Old 29-02-2008, 00:41   #821 (permalink)
Will_DW
Will_DW's Avatar
Whats the yellow/green headlight switch Stav? It actualy change colour of headlights?
I want that
Old 29-02-2008, 00:51   #822 (permalink)
sideways.taff
-NightWalkers-
sideways.taff's Avatar
Originally Posted by Ali View Post
fricking sweet Stav, can't wait to see it in action!
Reckon that raised bonnet actually helps with cooling? I'm sure it was Steve Carter did a test and found it had the adverse effect, looking for an image on the net that I found ages ago for a uni project that showed it but this kinda does:
Shows its actually high pressure at the base of the screen so won't actually let the air escape?
cheers
Ali
Just read back through the latest posts..
Yeh raised rear edges on bonnets do not serve to speed up exiting airflow. Adding a small vertical gurney flap along the rear edge of the raised bonnet will though
sideways.taff is online now   Reply With Quote
Old 29-02-2008, 00:59   #823 (permalink)
Jimthejunior
Represent
Jimthejunior's Avatar
Hmmm is that a nascar i spy? Hmmmm
Old 29-02-2008, 10:41   #824 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
I want that
No no, just whoever owned it before has fitted different colour lights in each bit, so side lights are whitey green, the next lights in are bluey, the middle lights are yellow, and then they change again on full beam, but i forget which.
Old 01-03-2008, 14:36   #825 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
Got the tyres on the Rotas at last!
Rears went on ok, maybe need slightly more flare, but its ok.
But I cant get fronts on
Looks like they will physically fit no bother, but the holes on the rear of the wheels wont clear the bolts on the spacers that were on the front
I cant even try and see how they are without the spacers as I cant get em off, see here-
How hell you remove front bolt-on spacers?
The rears look good tho!
17s are back on for now
Old 01-03-2008, 14:40   #826 (permalink)
Jord
GRD Drift Club
Jord's Avatar
Stav, I've lost count of the number of smilies in this thread - sort it out man! I've replied to your thread, that always worked for me.
Old 01-03-2008, 14:43   #827 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
it can frick off for today, im gonna go finish off the tyres on the 17s.
if im not too hung over tomorrow ill give it a go
Old 01-03-2008, 15:06   #828 (permalink)
topi
KlutchKickKidz
topi's Avatar
Looks badaman on those rotas.
Old 01-03-2008, 15:47   #829 (permalink)
Dori Mat
UberLifestyler
Dori Mat's Avatar
P I M P
get someone to put there foot on the brakes and undo the spacers
Dori Mat is online now   Reply With Quote
Old 01-03-2008, 15:48   #830 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
Oh modded cars are great arnt they...
Just been out caning around and when slowed back down i got a waft of stinky transmission fluid from the gearstick area and a lil bit of smoke.
On closer inspection now im home gearbox oil is actually coming in to the car
Didnt think it was at enough pressure to manage that, but looks like i best look at that now
Also have a strange rattle from the rear drivers side since about half way home from JDM. Its a plasticy rattle rather than a thump, and tho it happens on rough surfaces, it dont actualy happen in time with the bump, so i dont think its suspension probs, i think its summat else.
Cant work out what tho! Maybe its the orig handbrake cable or summat?
Bastard cars!
Originally Posted by Dori Mat View Post
P I M P
Its hard enough just getting a jack to a suitable jacking point at the front TBH, bloody big gay bodykit, lol
Old 01-03-2008, 16:02   #831 (permalink)
Dori Mat
UberLifestyler
Dori Mat's Avatar
jacking the front of mine up is a PITA without a bodykit
drive it up onto some planks of wood first give yourself a bit more height
get all 4 wheels on i need to see it
Old 01-03-2008, 16:36   #832 (permalink)
TwinturboCH
TwinturboCH's Avatar
Send a message via ICQ to TwinturboCH Send a message via MSN to TwinturboCH
This is looking the BOLLOCKS Stav You NEED to get those 18's on the front though LOL
You still gonna let me use it for that demo?
TwinturboCH is offline   Reply With Quote
Old 01-03-2008, 16:51   #833 (permalink)
Paz
-NIGHTSPIRIT FAMILY-
Paz's Avatar
Dont put stickers on it Stav. With the Rota's on it'll look plenty good.
Paz is offline   Reply With Quote
Old 01-03-2008, 16:52   #834 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
If I can make it work right then maybe
This I expect is the cause of the tranny fluid leak/stink...
Thats the rubber boot that sits on the base of the gearstick, its fricked.
There about 5 more holes in it than that too, gotta work out how to get one of them now too, i "think" its a RB20 box, do they share that boot with CA18 or SR20 boxes?
Old 01-03-2008, 17:07   #835 (permalink)
200sex
200sex's Avatar
Does look the same as the ca/sr boot to me, could be wrong though,
200sex is offline   Reply With Quote
Old 01-03-2008, 17:28   #836 (permalink)
TwinturboCH
LOL
Yeah, looks identical to the SR20 one Mine did the same thing on my S14 and every time you gave it stick the car stank of gearbox oil, I quite liked it
Old 01-03-2008, 17:36   #837 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
The smell isnt great, but its actually coming in to the car in smoke and liquid form, which isnt ideal!
Ive went nuts with the superglue on the current one, hopefully it will work while I find an SR20 one...
Old 01-03-2008, 17:52   #838 (permalink)
Alex B
Alex B's Avatar
Send a message via MSN to Alex B
RB20 and RB26 are the same, cost about £7 from Nissan and have always ben in stock when we've ordered them.
I had mine go on the GTR, didn't look damaged but used to make the inside of the car stink and occasionally, (mostly on long, fast mortorway trips), there would be faint clouds of smoking coming up through it! Changed the GTS one just for the sake of it.
Alex B
Edit, we've got a new one at work waiting to go on dads GTR, I can get the part number off it monday if you haven't sorted it by then.
Alex B is offline   Reply With Quote
Old 01-03-2008, 21:32   #839 (permalink)
Ed.
The Real Ed
Yeah,it looks good as it is now
Ed. is offline   Reply With Quote
Old 01-03-2008, 23:16   #840 (permalink)
RandomGuy
Team Japspeed
RandomGuy's Avatar
Send a message via MSN to RandomGuy
stav that looks awesome on the rotas mate!!!
sit well on the rears, just hurry up and get the fronts on ...
RandomGuy is offline   Reply With Quote
