Old 13-12-2007, 21:04   #641 (permalink)
Storm Chaser
Send a message via MSN to Storm Chaser
Nice to have met you today Stav, I am glad to have been able to help, I guess its not very often I can offer good advice or help out so its good that I can sometimes!
Storm Chaser is offline   Reply With Quote
Old 13-12-2007, 21:29   #642 (permalink)
floyd
floyd's Avatar
hi stav, could it be the wiring from injector number 6 to the ecu or perhaps one of the drivers in the ecu, had a similar problem with an s14 i traced the wires back to the ecu and put new wires in and it was perfect, worth a shot, good luck
floyd is offline   Reply With Quote
Old 13-12-2007, 21:35   #643 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
Hiya mate.
Unfortunatly we checked continuity and resistance on the injectors and they were fine, and even changed the ECU, so almost deffo not that
Old 13-12-2007, 21:58   #644 (permalink)
jonesy-rst
wot a ncie car nice rocker cover lol nice one
jonesy-rst is offline   Reply With Quote
Old 13-12-2007, 22:34   #645 (permalink)
e30 of Death
Sorry I cba to read all 30pages of this, but did you do a compression test? I'd suspect a mechanical problem if you've tried all of this electrical stuff. Could be a bad seal on a valve, or something broken in the head?
Old 13-12-2007, 23:04   #646 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
10.5bar all round, spot on, only need to look back the last 3 pages or so to see all the stuff we've done to try n fix it so far.
Old 13-12-2007, 23:12   #647 (permalink)
e30 of Death
Ah right soz. Hmm ok my only idea is toasted. Just sell the engine shit and stick in a 1J. It wont be off the road for long if you keep it sensible.
You bother with that e30 in the end?
Old 13-12-2007, 23:47   #648 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
I think a 1J will be a ballache as theyve modded the subframe and allsorts to make the RB fit
Tho its dead tempting to sell it as its worth about 2.5k, but it will mean it goes off the road for a longer time
Didnt bother with the E30, no time to mess with that, and it needed some messing with!
Old 14-12-2007, 12:45   #649 (permalink)
japaneasy
japaneasy's Avatar
Send a message via MSN to japaneasy
Good to see she has a window again when are you getting the thing down here bud...?
japaneasy is offline   Reply With Quote
Old 14-12-2007, 23:49   #650 (permalink)
danbuckjoyce
danbuckjoyce's Avatar
Send a message via MSN to danbuckjoyce Send a message via Skype™ to danbuckjoyce
Take it to Paul, he will have it fixed in no time~plus we have an airfield we can go out on, oh yeah~that road we shot the pics on, its closed!
In fact move the mag down here, it going off down here right now~its the place to be.
danbuckjoyce is offline   Reply With Quote
Old 15-12-2007, 15:12   #651 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
As about the only 2 possible problems left unchecked (as seems we 99% sure its not fuel or ign) are mechanical, ie summat wrong with the inlet, or either the inlet or exhaust valves not opening, ill try check them out myself first, and see whats up.
I was thinking tho, its the dead of fricking winter, surely im better off sorting shit i wanted to do to it NOW, rather than quickly get it on the road, then take it off again a few times later on (when the weathers better and i should be driving it!) for a cage etc etc.
So providing i can find out whats up, i might remove the bits that need fixing or whatever, and send the car off to have a cage while i fix those bits.
Multi-tasking!
Old 15-12-2007, 16:50   #652 (permalink)
Nelo
Resident Alco
Nelo's Avatar
Send a message via MSN to Nelo
Get a woman to help with the Multi Tasking... apparently they're better
Try getting the engine leakdown tested mate.
Nelo is offline   Reply With Quote
Old 15-12-2007, 17:01   #653 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
it shows 10.5 bar accross the cyls, leakdown or no leakdown, itd not run on 5 all the time, surely?
Old 15-12-2007, 18:43   #654 (permalink)
Nelo
Resident Alco
Nelo's Avatar
You haven't done a leakdown test yet I dont think. You need a compressor and tester. You can have 10 bar across all cylinders at 1 moment in time with bad leakdown on a cylinder.
Old 19-12-2007, 10:29   #655 (permalink)
gtst lad
Ut oh
I'm sure you've tried this but thought i'd suggest it as couldn't see it mentioned in the thread.
Have you tried putting the ecu into diagnostic mode to see if it flashes any fault codes?
gtst lad is offline   Reply With Quote
Old 19-12-2007, 10:41   #656 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
Not done that, dunno how to be honest, but as we've checked all ign and fuel, its mega unlikly its either.
I finish work for 2 weeks from tonight onwards, so i can finally get the inlet etc off and hope its that.
Ive been told on multi-throttle engines if a air leak is REALLY bad post throttle it can run so lean it wont even run, which makes sense on my car.
Esp as it has always had a mild miss and a high idle, both which could happen with an air leak.
If its not that, well, in screwed, lol.
Old 19-12-2007, 11:00   #657 (permalink)
gtst lad
Ut oh
Got to be worth double checking as it only takes a few seconds, you can also test whether the cars run lean or rich which could help to tell whether it's an air leak.
Here's a copy and paste
Skyline Diagnostics
ECU diagnostics
The ECU is found in the passenger footwell, behind the plastic kickplate to the left of your feet when sitting. Usually you have to remove the computer from the mounts in the footwell, as the LED(s) you need to see is pointing away from you.
Switch on the ignition, but don't start. The LED on the ECU will be glowing.
Turn the selector screw clockwise all the way (gently!)
There are three different types of factory ECU available in Skylines.
One type has two LEDs and five modes
The other type has one LED and two modes
The last type has no LEDs, the output is done with the engine check light in the instrument cluster. Acts as a single LED ECU.
For two LED EDU's: the LED will flash once, pause, flash twice, pause... all the way up to five. This is the diagnostic mode. Mode 1 = one flash, mode 5 = five flashes. When you reach the right mode, turn the screw back counter-clockwise. Mode 3 is what most people use.
For one LED ECU's: wait a couple of seconds, and turn the screw back counter-clockwise, the ECU is now in mode 2.
Note - the engine check light on the dash will mirror the LED on the computer.
The LED will flash out a code (or series of codes if there is more than one fault) More recent ECU's have two LED's (red = first digit, green = second digit, eg red 2x flash, green 1x flash = code 21) The ECU's on most R32's have one LED, long flash = first digit, short flash = second digit, eg long, long, short = code 21.
Codes:
11 Crankshaft position sensor
12 MAF sensor circuit
13 Coolent temperature circuit
14 Vehicle speed sensor circuit
21 Ignition circuit
31 ECU (ouch!)
34 Knock sensor
43 Throttle position circuit
45 Injector leak
51 Ignition circuit
54 Auto signal to ECU
55 All OK
Turn the ignition off to put the ECU back to normal.
There is also a O2 sensor test in real time available - do the above to get the ECU into mode 2 (single LED ECU) or mode 1 (2 LED ECU's) Start the engine. Warm the engine, and then run under no load at 2000 rpm for the test.
Single LEDs: on = lean, off = rich
Dual LED's: green LED on = lean, green LED off = rich
Go by the trend shown, eg mostly on = lean, mostly off = rich. The LED should be flashing between 5-10 times per 10 seconds under normal conditions.
Old 19-12-2007, 11:17   #658 (permalink)
e30 of Death
Clever shit!
Old 19-12-2007, 11:31   #659 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
The rich/lean thing wont help really, as its only 1 cyl that will be mega lean.
Not sure if my ECU has a LED, but i bet it wont be linked to the dash light if it hasnt.
It seems to be, if I believe the case writing, originally a RB20 ECU from a Auto Cefiro.
TBH the cars in so many bits at mo, itd prob be quicker to take the inlet off and look, lol.
Old 19-12-2007, 11:50   #660 (permalink)
e30 of Death
Maybe you should just fit a GTR ecu? Is the problem staring you right in the face there?
