04-06-2008, 11:04
| #732 (permalink) |
| TNS MAN CHILD ![]() | bored thought id do a spec list: Engine Toyota 2jz-gte 3000cc 24v dohc, ITG motorsport air filter, tubular manifold, gt35r, wasted spark coil pack set up with msd leads, tial 44mm external wastegate to atmosphere, custom exhaust including 3inch v band and flexi front pipe, one silencer, custom inlet plenum, Q45 throttle body, 850cc sard injectors custom fuel rail, aeromotive rising rate fpr 1:1 all fittings and line AN areoquip, fuel cell in the boot, areomotive a1000 main pump good for 1000hp, Holley 270gph lift pump 2.5 litre custom swirl pot, koyo alloy radiator, custom intercooler, Vems ECU, 5 speed r154, jz bell housing, spec stage 3 clutch custom prop. Not fully mapped made 430hp and 400bls/ft @0.75bar (1.5 bar next target) Chassis Fully stripped shell including all seam sealer, sound deadening, fully seam welded, with extra gearbox mount, parcel shelf removed, new rear bulk head, boot floor removed, tubbed front & rear arch’s removed front panel sunken drivers seat mounts, moved shifter location, 6 point weld in cage with x door bars, Rota torques 18x9.5 et front and rear, Driftworks ground control coilovers and camber top mount, driftworks lower arms front and rear, fully adjustable geometry - camber, caster, toe, traction arms, Tein steering arms, fully stripped and powder coated sub frame with solid bushes, Nismo gt pro 2 way diff, gtr drive shafts and hubs, 300zx 4 pot calipers and discs, braided lines with abs removed, painted custom cream Exterior Final konextion S15 front bumper and head lights, E P racing carbon vented bonnet on pins, s15/s14 conversion wings, final konextion s14 side skirts, and 50mm over fenders, final konextion s14 rear bumper, carbon s14 boot with pins, custom cream paint! Interior One off 6 point roll cage, Kevlar drivers bucker seat, passenger bucket seat, 6 point harness’s, hydro handbrake, battery located being passenger seat, custom gear knob, Race tech oil temp/ water temp/ oil press/ boost electrical cut out and lifeline fire extinguisher, OMP steering wheel, D1 flip up steering boss ecu hidden in glove box with fuse board hidden behind airbag panel Last edited by MR-steveo : 04-06-2008 at 15:36. |
