01-09-2008, 12:27
| #1243 (permalink) |
| Dex- I have actually mate, yeah ill sell it. Caged- It does everything I need it to do, and is better quality than most the cages ive seen. Tho most of them arnt even welded 360deg round the tube, lol. I have just recieved a CD of images that Andy Robinson Race Cars - roll cages, complete chassis, fabrication, setup, race car engineering took while they was installing it, and heres a couple of interesting ones... This one shows the rear strut bar ill be putting the harnesses on I guess... ![]() And most of all, these pics shows how bad the wiring is behind the dash, and how much crap is left there I dont need! Still got a heater matrix! But there is no room for the heater hoses to go in the car, and there no blowers fitted either! I reckon at least 50% of that wiring is totally redundant too. ![]() ![]() I reckon its time to remove the dash, again. How much dash is needed from a comp point of view? Dont wanna bin it off and then have to refit it in future... |
01-09-2008, 12:53
| #1246 (permalink) |
| Ringer- Bons car is well trimmed compared to mine even now, he has a luxury drifter, lol Bon- Fook knows, but now chopping the dash has properly lost its strength, it looks shite now, and the main speedo and rev counter has stopped working too suddenly, and they nor me have worked out why! (all the warning lights work along the bottom, but the stuff on the main bit, speedo, revs, fuel, and water, have dissapeared (digi dash on mine remember!) |
01-09-2008, 15:43
| #1248 (permalink) |
| It says if its replaced, it should be replaced with one similar/better appearance/quality of the original. Which is quite open ended to say the least. Need to do something though, my dash looks fricked at mo, and behind it is even worse! |
01-09-2008, 19:42
| #1253 (permalink) |
| Drift Gibbon Join Date: Apr 2006 Location: banbury, UK
| they are 1, 2, 3 or preferably 4 wraps that stop the door bar X splitting in a side impact, which in turn goes into your spleen and you die. happened to someone i know ![]() they seem to be way to many door bar X's without them. A 2 peice door bar is preferable all together and a far superior design il grab some pics off my hard drive........? |
01-09-2008, 20:18
| #1254 (permalink) |
| dorifto kingu! Join Date: Oct 2007 Location: Nr. Oxford
| Loving this car still, ever since I first saw it! Like Bunny though, I've only seen it in person once, at a DWYB AGES ago. Just bolt the dash back in mate, even if it means drilling some new holes and shoving big long bolts through - not worth going for anything else really is it? Are these the sort of wraps caged? ![]() |
01-09-2008, 20:47
| #1256 (permalink) | |
dash, well, i need to remove some of it at least to try fix it, and if not ill need to knock up some aftermarket clocks that do work. and may as well remove all the extra random crap thats behind it that i dont need, try make things easy as poss. | |
01-09-2008, 21:48
| #1259 (permalink) |
| Caged, so really you could use any high strength, tough 'wrap' I'm guessing? Having the specific right sort is always good though ![]() Stav - Cheltenham's not that far away tbh! Although, not being far away doesn't mean you ever come here (and vice versa), so that point is moot anyway. Fairy snuff with the dash and wiring, makes sense. I hope you can get the clocks sorted, thats the sort of hassle that just makes you go 'argh' (again). |
