Old 08-04-2008, 22:59   #421 (permalink)
e30 of Death
Maybe... Just... Turn down the boost, just a touch? Maybe you don't QUITE need that much power?
lol.
I joined you in the "our car's are fricked" club, and I have only just placed the order for my replacement clutch lol. I have fixed my missfire, and nearly done my rear brakes, so should be alreet. Hopefully we won't be in the same club at round 2!
Old 08-04-2008, 23:06   #422 (permalink)
Polo
Team Green!
Polo's Avatar
lol.
Haha, naaaa more boost it was only at 28psi when it went, it was mapped to 35psi Morrrrrrrre powers!!!
Yea Boi, club top 2 init!!!
Old 08-04-2008, 23:33   #423 (permalink)
Crosshatch
-NightWalkers-
Crosshatch's Avatar
35psi!
my powers are weak, I only run 0.6 bar lol
My high boost is 0.8
Crosshatch is offline   Reply With Quote
Old 09-04-2008, 09:31   #424 (permalink)
Mr Bizzle
Team DWYB
Mr Bizzle's Avatar
Originally Posted by Crosshatch View Post
35psi!
Your gay.
But i am going to rig his boost controller so it won't boost past 1.5 bar anyway. Unfortunatly for Polo he's trying to compensate for being crap by running more power...
Poor lad
Old 09-04-2008, 09:48   #425 (permalink)
cefiro_drifta
mad pointing munkey
cefiro_drifta's Avatar
Originally Posted by Mr Bizzle View Post
Your gay.
Poor lad
if thats the case he NEEDS LOTS MORE POWER
Old 09-04-2008, 22:34   #426 (permalink)
Polo
Team Green!
Polo's Avatar
You bitchs!!! sabatage time i think
Stripped the donor engine today, removed all the rings and cleaned the pistons and rings, then refitted the rings and removed the pistons from the rods. Took ages!
Also got all the pistons out of the engine that died.
this is the good pistons No wonder its been a bit smokey for the last year.
And the melted one Proper job
And the bore is in really good condition considering, little hone and itl be sweet.
Old 10-04-2008, 22:21   #427 (permalink)
Polo
Team Green!
Polo's Avatar
slow progress today but you cant really rush engine work
a bit of this and some cleaning
Clean second hand pistons and rings
How i left it tonigt, awaiting new head gasket and a few more goodies from Apex
Old 10-04-2008, 22:29   #428 (permalink)
Mr Bizzle
Team DWYB
Mr Bizzle's Avatar
LOL
Standard block ftw!!
Old 10-04-2008, 22:30   #429 (permalink)
e30 of Death
Nice work, thought the bores should have more of a diagonal/criss-cross honing pattern after though rather than almost horizontal? Does it not matter too much? Just would have thought the rings would slightly skip over the ridges left by the honing on a microscopic level thus causing problems?
Old 10-04-2008, 22:43   #430 (permalink)
Polo
Team Green!
Polo's Avatar
Bizzle, what you on about? standard block? of course, its the same engine as what went bang just some new pistons lol
Mike, do you think it really matters with this engine lol + the honing tool i have is long, with the short stroke of the SR engine and with the piston oil jet in its near on imposable to do it. It was only a very light hone with a medium grit any way, just bore number one had a little bit more work.
Old 10-04-2008, 22:51   #431 (permalink)
superclarkey
Mood=Badical!
superclarkey's Avatar
Nice work, just out of interest they are 54c pistons, how do you think they will get on with the ceramic coating being removed ?
Shame thats a nice case of det on that engine, nissan pistons are crap too soft, you going to lower the compression slightly to help out with combustion pressures ?
clarkey
Old 10-04-2008, 23:05   #432 (permalink)
Polo
Team Green!
Polo's Avatar
clarkey
54c! WTF????? Explain?
I run a 1.9mm gasket ATM thats low enough, this is just a stop gap untill i get a proper engine sorted soon.
Old 11-04-2008, 01:15   #433 (permalink)
topi
Shh Cha Muhf
topi's Avatar
Ffs...
Old 11-04-2008, 01:29   #434 (permalink)
superclarkey
Mood=Badical!
thats just the piston found in the 65F SR20 block in the uk VVT bentcam.
The 54c pistons are actualy the same as in the pulsar GTiR and they come cermicly coated out of the factory for det and heat protection.
Thats why the Sr20 pistons always have dark tops
Old 11-04-2008, 03:06   #435 (permalink)
pizzaboy
splendiferous
pizzaboy's Avatar
That a strong contender for the "DW Geek Statement of 2008" award.
pizzaboy is offline   Reply With Quote
Old 11-04-2008, 08:51   #436 (permalink)
Polo
Team Green!
Polo's Avatar
Whooops, so me cleaning them up with scotch bright and degreaser wasnt a good idea
Old 11-04-2008, 09:28   #437 (permalink)
Mr Bizzle
Team DWYB
Mr Bizzle's Avatar
Polo you fool.
Your running a standard block (IE: Bottom end) and i am trying to be ironic in saying that it's cool, yo!
Standard block FTW Yo! (see? )
Clarkey,
You are a MASSIVE geek.
Old 11-04-2008, 09:30   #438 (permalink)
Mattyboi
InitialD erby
Mattyboi's Avatar
aaaahahahahaha! Whoops! I`d have done the same though.
Old 11-04-2008, 09:41   #439 (permalink)
cefiro_drifta
mad pointing munkey
Clarkey,
that was nice of you bizzle, at least u didnt call him a flange like usual haha
so wat happens if u take all the ceramic coating off like EL DUMBASS has done ? just less protection on the top from det etc or wat ?
also when u hoon the cylinders doesnt that make them bigger? so would u need bigger rings or pistons ? or is it so minimal that it wouldnt matter ?
Old 11-04-2008, 09:48   #440 (permalink)
Mr Bizzle
Team DWYB
Mr Bizzle's Avatar
Sorry,
Edited.
Originally Posted by Superclarkey
Clarkey,
You are a MASSIVE C**T.
