Old 27-04-2008, 12:09   #581 (permalink)
muttley
muttley's Avatar
Top work there and an interesting thread to read, keep it up
muttley is offline   Reply With Quote
Old 27-04-2008, 12:13   #582 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
mint.
what heat wrap is that stevo? looks more like the stuff you wrap things in to keep the heat off rather than the stuff you wrap things in to keep the heat in?
Old 27-04-2008, 21:29   #583 (permalink)
MR-steveo
TNS MAN CHILD
mint.
its this shit
Thermo-Tec 15001 - Thermo-Tec Turbo Insulating Kits - summitracing.com
should work ok
Old 27-04-2008, 21:43   #584 (permalink)
tony-s14
tony-s14's Avatar
Send a message via MSN to tony-s14
very nice job
tony-s14 is offline   Reply With Quote
Old 01-05-2008, 00:09   #585 (permalink)
Will_DW
Will_DW's Avatar
Went down to see Steveo today and the car is looking amazing!
Shouldnt be long until its done i dont think, but the colour in person is sweeet.
Got a few snaps, one of which i probably wont put up as its of him doing a bit of a gay pose.. lol..
Fair play to all hes done, its mint!
Old 01-05-2008, 00:15   #586 (permalink)
chunk
middle aged
chunk's Avatar
Good work yooooof! I'll try to come over and see you before i get all cut up next week.
Do ittttttt! I have a very camp steveo pose piccy here, i'll post it if you post yours!
Old 01-05-2008, 01:05   #587 (permalink)
sammysideways
coool cool. stevo can i come up and look at it sometime? looks mint
Old 01-05-2008, 04:09   #588 (permalink)
CANHCR32
CANHCR32's Avatar
Send a message via MSN to CANHCR32
Ive always heard heat wrapping your manifold is bad because it holds in to much heat and can cause the manifold to crack. a cast manifold is stronger at avoiding this problem. correct me if Im wrong
CANHCR32 is offline   Reply With Quote
Old 01-05-2008, 08:22   #589 (permalink)
cptsideways
Pimms O'clock
cptsideways's Avatar
If thats the sticky heat wrap Steveo - no non nononononono - the glue catches on fire!!! Its only heat shielding stuff
Old 01-05-2008, 08:48   #590 (permalink)
Mitch
Driftgarage
Mitch's Avatar
It looks like it's made for that job if I'm looking at the right link...
Old 01-05-2008, 08:55   #591 (permalink)
Nelo
Resident Alco
Nelo's Avatar
Send a message via MSN to Nelo
The engine looks at home there Steveo, really nice work. This is going to be another weapon I think
Nelo is offline   Reply With Quote
Old 01-05-2008, 09:56   #592 (permalink)
MR-steveo
TNS MAN CHILD
well its a cheap shit one so its gonna crack! ill just keep and eye on it!
as for the heat rap!
look here its for exhaust housings! which get a little hot this is the kit!
Old 01-05-2008, 18:51   #593 (permalink)
CANHCR32
CANHCR32's Avatar
I guess if it cracks then you can just re-weld it and make it stronger
Old 01-05-2008, 20:41   #594 (permalink)
gaz_moose
.MTM.
wow that stuff must be mint that turbo is glowing red hot!!!
Old 01-05-2008, 20:55   #595 (permalink)
koukiboy
Send a message via MSN to koukiboy
Wow it's so a great project!!!
koukiboy is offline   Reply With Quote
Old 02-05-2008, 04:30   #596 (permalink)
CANHCR32
CANHCR32's Avatar
you should love that turbo aswell, I run the exact same one .70a/r aswell. in my overbored rb25, with tomei cams. and it makes great power I hit full boost at about 3700rpm (only 10psi makes about 380whp not dyno'd yet) with the 3litre you should have a very usedable power range. where is your redline set at 7200?
Old 02-05-2008, 07:21   #597 (permalink)
MR-steveo
TNS MAN CHILD
you running a gt35r 0.63 ? not sure think im gonna run between 7000-7500 depends on power lol
Old 04-05-2008, 04:15   #598 (permalink)
CANHCR32
CANHCR32's Avatar
no, i run a/r 0.70 gt35r same as the turbo in the pic above I run to 8000rpm, but I have a full forge motor going in, in about 2-3weeks and then I hope it will make about 420-430whp. with your extra displacement it'll be a blast and desently responsive
Old 05-05-2008, 00:11   #599 (permalink)
MR-steveo
TNS MAN CHILD
creamy goodness
well after a road trip with mr wayne (phat13) of mwbodyshop the old girl turned out like this.............................
more pics tomorrow maybe outside
well i must say a big thakyou to mr wayne for a great job you made the car look pretty and badass wouldnt have happened without your skills xxx
thank you
thanks ep racing for the fk kit
Old 05-05-2008, 00:16   #600 (permalink)
Will_DW
Will_DW's Avatar
Looks awesome! What else is left to do?
Did you finish the fuel system?
