Old 10-04-2008, 22:42   #541 (permalink)
superclarkey
BRAP! BRAP!
Good work mr.stevo, always like when people actualy do there own fab work
Anyone can sign a cheque doing it yourself rocks
Old 10-04-2008, 22:55   #542 (permalink)
MR-steveo
TNS MAN CHILD
Old 10-04-2008, 23:33   #543 (permalink)
Polo
Team Green!
Polo's Avatar
I want a TIG welder
Nice work Steveo
Old 11-04-2008, 09:56   #544 (permalink)
MR-steveo
TNS MAN CHILD
Originally Posted by MR-steveo View Post
cheers guys!
well thanks to jerry (AEsuperG) and hope ur bro is back to full fittness asap!!!
i can crack on with the car, starting on getting the girl a drink........
i love welding alloy
i spent most of the time finding places to put the parts, and about 30mins cutting and welding
Old 11-04-2008, 10:04   #545 (permalink)
Phil
Admin
Phil's Avatar
Did you say that pumps the same as my lift pump? If so, it's supposed to be set level or no higher than the outlet of the fuel tank..
Phil is offline   Reply With Quote
Old 11-04-2008, 10:36   #546 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
yup as Phil says the lift pump needs to be ideally located at the same level or lower than the tank
Old 11-04-2008, 10:39   #547 (permalink)
Dex
kut!
Dex's Avatar
Send a message via MSN to Dex
stupid Q, but why?
Old 11-04-2008, 10:45   #548 (permalink)
MR-steveo
TNS MAN CHILD
no ive got the same main pump as you mr phil! and the holley lift pump i had a look through the litriure of the pump and it didnt say anything about needing to be fitted at the same level as the tank!
Old 11-04-2008, 10:53   #549 (permalink)
MR-steveo
TNS MAN CHILD
if you look at the pump and tank side on its only 80mm about the tank outlet as the pick up is the top of the tank!
Old 11-04-2008, 10:57   #550 (permalink)
suprmek1
Dori Mechanic
suprmek1's Avatar
Should be fine with the lift pump as this will draw the fuel to the main pump rather than it having to suck fuel from the tank. His swerl pot (sp) takes the fuel level higher than the main pump giving it gravity feed.
Good work stevo
Old 11-04-2008, 11:01   #551 (permalink)
matt
-NIGHTSPIRIT FAMILY-
matt's Avatar
yeah, I thought it was only high pressure pumps that had to be lower? hence the 'lift' part of lift pump? I hope thats the case cos I don't want mine under the car getting covered in shit!
matt is offline   Reply With Quote
Old 11-04-2008, 11:05   #552 (permalink)
cookiemonster
cookiemonster's Avatar
Wow mr steveo this looks amazing i havent seen this thread in a while top work
cookiemonster is offline   Reply With Quote
Old 12-04-2008, 19:29   #553 (permalink)
MR-steveo
TNS MAN CHILD
got all the pulmbing doing in the boot and swirl pot fished and boot floor
im happy with it
Old 12-04-2008, 19:46   #554 (permalink)
Hexham-Scotty
Skylinepart.cm
Hexham-Scotty's Avatar
Send a message via MSN to Hexham-Scotty Send a message via Skype™ to Hexham-Scotty
Work of art MR S
Hexham-Scotty is offline   Reply With Quote
Old 12-04-2008, 19:47   #555 (permalink)
e30 of Death
Looks lovely Nice work man
Old 12-04-2008, 20:20   #556 (permalink)
doz
animal!!
im happy with it
Nice, neat work there Stevo, but is the hole grommited that passes through the firewall/boot floor?
doz is offline   Reply With Quote
Old 12-04-2008, 20:28   #557 (permalink)
j@garagemac
Garagemac
j@garagemac's Avatar
Send a message via MSN to j@garagemac
thats just mocked up . when it is all installed final it will be gromited
j@garagemac is online now   Reply With Quote
Old 12-04-2008, 22:13   #558 (permalink)
Barky
Team Triad
Barky's Avatar
Fantastic work!
Barky is offline   Reply With Quote
Old 13-04-2008, 13:20   #559 (permalink)
doz
animal!!
cool stuff regardless
Old 18-04-2008, 20:35   #560 (permalink)
blue boy
Stunning work, just read this from start to finish.
blue boy is offline   Reply With Quote
