BRAP!
well you have to work through and eliminate possible causes, i suggested inlet gaskets because i know they can do funny things, and also because the problem got slowly worse ect.
upto you if you don't want to change them, but its a job worth doing none the less.
clarkey
Old 07-12-2007, 17:02   #615 (permalink)
superclarkey
BRAP! BRAP!
Totally agree, but if a cylinder is infact seeing the same compression to other cylinders and the point of ignition.. it would still fire, maybe not as well but it would.... this is flat out not doing anything.
If it is wiring, its wired how its got progressively worse over time, and its consistent.. you would think if it was a dodgy wire it would come and go.
only trying to make surgestions, something like a cam would have been instant, not progressive, so i think that rules that out ect,
Either way i hope you find out whats causing it, will turn out to be something retarded.
Old 07-12-2007, 17:07   #616 (permalink)
Nelo
Resident Alco
Nelo's Avatar
Blocked fuel filter
Old 07-12-2007, 17:08   #617 (permalink)
superclarkey
BRAP! BRAP!
lol, that may be the case if it ran 6 fuel fitlers haha
maybe the fuel just don't like no.6 and flows past it......
Old 07-12-2007, 17:10   #618 (permalink)
gtst lad
Ut oh
Just trying to help out here, have you checked the throttle butterfly/linkage etc for that cylinder?
gtst lad is offline   Reply With Quote
Old 07-12-2007, 17:11   #619 (permalink)
Nelo
Resident Alco
Nelo's Avatar
Yeah could be that special "5 Cylinder" Fuel they used to run in the old Group B Audi Quattros? Maybe try emptying the tank of fuel
Old 07-12-2007, 17:12   #620 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
sprang to mind for me, mentioned it to clarkey, but he said (quite correctly i believe) that the throttles are joined in twins, so just 1 wont be shut on its own.
