Old 17-11-2007, 19:26   #1 (permalink)
Andy_f
I <3 BDC!
Andy_f's Avatar
Andy_F's comp spec S13 project
Old thread here: Andy_F's low budget S13 project... take 2.
Well, I've had my S13 for over a year now. I've got in a fair bit of practice and realised now that I'd quite like to start competing - after I got my first taste of Tsuiso at Rotorstock 4 - and loved it. I was also told by a few people that I had the skills to do well in competition. I'll be aiming at BDC Pro level.
Anyway, since my old project thread was originally titled 'low budget' and ended up being much more expensive than I thought/planned/hoped, I think a new thread is in order, and I will document my build up from amateur spec car to comp spec.
Specifications:
Initial Spec
Random air filter
T28 (knackered)
Current Spec:
Engine
'Stage 2' engine, standard internals, roughly 260-280hp
Freshly rebuilt S14 T28 turbo
Manual boost controller set to 11psi
K&N air filter with air feed
Intake hard pipe
Braided turbo oil feed line
Home made coke can catch tank
Walbro 255lph fuel pump
Apex Performance front mount intercooler
Japspeed 3 inch exhaust from turbo elbow back
Horsham Developments 'stage 2' chipped ECU
Silkolene Pro S 10w50 oil
Mocal 19 row oil cooler with thermostatic sandwich plate
Bosch colder spark plugs
Bee*R Rev Limiter
Transmission
Welded diff
Standard gearbox
Exterior
Drift dent
Bootlid filled and wiper removed
Sleepy eye mod
17 inch Kosei Japan's 10 spokes
16 inch Advan SA3R's
16 inch BBS style split rims
Rolled arches
Rear indicators sprayed red
M-Sports Type A bodykit
Suspension/Brakes/Steering
K-Sport coilovers
Front strut brace
DW poly rear subframe bushes
Adjustable front tension arms
Adjustable rear toe arms
Drilled and grooved front discs
Interior
All interior removed except doorcards and dash
Bride drivers seat with Bride frame
Recaro SR recliner passenger seat with home made/Bride subframe
Prosport oil pressure, temperature and boost gauges
Pivot 3.5 inch tacho
Soundproofing removed
Nardi steering wheel
Dildo gear knob
Apex'i Multichecker
Border 4 point passenger 5 point driver 3 inch harnesses
Awaiting fitment
Poly Steering rack bushes
Stainless collumn bush
Tein Track rods with DW anti bump steer ends and spacers
Adjustable rear camber and traction arms
Alloy radiator with twin electric fans, electronic controller and alloy cowling
RPS Street Max organic clutch
Godspeed ARB's
Uprated ARB drop-links and poly bushes
Phormula KS-3 detonation meter
Veilside rear ducktail style spoiler
Still to buy
Comp spec 6 point rollcage
Plumbed in fire extinguisher system
Towing eyes
Pull cords
Battery cut off
Still to make/do
Possibly make my own tow eyes
Paint interior
Paint exterior
Poly rear windows
Fix dent in rear quarter
Remove ariel
Chop some inner bodywork to reduce weight
The current look:
Proposed look:
Hopefully it'll be the only kitted two tone S13 in the UK. I haven't seen any others. I also haven't seen any other S13's with an M-Sport body kit.
The plan will be to keep the engine standard and stick with the CA, that way it will be relatively inexpensive to fix or replace if I have a failure, and also parts are plentiful.
I hope to start cutting through the to-do list with vengeance in the next couple of weeks. I still plan to keep to my original method of doing/fitting as much as possible myself, without getting anyone else to do anything, except fitting tyres.
Old 17-11-2007, 19:29   #2 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
2tone will look mint mate, good luck with it
Old 17-11-2007, 19:40   #3 (permalink)
SteveDunn
I can't see...
SteveDunn's Avatar
Send a message via MSN to SteveDunn
Yeah that will look ace.
SteveDunn is offline   Reply With Quote
Old 17-11-2007, 21:15   #4 (permalink)
willg180
willg180's Avatar
Looking forward to seeing that painted, it going to look amazing!
willg180 is offline   Reply With Quote
Old 17-11-2007, 21:30   #5 (permalink)
speedysatan
speedysatan's Avatar
Two tones good, not many like that. Cool
speedysatan is offline   Reply With Quote
Old 17-11-2007, 22:57   #6 (permalink)
Ali
Ali's Avatar
Ali is offline   Reply With Quote
Old 17-11-2007, 23:33   #7 (permalink)
N22CK_C
Originally Posted by Ali View Post
oh yes please
N22CK_C is offline   Reply With Quote
Old 18-11-2007, 00:54   #8 (permalink)
Andy_f
I <3 BDC!
Andy_f's Avatar
Oh man Ali, you're a bastard! That neeeeeeds to be done.
Old 18-11-2007, 01:08   #9 (permalink)
chunk
middle aged
chunk's Avatar
Looks sweet that!!! Gold wheels for sure
Old 18-11-2007, 02:18   #10 (permalink)
Messydan
AKA Fred Flintstone
Messydan's Avatar
Send a message via MSN to Messydan
You know what, i REALLY like the light green and grey with the gold centre'd wheels.
Messydan is offline   Reply With Quote
Old 18-11-2007, 09:24   #11 (permalink)
sketch
lookslike an awsomeproject mate, my 200 is the exact same colour but ithinkimgoing to got for the satin black look as i know im gonna have to make some cheap repairs as i cant drift (but slowly getting better, slowly lol) actually seeing your plans almost wishes i hadnt half sprayed my car black already! good stuff
sketch is offline   Reply With Quote
Old 18-11-2007, 11:07   #12 (permalink)
Ali
Ali's Avatar
I thought you might say that lol, I started off just trying to fix the colours a bit better then thought it badly needs some dished rims and gold centres seems to really work well with the colour. Also tried to blend out that line down the side that you were on about doing whilst repairing the damage. If only real life was that easy lol
ps. wangan wing, top spoiler and a bit of flare
I'll stop hijacking anytime soon just giving you naughty ideas of what it should become
Old 18-11-2007, 19:26   #13 (permalink)
Dori Mat
UberLifestyler
Dori Mat's Avatar
that looks great i like the black stripe to separate the two colours
Dori Mat is offline   Reply With Quote
Old 18-11-2007, 20:02   #14 (permalink)
MC2
Send a message via MSN to MC2
Love it with the gold rims... Do iiiiitttt
MC2 is offline   Reply With Quote
Old 19-11-2007, 13:09   #15 (permalink)
Pikey
Pikey's Avatar
That spoiler looks good on there - what a coincidence I sold him one that looks just like that last week
Old 19-11-2007, 14:39   #16 (permalink)
Ali
Ali's Avatar
Yup I know thats why its on there, its actually chopped from a pic in your for sale thread but changing matt black to piss green is pretty hard lol
Old 19-11-2007, 14:52   #17 (permalink)
Andy_f
I <3 BDC!
Andy_f's Avatar
I actually like the look of the spoilers in gray though, didn't think of doing that.
Old 19-11-2007, 15:04   #18 (permalink)
Hammond
~frick!racing~
Hammond's Avatar
Andy, you've soo gotta do that! Car is looking awesome dude
Hammond is online now   Reply With Quote
Old 19-11-2007, 22:56   #19 (permalink)
retrodan
celebs in car
retrodan's Avatar
2tone factory paint ftw!! low an hard!!! looks like a good idea to make a cool skid car!!
Old 07-02-2008, 18:35   #20 (permalink)
Andy_f
I <3 BDC!
Andy_f's Avatar
After a trip to see Mitch yesterday, and a trip to DW HQ last week, I can finally do an update! Fairly substantial one.
Fitted the spoiler ages ago, forgot to update. Looks badass!
FIA seats purchased! Cobra Suzuka for the drivers side, OMP Eco for the passenger, since I'm a tight ass. Problem: with a normal subframe, the suzuka is far too high. From research i have done, it seems everyone has the same issue with the seat and any subframe. Solution? Hack up the original mountings.
It seems that its not a structural part, but I can always weld in some box section to put strength back if needed. I'm just going to basically make some L brackets and mount it straight to the floor, which gives me a perfect driving position. Roll cage also trial fitted - Fabricage FIA straight leg dash dodger, for fitting with minimal fuss.
Pics of seat/cage:
Check out the headroom!
You can also see the plumbed in fire extinguisher in that pic, waiting to be fitted.
Front tow hook semi-fitted:
Had to mount it at an angle to avoid the IC pipework and to fit through a gap in the bumper with minimal fettling. Unsure about where or how to mount the rear one, if you have any ideas feel free to spout them.
Cut off wired in and working, not mounted yet. Need to make a nice panel on the dash to mount stuff to:
Its finally getting there! Ordered a set of harnesses last night, and then need to buy my safety gear. Aiming for licencing at Silverstone on the 16th March.
