Old 05-11-2007, 20:47   #61 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
these 2jz swaps are getting common, think ill ditch mine for a 742.13 from a skoda, and do the wee orz powerz from a Skoda
Old 06-11-2007, 21:59   #62 (permalink)
Twisted
Very exicited to see this come out of the bath!!! Even more to see what happens to mine!!!!!!!!!!
Twisted is offline   Reply With Quote
Old 07-11-2007, 07:53   #63 (permalink)
MC2
Send a message via MSN to MC2
Can't wait for this to be finished
MC2 is offline   Reply With Quote
Old 07-11-2007, 09:09   #64 (permalink)
RandomGuy
Team Green
RandomGuy's Avatar
Send a message via MSN to RandomGuy
SteveO i Got A PM
Did you??
RandomGuy is offline   Reply With Quote
Old 10-11-2007, 14:57   #65 (permalink)
MR-steveo
TNS MAN CHILD
Got my shell back from the dippers.................
picked up my shell it looks sweet apart from a bit of flash rust got caught in a shower but nothing a bit of scotch wont sort out
before...
after.....
look inside the arch's i cant wait to start welding lol
look no seam sealer
oh and a few new parts.......
DB 9 Brembo calipers and ive got 355mm disc's
gonna order the roll cage tubing next week
Old 10-11-2007, 15:29   #66 (permalink)
sx-si
id love to start from a bare shell good luck buddy
sx-si is offline   Reply With Quote
Old 10-11-2007, 15:37   #67 (permalink)
MR-steveo
TNS MAN CHILD
not the fact that i want to kinda had to lol
Old 10-11-2007, 16:52   #68 (permalink)
narcotic
narcotic's Avatar
Send a message via MSN to narcotic
should have done all the welding before the dipping you numpty :P then get them to give it back in primer
narcotic is offline   Reply With Quote
Old 10-11-2007, 16:54   #69 (permalink)
superclarkey
Mood=Badical!
superclarkey's Avatar
No, you must dip then weld....not before
This shell will be extrememly rusty soon... i would primer it asap !
Old 10-11-2007, 16:55   #70 (permalink)
narcotic
narcotic's Avatar
dont put any badges on the car too and leave the aston martin logos on the calipers, when stopped
officer 'what car is this then'
steve-o 'its an aston martin s145 sport mate, its proper bo'
no more tickets coz that aint my car :P
Old 10-11-2007, 16:57   #71 (permalink)
superclarkey
Mood=Badical!
Also Stevo, make sure to check the thinkness of the metal around them turret tops as they may have been thinned out too much lol. which could be bad
Old 10-11-2007, 17:01   #72 (permalink)
narcotic
narcotic's Avatar
why dip then weld?
Old 10-11-2007, 17:08   #73 (permalink)
superclarkey
Mood=Badical!
Glad you asked
When you seam weld a car... say like i did to mine, you have to burn out the seam sealant that is between the two panels, as its "metal - seam sealant - metal" layer by layer if that makes sense, if you weld it with the sealant in there, it makes a dirty weld and is not that strong and also there is a gap between the panel.
as you can see in Steve's picture, now its dipped there is gaps between all the panels. he will have to dolly them (hammer) together so they are touching and then weld them, this will make a strong and clean weld.
people that don't burn out the seam sealant first... well, shouldn't be doing it.
if he seamed it first... when it was dipped and got it back ,he would have gaps every were in the shell.. and it wouldn't be so strong and water would rust the frick out of it
I used to do rally prep when i was young, i know this for sure
Old 10-11-2007, 17:15   #74 (permalink)
narcotic
narcotic's Avatar
ok so why not dip then weld, cage, tub, chop and prep then dip again
Old 10-11-2007, 17:18   #75 (permalink)
superclarkey
Mood=Badical!
because everytime you dip it it removes thickness from the shell.. i bet if he weighed it before and after it would now be lighter
you would be crazy to dip it twice ! bet nothing would come back lol.
To do it properly, you have the car Dipped, then once done sent back for primer and proxy sealent coat.
Clarkey.
Old 10-11-2007, 17:27   #76 (permalink)
MR-steveo
TNS MAN CHILD
lol you guys.... the dip dosnt remove any metal this i a diffent process which uses cold prosess so takes longer and is not as harsh they have had cars that have been in the dip 4 or 5 times
Old 10-11-2007, 17:28   #77 (permalink)
superclarkey
Mood=Badical!
I thought you said it was the same process as prodrive use, they acid dip there cars and it removes metal, i know that for sure as i've been there and spoke to them lol
Old 10-11-2007, 17:30   #78 (permalink)
Chris_200SX
-NightWalkers-
Chris_200SX's Avatar
Very cool steveo, cant wait to see the finished product
Chris_200SX is offline   Reply With Quote
Old 10-11-2007, 17:33   #79 (permalink)
Ian.G
86 ColdTurkey
Ian.G's Avatar
Send a message via MSN to Ian.G
Hubba
Spark up the welder buddy.
Ian.G is offline   Reply With Quote
Old 10-11-2007, 17:38   #80 (permalink)
MR-steveo
TNS MAN CHILD
there are 3 stages what they did to mine mucho cheaper
then acid/etch dip
then zinc dip
i only had the first
